Old 05-11-2009, 10:11   #1 (permalink)
sebY7676's Avatar
Member: 637351
Thanks Meter: 167
Help N95-8GB
Hi all, pls Infinity help...N95-8GB come to me with problem "power-off itself".
HERE IS LOG from phone(readed detailed)
COM6 [VCP0] selected
module v2.82
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: read/check detailed information
Boot ...
19200 fixed
Connecting, wait...
Initializing [6226:8A02:8A01]...
CPU: MT6226
high speed boot Off
chip: 0031:3566:B370
status: FF
high speed boot Off
boot packet size: 0002
Release Power button now !
Boot Done
Initialize ...
flash: EC257E25082501:2CEA0000000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
Set baud ...
115200
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
device parameters autodetection in progress...
it's time to stop: 2C0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
warning: wrong data size at 0x00232BDC, retry...
read error recovered
security area (code #1) is Ok
security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.8C8B8998.[N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32.B IN_79236150].rpl
identification#1 detection finished
device-id: 8C8B8998
identification#1 protocol ver: 04
ver. sw 1: N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32.B IN
ver. sw 2: MAUI.06B.W07.04.MP.V32, AF9EDC86
ffs offset/size: 00E00000/00200000
detect device identification#2...
detect device identification#2 finished
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
checking area [00000000]: 00000000-00FFFFFF...
ffs/eeprom found near: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
detecting ffs/eeprom structure pass 1...
detect standard fat location pass #1...
detect extended fat location pass #1...
detect standard fat offset pass #1...
detect standard fat data...
fat layout detection complete
ffs/eeprom detected ok: element #1
detecting ffs/eeprom structure pass 2...
ffs/eeprom detected ok element #2
Check firmware integrity Done
Check firmware content ...
detecting firmware build...
firmware build: 200801151232
detecting product-id...
done
detecting languages...
language parameters detected
detected languages: En Ru Fr Es Hu Ro Pl Id Sk Ar
Check firmware content Done
Backup required data ...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\N 95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32__s ystem_log_8C8B8998_79236150_20090511-101220.B0X.bin
Finished, time used: 370 sec
Remove/Install battery now !
After, i format FFS safe mod , and now, appear only NOKIA logo, but phone cant power-on.
Here is log:
module v2.82
Action: reset settings
Model: Autodetect 6205-6227 NOR
19200 autodetect
CPU: MT6226
high speed boot Off
status: FF
Connecting at 19200, wait...
Phone detected, wait...
Hardware: MT6226,E02
Date: 2005.04.12
Version: 1.0
Version: MAUI.06B.W07.04.MP.V32
Version: N95_06B_HW
detecting structure #2...
warning: wrong packet cs
0warning: wrong packet cs
done
44 byte(s) read
imei: 35502091809656
connection Ok
building list...
done
items to clear: 169
items cleared: 144 of 169
items remains: 0
Finished, time used: 153 sec
What is next step for repair this phone??
I read full flash, and i will send.
Old 05-11-2009, 10:58   #2 (permalink)
biochemistali's Avatar
Member: 190344
Thanks Meter: 280
1. reduce speed
2. press power on key during the whole operation.
Old 05-11-2009, 11:05   #3 (permalink)
sebY7676's Avatar
Member: 637351
Thanks Meter: 167
Originally Posted by biochemistali View Post
1. reduce speed
....and format ffs again? Pls, tell me..
Old 05-11-2009, 11:36   #4 (permalink)
Member: 463037
Thanks Meter: 135
download this flash files from support.N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_ MP_V32.B IN
after flash test the phone w/ battery if the same problem before you flash...or rehot the CPU...
The Following User Says Thank You to wilnert For This Useful Post:
Old 05-11-2009, 11:42   #5 (permalink)
sebY7676's Avatar
Member: 637351
Thanks Meter: 167
Thanks, i will try and i will come with details...
Old 05-11-2009, 13:31   #6 (permalink)
sebY7676's Avatar
Member: 637351
Thanks Meter: 167
Thanks for help, flash with succes and now the phone work well
Here is log
module v2.82
Action: write NOR flash
"smart write" active
write: Firmware
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
ffs/eeprom backup enabled, it may takes several minutes !
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6226
high speed boot Off
status: FF
high speed boot Off
Boot Done
Initialize ...
Initialize Done
Set baud ...
