Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Infinity-Box > Chinese Miracle & PinFinder
Old 01-04-2012, 12:11   #1 (permalink)
Member: 57358
help me with Nokia X7 China phone CPU MT6235BA
I have Nokia X7 China phone dead .Cpu MT6235BA is very hot.I changed another CPU.CPU now is ok.But phone can not power on.
Here is log read full detail :
COM16 [VCP1] selected
module v3.30
Device: Autodetect 6228-6268 NAND
Checking data, wait...
Action: read/check information
interface: BROM_DLL_v3.1016.00
Connect...
Connecting...
Booting...
Release Power button now !
bootcode current/expected: 3.2/3.2
CPU: 6235:8A04:8A01
status: FF
bbchip bl ver: FE
NOR flash chip: not installed
NAND flash id[0014]: 0098:00D100900015 [TOSHIBA] TC58NVG0S3AFT
chip size: 128Mb
page/spare size: 0800/0040
pages per block: 0040
bits i/o: 08
address cycles: 04
internal RAM size: 00010000
external RAM: S_DA_RAM_ERROR
done
Set baudrate (921600)...
done
ram test...
testing 32bit...
32bit ram test passed
testing 16bit...
16bit ram test passed
ram test passed
===> detect existing firmware structure...
detect ffs...
ffs offset/size: 02000000/06000000
firmware size: 32Mb
ffs size: 96Mb
detect sec ro...
detect custom parameters...
detect project-id...
project-id: SH7-CN3_SW_TOS_V004
detect NAND info...
number of areas/bytes to read: 1:001A0000
reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)...
nfi area detection...
bootloader version: SLD35_09A_BOOTLOADER_V005_MT6235B_SH7-CN3_SW_TOS_V004.bin
nfi area detection (3 cores) finished: Ok
TCL-ID detection...
TCL-ID detection done
startup code area #1 detection...
startup code area #1 detection done
rom info ver: 07
sw version: SLD35_09A_PCB01_GPRS_MT6235B_S01.SH7-CN3_SW_TOS_V004.BIN
project-id: SH7-CN3_SW_TOS_V004, 00000000
code offset: 00000000
ffs offset/size [01]: 02000000/06000000
rom info structure: [standard] type (07)
TCL-ID is absent
===> done
New firmware found (v.3.30, database date: 17.04.2011):
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: mtk@infinity-box.com or upload files to RapidShare ? Secure Data Logistics or 4shared.com - free file sharing and storage
- include in your e-mail full text from phone back label (phone name etc.)
Disconnect...
done
Finished, time used: 1 min 21 sec
Remove/Install battery now !
how can i repair it ? I can not find firmware file in support area !
Old 01-04-2012, 16:19   #2 (permalink)
Member: 148515
hello!
sorry, no such file in our collection.
maybe some forum member will share it or probably you can find same working phone on local market. Read full flash and write to damaged phone
Old 01-04-2012, 19:12   #3 (permalink)
Member: 57358
hello!
This phone have problem with CPU so can i read full flash and send it to you to make firmware ? Or i must reflash it with firmare from another working phone ?
I connect it to a power meter , press power on key , it takes a little mili Ampe and fall down when i release power on key.it looks like another phone have a problem with normal CPU 6225 ect... .But i change 3 CPU 6235 . The same , can not power on but can read detail and full flash with Infinity ! Thanks so much for your help !
Old 01-05-2012, 16:01   #4 (permalink)
Member: 57358
anybody help me ? Please !
Old 01-05-2012, 21:05   #5 (permalink)
Member: 148515
hello!
some NAND phone, which 6235 phone is, might get damaged even if EEPROM is erased. there is no tools on market which can re-write EEPROM in NAND phone.
So, probably, even full flash from good working phone will not repair your damaged phone
Old 01-06-2012, 22:36   #6 (permalink)
Member: 57358
So there is no solution for this phone ?
Old 01-06-2012, 22:39   #7 (permalink)
Member: 57358
EEprom is located in flash or in CPU ? Flash is ok ! i think that it can not be damaged.Only problem with CPU.
Old 01-08-2012, 17:05   #8 (permalink)
Member: 148515
hello!
FFS area is kept in flash IC, after firmware area
Old 01-27-2012, 10:36   #9 (permalink)
Stoyan's Avatar
Member: 14868
mate could you tell me the pinouts of this phone , are they on pcb or on charger connector? tried almost everything.
Old 01-27-2012, 12:44   #10 (permalink)
Member: 148515
hello!
i can advise one good and fast method for finding Tx/Rx.
you need only multimeter for this
Old 01-27-2012, 17:52   #11 (permalink)
Stoyan's Avatar
Member: 14868
yes, 2,7v on any point on the plate at power-on phone. But there is no any point with such value, either close to it. right?
found some ping but software cann t detect right NAND
Old 01-28-2012, 01:34   #12 (permalink)
Member: 148515
hello!
yes, 2,8 volts...either on connector pins or available test points
Old 09-29-2012, 09:49   #13 (permalink)
Member: 523637
Help master.....i need that file of nokia cchinaphone X7....SLD35_09A_BOOTLOADER_V005_MT6235B_SH7_IND-EN1_900_SW_TOS_V001.biV005.bin.
can u share an good copy of that FW...Please....
thank you for attention.
New Nokia Software!!!!!!! Jefferson Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 73 05-15-2013 13:07
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 26 09-25-2012 02:41
Page generated in 0.31730 seconds with 11 queries
