10-23-2009, 10:28 | #1 (permalink) |
No Life Poster Join Date: Sep 2004
Member: 82423 Status: Offline Thanks Meter: 1,203 | NKTEL A800 "Invalid video file" Problem I have A800 When I one phone without sim and put memory card and run video its work fine. But when I put sim and memory card and run video its show "Invalid video file".I downlaod flash file from support area "X6720_ABROAD_PCB01_GPRS_MT6225_S00.6720_ABROAD_2CD GB_V1_1_2__NKTEL-A800_16m_En_Ru_El_Fr_Th_Vn_Tr_Hi_Farsi_Pt_Bg_Ar.B0 M" and flash phone with file phone dead. I read before flash full flash backup and I right to phone its live but still same. Here is logs support area download flash file I do all think not success. Any idea how to solve this issue COM7 [VCP0] selected module v2.95 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active write: Firmware X6720_ABROAD_PCB01_GPRS_MT6225_S00.6720_ABROAD_2CD GB_V1_1_2__NKTEL-A800_16m_En_Ru_El_Fr_Th_Vn_Tr_Hi_Farsi_Pt_Bg_Ar.B0 M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:1103:0002 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #02 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #03 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is damaged, recalculation required rom info detection finished device-id: DF7FA230 rom info protocol ver: 04 ver. sw 1: X6720_ABROAD_PCB01_GPRS_MT6225_S00.6720_ABROAD_2CD GB_V1_1_4.BIN ver. sw 2: 6720_ABROAD_2CDGB_V1.1.4, DBFCAA4A address offset: 00000000 ffs offset/size: 00E00000/00200000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished startup code area #1 check... warning: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.DF7FA230.[X6720_ABROAD_PCB01_GPRS_MT6225_S00.6720_ABROAD_2CD GB_V1_1_2.BIN_D19131C1].rpl warning: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.DF7FA230._X672 0_ABROAD_PCB01_GPRS_MT6225_S00.6720_ABROAD_2CDGB_V 1_1_2.BIN_D19131C1_.rpl warning: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.DF7FA230.[X6720_ABROAD_PCB01_GPRS_MT6225_S00.6720_ABROAD_2CD GB_V1_1_2.BIN_D19131C1].rpl warning: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.DF7FA230._X6720_ABROAD_PCB01_GPRS_MT6225_S00.672 0_ABROAD_2CDGB_V1_1_2.BIN_D19131C1_.rpl ==================== warning: unknown rom info structure: X6720_ABROAD_PCB01_GPRS_MT6225_S00.6720_ABROAD_2CD GB_V1_1_2.BIN_D19131C1 Unknown firmware detected (v.2.95, database date: ), user action required: 1. download latest software from support area and try again 2. if no still luck follow the next procedure: - find good working phone with the same firmware: X6720_ABROAD_PCB01_GPRS_MT6225_S00.6720_ABROAD_2CD GB_V1_1_2.BIN - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) - be little bit patient and wait update ==================== error: startup code area #1 can't be fixed detecting startup code area #2... startup code area #2 is absent You can flash phone now but can not finalize it. In most cases phone CAN NOT power-on. Do you want to continue anyway ? file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\X 6720_ABROAD_PCB01_GPRS_MT6225_S00.6720_ABROAD_2CDG B_V1_1_4__system_log_DF7FA230_4AAAFCDB_20091023-150529.B0X.bin Area: Firmware flash: 98000300000001:18E59F00000000 Write: Firmware sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done Finalization ... Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\X 6720_ABROAD_PCB01_GPRS_MT6225_S00.6720_ABROAD_2CDG B_V1_1_4__system_log_DF7FA230_4AAAFCDB_20091023-151435.B0X.bin Finished, time used: 583 sec Remove/Install battery now ! Thanks in advance. |
The Following User Says Thank You to irfanamin2 For This Useful Post: |
10-23-2009, 10:31 | #2 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Rawalpindi, Pakistan
Member: 421117 Status: Offline Sonork: +92 346 5544377 (PHONE) Thanks Meter: 2,522 | It's a problem in Video format Read it http://forum.gsmhosting.com/vbb/show...15&postcount=3 |
10-23-2009, 10:45 | #3 (permalink) |
Member: 82423 Status: Offline Thanks Meter: 1,203 | Here is read ful flash logs: COM7 [VCP0] selected module v2.95 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active write: Firmware A800flash_X6720_ABROAD_PCB01_GPRS_MT6225_S00.6720_ ABROAD_2CDGB_V1_2_3__fullflash_20091021-152114.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:1103:0002 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #02 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #03 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is damaged, recalculation required rom info detection finished device-id: DF7FA230 rom info protocol ver: 04 ver. sw 1: X6720_ABROAD_PCB01_GPRS_MT6225_S00.6720_ABROAD_2CD GB_V1_1_2.BIN ver. sw 2: 6720_ABROAD_2CDGB_V1.1.2, C13191D1 address offset: 00000000 ffs offset/size: 00E00000/00200000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished startup code area #1 check... warning: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.DF7FA230.