05-29-2010, 11:22 | #1 (permalink) |
No Life Poster Join Date: May 2010 Location: In The World
Member: 1294926 Status: Offline Sonork: 100.1608183 Thanks Meter: 126 | how to format this n95-8g -ffs:safe mode -complete mode -nand ..... but still no luck error: operation failed ! |
05-29-2010, 11:22 | #2 (permalink) |
Member: 1294926 Status: Offline Sonork: 100.1608183 Thanks Meter: 126 | COM6 [VCP0] selected module v3.14 Action: reset settings ("format ffs") Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:323A:B7FF status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: N95_8GB.V01 Version: 8GB_06B_500 detecting structure #2... 0 done 44 byte(s) read imei: 353xxxxxxxxxxx connection Ok building list... done items to clear: 143 items cleared: 0 of 143 items remains: 0 error: operation failed ! Finished, time used: 11 min 21 sec Remove/Install battery now ! |
05-31-2010, 20:06 | #8 (permalink) | |
Member: 1294926 Status: Offline Sonork: 100.1608183 Thanks Meter: 126 | Quote:
i am trying writing other firmware and it goes to dead phone . so i rewrite the old one and the phone goes to the first state. (goes off with sim) i think it's hardware probleme. coz i am solving alot of this n95 same probleme. but the question is why can't do formate ffs ? and if somone writed a wrong software before. is the infinity well give this error ? thinks | |
05-31-2010, 20:36 | #9 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! it is hard to say why it is not formating in Safe mode, but complete mode format is even better (it clears more) if it does not help- this is not FFS caused problem |
05-31-2010, 20:48 | #10 (permalink) | |
i say why it give error (not why not formating) plz see log : connection Ok building list... done items to clear: 143 items cleared: 0 of 143 items remains: 0 error: operation failed ! Finished, time used: 11 min 18 sec and when formating with complete mode it goes to dead phone ( i must reflach it to revive) | |
06-01-2010, 21:41 | #11 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | It looks like phone file system is seriously damaged and it can not be repaired with "safe" format. You must use "complete" format ! If you will have any problems with "complete" format - post here operation log to check. Last edited by InfinitySupport; 06-01-2010 at 21:47. |
11-30-2010, 09:15 | #12 (permalink) |
Freak Poster Join Date: Jun 2004 Location: Indonesia
Member: 69608 Status: Offline Thanks Meter: 63 | How About this error Cannot complete format??? try using repair FFS done but phone still hang on nokia logo... ====> Boot ... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:15CE:3491 status: FF high speed boot Off boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E223C2200:2CEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb otp offset: 00000000 detecting chip #01 in region #00... flash: 01227E223C2200:2CEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb otp offset: 00000000 number of flash chip/regions detected: 02/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 01227E223C2200:2CEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb otp offset: 00000000 detecting chip #01 in region #00... flash: 01227E223C2200:2CEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb otp offset: 00000000 it's time to stop: 2C0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 02000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (04), 1 record(s) TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.890A831A.[N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32.B IN_F1A262E8].rpl rom info detection finished device-id: 890A831A rom info ver: 04 sw version: N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32.B IN project-id: MAUI.06B.W07.04.MP.V32, E862A2F1 code offset: 00000000 ffs offset/size [01]: 01BE0000/00420000 rom info structure: [protected] type (04), 1 record(s) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 01BE0000 standard ffs/eeprom offset confirmed: 01BE0000 detecting ffs/eeprom size... ffs/eeprom size: 00420000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:01BE0000-01FFFFFF firmware area: 00000000-01BDFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32__ ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\N95_PCB01_GPRS_MT 6226_S01.MAUI_06B_W07_04_MP_V32__ffs_20101130-144328.B0E.bin flash: 01227E223C2200:2CEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 01227E223C2200:2CEA0000000000 error: wrong erase first sector at 0x01BE0000 error: format ffs failed Finalization Fail file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\N 95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32__s ystem_log_890A831A_F1A262E8_20101130-144338.B0X.bin Finished, time used: 2 min 0 sec Remove/Install battery now ! |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
