11-23-2008, 14:17 | #1 (permalink) |
Freak Poster Join Date: Jun 2007 Location: S A H I W A L Age: 38
Member: 526737 Status: Offline Thanks Meter: 9 | How can i solved 6300rh-37 after flash blank display... module v2.69 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: write NOR flash skip: Firmware skip: Customization/Language Pack skip: Customization write: Eeprom/ffs Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:4F03:0004 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.638FDBD1.[JIA6300_PCB01_GPRS_MT6225_S00.MAUI_07A_W07_52_MP_V 2.BIN_E4B7E688].rpl identification#1 detection finished device-id: 638FDBD1 identification#1 protocol ver: 04 ver. sw 1: JIA6300_PCB01_GPRS_MT6225_S00.MAUI_07A_W07_52_MP_V 2.BIN ver. sw 2: MAUI.07A.W07.52.MP.V2, 7719481B ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: 01227E22202200:18E59F00000000 checking area [00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: eeprom[JIA6300_PCB01_GPRS_MT6225_S00.MAUI_07A_W07_52_MP_V 2.BIN]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\RH-37\eeprom[JIA6300_PCB01_GPRS_MT6225_S00.MAUI_07A_W07_52_MP_V 2.BIN]_20081123-050209.B0E.bin flash: 01227E22202200:18E59F00000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_638FDBD1_JIA6300_PCB01_GPRS_MT6225_S00.M AUI_07A_W07_52_MP_V2.BIN_E4B7E688_20081123-050224.B0X.bin Area: Eeprom/ffs flash: 01227E22202200:18E59F00000000 Write: Eeprom/ffs detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished Write Done Finalization ... Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_638FDBD1_JIA6300_PCB01_GPRS_MT6225_S00.M AUI_07A_W07_52_MP_V2.BIN_E4B7E688_20081123-050349.B0X.bin Finished, time used: 181 sec Remove/Install battery now ! Loading failed, probably damaged data file Loading failed, probably damaged data file please sir help me . . . .i have1 piece chines 6300 rh-37 dead. . . I flashed the fone difrent firmwere on the support flash is ok but display is blank. . . please tell me how can solved this problem. . . I write the original backup but problem is same phone display is already blank. . . Regards... aamirgsm |
11-23-2008, 14:40 | #3 (permalink) |
Member: 526737 Status: Offline Thanks Meter: 9 | yes i have this given below backup file which was saved during flash: http://rapidshare.com/files/16658834...0.B0E.bin.html |
11-23-2008, 14:54 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! we have more than 10 same version firmwares on our support site. download some of them and flash to phone. each time after this make Format FFS complete. i am sure this will solve your problem, if battery is full charged |
11-23-2008, 16:01 | #5 (permalink) |
Member: 526737 Status: Offline Thanks Meter: 9 | Dear Sir, I wrote all the firmware's which are available at teh support, but none of them is suitable for my phone. . . and problem is still same. . . so plz assist me now wat should i have to do to revive this phone properly. . . . Regard's aamirgsm |
11-23-2008, 16:14 | #6 (permalink) | |
No Life Poster Join Date: May 2008 Location: COME & MADE GREEN WORLD
Member: 771937 Status: Offline Sonork: 100.1605717 Thanks Meter: 1,052 | Quote:
[JIA6300_PCB01_GPRS_MT6225_S00.MAUI_07A_W07_52_MP_V 2.BIN]_20081123-050209.B0E.bin | |
11-23-2008, 17:32 | #7 (permalink) |
No Life Poster Join Date: Oct 2005 Location: Islamabad--Pakistan
Member: 194128 Status: Offline Thanks Meter: 303 | Here is the fully working flashfile of this mobile. I just read it from a working phone. http://www.4shared.com/file/72801611..._MP_V2BIN.html BEST OF LUCK! yawarniazi |
11-24-2008, 08:02 | #10 (permalink) | |
Member: 526737 Status: Offline Thanks Meter: 9 | Quote:
Dear yawarniazi I write the flash file after then ffs formate but problem is same. . . | |
11-24-2008, 12:03 | #13 (permalink) |
Member: 194128 Status: Offline Thanks Meter: 303 | Here is another working flash file of this phone. Hopefully this will help you to solve the problem http://www.4shared.com/file/72905947..._MP_V2BIN.html BEST OF LUCK! yawarniazi |
11-24-2008, 14:13 | #15 (permalink) | |
I thing it is hw problem. . . regar's aamirgsm | |
How can i solve Security Test Fail, after unlock by Mx-key | powerplay83 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 9 | 03-25-2010 14:39 |
E50 after flash blank display | ..::Sunil::.. | HWK | 38 | 02-21-2010 07:49 |
e71 after flash blank screen solved by mx key | adaki_vishal | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 11-10-2009 17:09 |
N-gage after flash white display blank | NuengEve | UFS2 + UFS3-Tornadoflasher | 3 | 02-06-2006 12:06 |
t722i help needed: after downgrade blank display. | chris_ua | Motorola P2k | 3 | 07-16-2003 16:34 |