[X6720_ABROAD_PCB01_GPRS_MT6225_S00.6720_ABROAD_2CD GB_V1_2_3.BIN_DC4B549C].rpl warning: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.DF7FA230._X672 0_ABROAD_PCB01_GPRS_MT6225_S00.6720_ABROAD_2CDGB_V 1_2_3.BIN_DC4B549C_.rpl startup code area #1 backup loaded startup code area #1 calculation... startup code area #1 fixed detecting startup code area #2... startup code area #2 is absent file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\X 6720_ABROAD_PCB01_GPRS_MT6225_S00.6720_ABROAD_2CDG B_V1_1_2__system_log_DF7FA230_D19131C1_20091023-152649.B0X.bin Area: Firmware flash: 98000300000001:18E59F00000000 Write: Firmware sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done Finalization ... Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\X 6720_ABROAD_PCB01_GPRS_MT6225_S00.6720_ABROAD_2CDG B_V1_1_2__system_log_DF7FA230_D19131C1_20091023-153657.B0X.bin Finished, time used: 975 sec Remove/Install battery now ! |
10-23-2009, 10:55 | #4 (permalink) | |
Member: 82423 Status: Offline Thanks Meter: 1,203 | Quote:
10-23-2009, 11:49 | #6 (permalink) |
Member: 82423 Status: Offline Thanks Meter: 1,203 | Mate! @shakeel145 format avi but only run camera recoding video file I put move song MP4, 3gp & avi in Memory card not work I get "Invalid video file" this error. with out sim both format run fine. any idea |
10-26-2009, 12:57 | #9 (permalink) |
Member: 82423 Status: Offline Thanks Meter: 1,203 | Mate! I do safe & complete but still same. Please update his flashing "X6720_ABROAD_PCB01_GPRS_MT6225_S00.6720_ABROAD_2C D GB_V1_1_2__NKTEL-A800_16m_En_Ru_El_Fr_Th_Vn_Tr_Hi_Farsi_Pt_Bg_Ar.B0 M" & X6720_ABROAD_PCB01_GPRS_MT6225_S00.6720_ ABROAD_2CDGB_V1_2_3__fullflash_20091021-152114.B0M.bin version. Thanks in advance. |
03-18-2010, 17:45 | #11 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: ONLY PRIVATE MSG
Member: 220932 Status: Offline Sonork: 100.1592154 Thanks Meter: 110 | Quote:
log COM5 [VCP2] selected module v3.10 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware X6720_ABROAD_PCB01_GPRS_MT6225_S00.6720_ABROAD_2CD GB_V1_1_6__NKTEL-A800_16m_En_Ru_Gr_Fr_Th_Vn_Tr_Hi_Farsi_Pt_Bg_Ar.B0 M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:B603:0002 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #02 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #03 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.E12CDE16.[X6720_ABROAD_PCB01_GPRS_MT6225_S00.6720_ABROAD_2CD GB_V1_1_6.BIN_1B4166C6].rpl rom info detection finished device-id: E12CDE16 rom info ver: 04 sw version: X6720_ABROAD_PCB01_GPRS_MT6225_S00.6720_ABROAD_2CD GB_V1_1_6.BIN project-id: 6720_ABROAD_2CDGB_V1.1.6, C666411B code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [enhanced] generation TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: X6720_ABROAD_PCB01_GPRS_MT6225_S00.6720_ABROAD_2CD GB_V1_1_6__ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\X6720_ABROAD_PCB0 1_GPRS_MT6225_S00.6720_ABROAD_2CDGB_V1_1_6__ffs_20 100318-212027.B0E.bin flash: 98000300000001:18E59F00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... startup code area #1 calculation... startup code area #1 fixed detecting startup code area #2... startup code area #2 is absent file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\X 6720_ABROAD_PCB01_GPRS_MT6225_S00.6720_ABROAD_2CDG B_V1_1_6__system_log_E12CDE16_1B4166C6_20100318-212040.B0X.bin Area: Firmware flash: 98000300000001:18E59F00000000 Write: Firmware sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\X 6720_ABROAD_PCB01_GPRS_MT6225_S00.6720_ABROAD_2CDG B_V1_1_6__system_log_E12CDE16_1B4166C6_20100318-212111.B0X.bin Finished, time used: 6 min 8 sec Remove/Install battery now ! | |
03-19-2010, 09:35 | #12 (permalink) |
No Life Poster Join Date: Aug 2006 Location: P@kIsTaN
Member: 327384 Status: Offline Sonork: 100.1605419 Thanks Meter: 312 | Hello bro flash with this file your problem will be solve then post here result..... X6720_ABROAD_PCB01_GPRS_MT6225_S00[1].6720_ABROAD_2CDGB_V1_1_4__NKTEL-A800_16m_En_Ru_Gr_Fr_Th_Vn_Tr_Hi_Farsi_Pt_Bg_Ar.B0 M |
Need nktel a800 ok file | rameez_gsm | Infinity-Box | 25 | 03-16-2010 11:32 |
NKTEL 2008 making video restart | rameez_gsm | Infinity-Box | 5 | 01-09-2010 05:12 |
NKTEL A800 firmware needed | zeerik | SpiderMan | 2 | 11-02-2009 16:04 |
Nktel A800 | eman_sayed55 | SpiderMan | 3 | 10-25-2009 12:25 |
NKTEL A800 invalid video file | rameez_gsm | Chinese Models & Cloned Phones | 2 | 10-24-2009 19:31 |
