Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Infinity-Box > Chinese Miracle & PinFinder
Old 09-17-2008, 11:25   #1 (permalink)
david_aguirre's Avatar
Member: 698672
how to know the flash file of china phone?
dear infinity team, will you please guide how to know rigth flash file of this unit.. MT6226BA0745-BOAL DP47HB...This is the CPU type
6300flash_20080916-233026.B0M.bin
Old 09-17-2008, 12:49   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Hello,
Please, make search in support area by required model name or by firmware version.
Also do not forget to check \\flashfiles\\ChineseMiracle\\_doc folder
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 09-18-2008, 01:46   #3 (permalink)
Member: 698672
Originally Posted by InfinitySupport View Post
Hello,
there are many kinds of firmware in support area, how do i know the right firmware and version of this phone? thanks for your kindly support
Old 09-18-2008, 02:48   #4 (permalink)
Member: 698672
before the phone was hang up, after format the phone was dead here is the logs in complete mode
=== log: [9/17/2008 6:39:40 PM] ====
COM5 [VCP0] selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: "format ffs"
Boot...
baud autodetection active
19200 autodetect
Connecting, wait...
Initializing[6226:8A02:8A01]...
CPU: MT6226
high speed boot disabled
chip: 0031:4FB0D70
high speed disabled
boot step size: 0002
Release Power button now !
Boot Done
Initialize...
flash: EC257E25082501:FFFFFF00000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
115200
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
device parameters autodetection in progress..
Warning: probably flash chip empty, erased, incorrectly flashed or damaged.
What to do:
1. go to software "Settings" page
2. set "Advanced chip detection method" box UN-CHECKED !
3. make flash write operation
If still no luck: send mail to support (mt62xx@gmail.com) with detailed description of problem,
attach the next files in your e-mail:
1. C:\Program Files\InfinityBox\ChineseMiracle\operation.log
2. C:\Program Files\InfinityBox\ChineseMiracle\cfi_xxxx_xxxx.bin
it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detection phase #2...
warning: identification#1 information not found, possible reasons:
.old firmware type w/o identification#1 data
.damaged firmware
.damaged hardware
if phone works fine just ignore this warning
detect device identification#1 finished
detect device identification#2...
warning: optional information is not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset assigned: 00E00000
checking area[00000000]: 00000000-00FFFFFF...
Can't detect eeprom/ffs area
Do you want to use standard ffs address: 00E00000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
2. make flash backup for emergency case
3. repeat required operation
operation terminated by user
error: critical error#1 during ffs size detection
error: can't detect eeprom/ffs address/size
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
Backup required data Done
Patch required data...
Patch required data Done
Special operation...
Special operation Done
Write...
Write Done
Finalization...
formatting...
Finalization Done
Finished, time used: 177 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
Old 09-18-2008, 07:49   #5 (permalink)
Member: 130995
Hello,
Do not make "whole flash chip" format.
Now restore original phone backup and make "format" in "safe" mode.
If problem still exist make "format" in "complete" mode.
How can I know the flash size of BB5 phones? adam345 Universalbox 1 02-24-2009 07:44
how to know the card id of a Cruiser-06 dongle ? gsmsikar Cruiser Suite 1 11-12-2008 10:29
How to know the FW version of phone Warluck02 UST Pro II 1 09-30-2008 08:11
how to know the flash files of dead phones sanjubhai Chinese Models & Cloned Phones 4 05-08-2008 09:03
how to know the original ver. of v25 ? makona x1x to x45/x50 2 01-12-2001 06:27
Page generated in 0.29275 seconds with 11 queries
