Old 03-02-2015, 23:01   #1 (permalink)
Member: 220595
Thanks Meter: 355
how to solve this issue ? mt6572 S5 clone g900f
Info log
Chinese Miracle II  [MTK module] v 1.14
Operation : Check / Read Info [ v1.14 ]
Wait for phone...
Phone found! [ 179 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8C00
BB_CPU_SB : 0000
BB_CPU_NM : [MediaTek] MT6572_S00
Processing BROM stage
BLVersion : 0x01
SecCfgVal : 0x00000000
BromVersion : 0xFF
BLVersion : 0x01
Preloader Status : Alive
Processing DA stage
DA Select done , sending
NAND_ID : 000100BC009000550056000100BC0000
eMMC_ID : 00000000000000000000000000000000
DA Stat : v4.2 on BBID : 0x88
DA Sent. Configure setting now ...
DA started successuflly
NAND FlashIC initialized
[NAND] : FLASH_VEN : 0x0094 , [Spansion] KEM51200_NADGSBXM2C32
[NAND] : FLASH_DIE : 0001 00BC 0090 0055 0056 0001 00BC
[NAND] : FLASH_LEN : 0x20000000
INT RAM    : 0x00020000
EXT RAM    : 0x10000000
BOOT TYPE  : NAND_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
NAND : Detecting structure now... Please, wait.
NAND : Structure detect done [31]
[AP] : Initial info read Ok!
Done!
Elapsed: 00:00:57
Reconnect Power/Cable!
now I try to format UDA because phone is stuck at BOOT logo...
Operation : Format FileSystem [ v1.14 ]
Wait for phone...
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8C00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Error read initial info , blank flash or wrong settings?
Operation Failed
Elapsed: 00:00:06
any suggestion ?
The Following User Says Thank You to yurais For This Useful Post:
Old 03-02-2015, 23:04   #2 (permalink)
Member: 220595
Thanks Meter: 355
i found this file searching for a flash file, it has no extension, so I dont know if it is possible to write, and which tool was it designed for ?
Download Galaxy S5 Mt6572 Sm G900f YFg-WNYYba - NextWap.Net
Old 03-03-2015, 05:54   #3 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Better not try write unknown things.
I see in logs wrong operations : Read Info, Format. In this way it will work.
The Following User Says Thank You to JayDi For This Useful Post:
Old 03-03-2015, 06:00   #4 (permalink)
Member: 703094
Thanks Meter: 23
try another files sir.............
The Following User Says Thank You to pogs1962 For This Useful Post:
Old 03-03-2015, 14:53   #5 (permalink)
Member: 220595
Thanks Meter: 355
Well, nobody has a good file ?
and there is no anything wrong on my procedure, I read info and then try to format. I also tried or NAND INIT options.
Old 03-14-2015, 21:30   #6 (permalink)
Member: 220595
Thanks Meter: 355
the flash file I downloaded was intented for EMMC phone , and mine is NAND, so, still searching for correct flash file
Page generated in 0.16186 seconds with 8 queries
