Go Back   GSM-Forum > Product Support Sections > Hard/Software-Products (official support) > Infinity-Box > Chinese Miracle & PinFinder
Old 09-19-2009, 17:09   #1 (permalink)
unlock_solution's Avatar
Member: 478791
Red face hi sir i got some sets when i try to format i got flash erase error
i have china copy e 55 i read that full backup sucessfully but canot restore got flash erase error ......... i got another some a 200 also and some more phones ...but still same even spider and cpf cannot flash that phones plz help ............. here is log
COM27 [VCP0] selected
module v2.90
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: write NOR flash
"smart write" active
write: Firmware
C55_LH_TS_PCB01_GPRS_MT6225_S00.W08_12_5__fullflas h_20090917-224658.B0M.bin
skip: Customization/Language Pack
skip: Customization
write: Eeprom/ffs
C55_LH_TS_PCB01_GPRS_MT6225_S00.W08_12_5__ffs_2009 0917-225130.B0E.bin
enhanced security fix enabled
Boot ...
baud autodetection active
19200 autodetect
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:F403:0007
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: 98000300000001:00000000000000
flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
Set baud ...
460800
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
detect device rom info...
detection phase #1...
detection phase #2...
warning: rom info information not found, possible reasons:
.old firmware type w/o rom info data
.damaged firmware
.damaged hardware
if phone works fine just ignore this warning
detect device rom info finished
detect device sec info...
detect device sec info finished
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
.damaged firmware
.damaged hardware
ffs address can not be detected, value from database assigned: 00000000/00000001
startup code area #1 check...
startup code area #1 fixed
detecting startup code area #2...
startup code area #2 is absent
Area: Firmware
Write: Firmware
error: wrong answer: 3B
error: flash write error: 00000000:00002000
Write Done
Finalization ...
Finalization Done
Finished, time used: 221 sec
Remove/Install battery now !
plz help
wbr varun
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Share on Facebook
Old 09-19-2009, 22:14   #2 (permalink)
Member: 148515
hello!
what cable/box do you use as interface?
Old 09-20-2009, 08:54   #3 (permalink)
Member: 478791
sir using spiderman as interface ..............wbr varun
Old 09-20-2009, 14:12   #4 (permalink)
Member: 148515
hello!
you have installed bad drivers for your spiderman box.
please use good drivers from our support area and this problem will gone forewer
support area path is: software / utilities / Prolific /
Old 09-21-2009, 12:05   #5 (permalink)
Member: 478791
sir i found that drivers in support area and update spiderman with that after that still same ...there are two drivers 2.0.28 and wd i tried one by one but still same ...........error showing flash write error ...
plz help ........wbr varun
Refbacks are Off
GSMCity - GSM Hosting - 1999-2010
Page generated in 0.55530 seconds with 8 queries
