06-09-2010, 09:55 | #1 (permalink) |
Freak Poster Join Date: Aug 2008
Member: 846872 Status: Offline Thanks Meter: 109 | How to unlock E66 chinese It's the first time I'm using my Infinity Box, and have got an E66 Chinese, but don't know witch cable to use. I've got the standard cables that comes with the box. Modell E66 TYPE: KT257 |
06-09-2010, 12:47 | #2 (permalink) |
Freak Poster Join Date: Dec 2006 Location: Khartoum-Sudan
Member: 420318 Status: Offline Sonork: 100.1661057 Thanks Meter: 65 | did u have PinFinder?? if yes choose the right cable for your phone then search for it with pin finder u can find Pind finder guide some where here , if u found the pinout ( Rx , Tx ) then from Chinese Miracle do SP-Unlock u can check here also: http://forum.gsmhosting.com/vbb/f425...2/#post5926184 |
06-09-2010, 18:15 | #3 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,531 | hello! 1. please post connector type. 2. are you sure that this is mt62xx MCU based phone? tip: you can check this by typing *#0044# and pressing green (send) button. if you will see "language set: english"- you can be sure, that this phone is supported by Infintiy software 3. do you have Pinfinder? tip: you can check this by typing *#0044# and pressing green (send) button. if you will see "language set: english"- you can be sure, that this phone is supported by Infintiy software waiting answer to all 3 questions |
06-09-2010, 23:09 | #4 (permalink) | |
Member: 846872 Status: Offline Thanks Meter: 109 | Quote:
2. I've to try it later on I don't have access to the phone now. but I think it is. 3. I don't have pinfinder. | |
09-01-2010, 03:10 | #6 (permalink) |
Freak Poster Join Date: Mar 2008 Age: 44
Member: 725927 Status: Offline Thanks Meter: 48 | Sr i have this model Sr i have this model in my hand its supported by infinity by tested *#0044# but i can find the pinout in pinfinder, conector is L05B. How is the measure voltaje procedure? BR |
09-01-2010, 11:14 | #7 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,531 | Quote:
you must search for test points on PCB. here is how this can be done: http://forum.gsmhosting.com/vbb/5530460-post2.html | |
09-06-2010, 23:22 | #10 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,531 | hello! you have marked test points. what could be easyer?!? solder 3 wires. box Tx pin to phone URX box Rx pin to phone UTX box GND pin to phone GND thats it! |
09-07-2010, 22:28 | #12 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,531 | hello! if you sure that phone is MT62xx MCU- then it should connect. can you make photo of rj45 cable with connector visable? i will check if you are using correct pins. picture must be in good quality. same as mine here: http://forum.gsmhosting.com/vbb/f296...-cable-386780/ so i could count pins and see colurs |
10-25-2010, 19:28 | #14 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,531 | hello! can you make photo of rj45 cable with connector visable? i will check if you are using correct pins. picture must be in good quality. same as mine here: http://forum.gsmhosting.com/vbb/f296...-cable-386780/ so i could count pins and see colurs |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