921600
Set baud Done
device-id: 8C8B8998
ffs/eeprom chip: 00
reading: N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32__ ffs...
warning: wrong data size at 0x00E53800, retry...
warning: wrong data size at 0x00E94800, retry...
warning: wrong data size at 0x00EC2800, retry...
warning: wrong data size at 0x00EF5000, retry...
warning: wrong data size at 0x00EF7000, retry...
warning: wrong data size at 0x00F25C00, retry...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\N95_PCB01_GPRS_MT 6226_S01.MAUI_06B_W07_04_MP_V32__ffs_20090511-141209.B0E.bin
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
security area (code #1) calculation...
done
detecting security area (code #2)...
security area (code #2) is found
security area (code #2) is fixed
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\N 95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32__s ystem_log_8C8B8998_79236150_20090511-141227.B0X.bin
Area: Firmware
Write: Firmware
Write Done
Finalization ...
Finalization Done
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\N 95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32__s ystem_log_8C8B8998_79236150_20090511-141314.B0X.bin
Finished, time used: 304 sec
Regards
Old 05-15-2009, 19:34   #7 (permalink)
sebY7676's Avatar
Member: 637351
Thanks Meter: 167
Again need help.After flash, phone work ok 2 days, but now something strange is happen...behave like keep press a key continuous... sometime and on this time, freeze. I verify keypad, but nothing seem wrong...is software problem?
Old 05-16-2009, 14:29   #8 (permalink)
genci titi 2002's Avatar
Member: 193804
Sonork: 100.1684818
Thanks Meter: 1,693
try to rehot the CPU.........
Old 05-16-2009, 21:07   #9 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
i agree with mr. geti
try to heat CPU
Old 06-01-2009, 17:32   #10 (permalink)
sebY7676's Avatar
Member: 637351
Thanks Meter: 167
Pls, can you tell me where is located cpu the phone still power-off itself ?
Old 06-01-2009, 21:45   #11 (permalink)
Member: 148515
hello!
CPU is ussually biggest IC.
but you also can locate it by name MT62xx on it
Old 06-07-2009, 00:21   #12 (permalink)
GSM PAVIA's Avatar
Member: 235881
Thanks Meter: 221
HELP AFTER FORMAT PHONE DEAD I HAVE FLASH PHONE ALWAYS LCD BLANCK I HAVE CHENGE FLASH FILE BAT NOT WORK
N 95 8G RM 15
ver. sw 1: N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04N95_PCB01 _GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32.BIN_MP_V32 .BIN
ver. sw 2: MAUI.06B.W07.04.MP.V32, 7B38A8FA
module v2.82
19200 autodetect
CPU: MT6226
high speed boot Off
chip: 0031:C084:56DF
status: FF
Date: 2005.04.12
Version: 1.0
Version: N95_06B_HW
0 done
44 byte(s) read
imei: 35792701116388
connection Ok
building list...
done
items to clear: 222
items cleared: 143 of 222
items remains: 0
Finished, time used: 402 sec
I HAVE USE THIS FLASH FILE
N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32__ _NOKIA_N95_16m_En_Ru_Fr_Es_Ml_Id_Th_Vn_Cn_Ar.B0M
N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32_N okia-N95-8Gb_Ro_16m_En_Ru_Fr_Hu_Ro_Pl_Ml_Id_Vn_Sk_Ar.B0M
N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32__ _N95_8GB_16m_En_Ru_Fr_De_Id_Th_Vn_Cn_Tr_Ar.B0M
N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32_1 6m_En_Ru_Fr_Ml_Id_Vn_Cn_Ar_ver2.B0M
PLZ WHATE FLASH FILE GOOD IN SUPPORT FOR MY PHONE
Old 06-11-2009, 20:23   #13 (permalink)
Member: 148515
hello!
if you dont have original backup you must try all files available on support one by one
Help help N95 8GB after write pm Phone start-up failed contact the reailer:::ANSWERED mohit_kripalu01 Universalbox 10 08-16-2009 09:34
Help help N95 8GB after write pm Phone start-up failed contact the reailer mohit_kripalu01 Nokia Base Band 5 ( BB-5 ) 18 03-06-2009 15:08
help.. n95 8gb need pin out.. acay Chinese Models & Cloned Phones 0 08-22-2008 12:23
major problem help!, N95 8gb shengster Nokia Multimedia 0 08-05-2008 17:14
Page generated in 0.27059 seconds with 10 queries
