02-23-2009, 11:11 | #1 (permalink) |
No Life Poster Join Date: Dec 2006 Location: punjab india
Member: 421487 Status: Offline Thanks Meter: 58 | how to remove enter lock code ztez828[ k100] |
02-23-2009, 11:24 | #2 (permalink) | |
No Life Poster Join Date: May 2005 Age: 40
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | Quote:
take full backup,eeprom and full flash then do format ffs if not success do complete format ffs.. | |
02-23-2009, 13:43 | #5 (permalink) | |
Freak Poster Join Date: Jan 2006 Location: Nigeria
Member: 218859 Status: Offline Thanks Meter: 2 | v300 chinese set Quote:
module v2.77 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard fast Unlock procedure can be faster if you skip ffs/eeprom area backup procedure. Do you want to disable ffs/eeprom backup ? ffs/eeprom backup disabled enhanced security fix enabled Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:8703:000E status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #02 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #03 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation ==================== New firmware detected (v.2.77, database date: 14.02.2009): BXWY25_GEMINI_PCB01_GPRS_MT6225_S00.A673_WAIWEN_V1 _6.BIN This firmware is missing in support area. If this phone is good and working: - make "Read full flash" operation - send flash backup files to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== identification#1 detection finished identification#1 protocol ver: 04 ver. sw 1: BXWY25_GEMINI_PCB01_GPRS_MT6225_S00.A673_WAIWEN_V1 _6.BIN ver. sw 2: A673_waiwen_V1.6, 00000000 ffs offset/size: 00E00000/00200000 detecting security area (code #2)... .................................................. .................................................. .................................................. .................................................. .................................................. ...... security area (code #2) is absent detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: EC257E25082501:18E59F00000000 checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF detecting ffs/eeprom structure pass 1... ......................... detect standard fat location pass #1... .................................................. ..... detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs/eeprom detected ok: element #1 Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... flash: EC257E25082501:18E59F00000000 Backup required data Done Patch required data ... .................................................. ..... lock area found Patch required data Done Special operation ... Special operation Done Write ... flash: EC257E25082501:18E59F00000000 flash: EC257E25082501:18E59F00000000 Write: lock-area-1 Write Done Finalization ... Finalization Done Finished, time used: 133 sec Remove/Install battery now ! but phone has refused to be unlocked.i has even started attaching full flash to support.maybe i should save my time if all this effort will not yield result. | |
02-23-2009, 13:47 | #6 (permalink) | |
module v2.77 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard fast Unlock procedure can be faster if you skip ffs/eeprom area backup procedure. Do you want to disable ffs/eeprom backup ? ffs/eeprom backup disabled enhanced security fix enabled Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:8703:000E status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #02 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #03 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation ==================== New firmware detected (v.2.77, database date: 14.02.2009): BXWY25_GEMINI_PCB01_GPRS_MT6225_S00.A673_WAIWEN_V1 _6.BIN This firmware is missing in support area. If this phone is good and working: - make "Read full flash" operation - send flash backup files to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== identification#1 detection finished identification#1 protocol ver: 04 ver. sw 1: BXWY25_GEMINI_PCB01_GPRS_MT6225_S00.A673_WAIWEN_V1 _6.BIN ver. sw 2: A673_waiwen_V1.6, 00000000 ffs offset/size: 00E00000/00200000 detecting security area (code #2)... .................................................. .................................................. .................................................. .................................................. .................................................. ...... security area (code #2) is absent detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: EC257E25082501:18E59F00000000 checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF detecting ffs/eeprom structure pass 1... ......................... detect standard fat location pass #1... .................................................. ..... detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs/eeprom detected ok: element #1 Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... flash: EC257E25082501:18E59F00000000 Backup required data Done Patch required data ... .................................................. ..... lock area found Patch required data Done Special operation ... Special operation Done Write ... flash: EC257E25082501:18E59F00000000 flash: EC257E25082501:18E59F00000000 Write: lock-area-1 Write Done Finalization ... Finalization Done Finished, time used: 133 sec Remove/Install battery now ! but phone has refused to be unlocked.i has even started attaching full flash to support.maybe i should save my time if all this effort will not yield result.i hv tried user unlock too and interchanged read code,standard fast etc.any hope for the phone? | |
How to remove phone lock code G810??? | jham | UST Pro II | 19 | 10-04-2009 12:11 |
How to remove phone lock code on k770 | sniper007 | SETool2 | 1 | 02-10-2009 15:12 |
How to remove phone lock code on x70? | sutiee | Panasonic | 9 | 04-21-2005 08:38 |
how to remove phone lock code on k508i | jusluke | Cruiser Suite | 4 | 01-27-2005 10:42 |
How to remove the Lock code from this phone ? | gsm_trade | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 08-04-1999 15:34 |
