Old 11-24-2008, 07:04   #1 (permalink)
PRIMACELL's Avatar
Member: 427685
Thanks Meter: 103
HITECH H39 DEAD,repaired ok
==== log: [11/24/2008 1:21:36 PM] ====
COM3 [VCP0] selected
module v2.69
Device: Autodetect 6205-6227 NOR
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: read NOR flash
Boot ...
19200 fixed
Connecting, wait...
Initializing [6226:8A02:8A01]...
CPU: MT6226
high speed boot disabled
chip: 0031:AADA:A9D2
high speed disabled
boot packet size: 0002
Release Power button now !
Boot Done
Initialize ...
flash: EC257E25082501:2AEA0000000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud ...
460800
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
device parameters autodetection in progress...
it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area (code #1) is Ok
security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.714F72D1.[U26_06B_PCB01_GPRS_MT6226_S01.UPU25U26V03B59.BIN_4 F6076A5].rpl
identification#1 detection finished
device-id: 714F72D1
identification#1 protocol ver: 04
ver. sw 1: U26_06B_PCB01_GPRS_MT6226_S01.UPU25U26V03B59.BIN
ver. sw 2: UPU25U26V03B59, 5A899FB0
ffs offset/size: 00E00000/00200000
detect device identification#2...
warning: optional information is not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00E00000
checking area [00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00E00000
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
reading: flash[U26_06B_PCB01_GPRS_MT6226_S01.UPU25U26V03B59.BIN]...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\flash[U26_06B_PCB01_GPRS_MT6226_S01.UPU25U26V03B59.BIN]_20081124-133439.B0M.bin
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_714F72D1_U26_06B_PCB01_GPRS_MT6226_S01.U PU25U26V03B59.BIN_4F6076A5_20081124-133449.B0X.bin
Finished, time used: 774 sec
Remove/Install battery now !
WARNING ! Settings will be cleared, user data erased, Imei set to default value !
Make flash backup before this procedure !
Do you want to continue ?
==== log: [11/24/2008 1:34:56 PM] ====
module v2.69
Action: reset settings
Model: Autodetect 6205-6227 NOR
19200 autodetect
CPU: MT6226
Connecting, wait...
error: can't finalize test mode
repeat operation and HOLD phone "Power" button long time !
error: operation failed !
Finished, time used: 99 sec
==== log: [11/24/2008 1:37:16 PM] ====
module v2.69
Action: "format ffs"
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6226
high speed disabled
Boot Done
Initialize ...
Initialize Done
Set baud ...
460800
Set baud Done
device-id: 714F72D1
ffs chip: 00
reading: eeprom[U26_06B_PCB01_GPRS_MT6226_S01.UPU25U26V03B59.BIN]...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[U26_06B_PCB01_GPRS_MT6226_S01.UPU25U26V03B59.BIN]_20081124-134052.B0E.bin
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
Write Done
Finalization ...
formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_714F72D1_U26_06B_PCB01_GPRS_MT6226_S01.U PU25U26V03B59.BIN_4F6076A5_20081124-134111.B0X.bin
Finished, time used: 230 sec
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
Old 11-24-2008, 18:05   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
thank you for sharing your experience!!!
need file hitech h39 alfred_smd CPF-BOX Ⅱ 1 03-09-2009 03:38
VeKing can't find pinout hitech h39 notgood VE-KING 2 01-02-2009 20:15
HiTech H39 need help notgood Infinity-Box 2 08-05-2008 14:04
dead V3R repair ok phonetool Smart-Clip 13 01-26-2007 02:43
Page generated in 0.15076 seconds with 10 queries
