Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2004 Location: India Age: 32
Member: 50805 Status: Offline Thanks: 77
| How to use Pinout finder for dual CPU phone i've spice D80 Dual GSM Pinout finder work fine here is detail but not able to work with second CPU...(phone restarting in master sim, slave sim working fine) Code: software version: 1.06 cable type: 2x5 (L10C) platform: MT6205, MT6217-MT6228 searching adapter at COM10... adapter found, version: 2000 pins: 10, plain power cycles: 1 activation cycles: 7 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... 19200 CPU: MT6219 result: Rx:5 Tx:4 time required: 25 sec Power On ! Code: COM10 [VCP1] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: reset Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6219:8B02:8B01]... CPU: MT6219 high speed boot enabled CPU: MT6226MA detected chip: 0031:B3C1:F356 boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22202200:2AEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:2AEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 921600 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E22202200:2AEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:2AEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: P67_PCB01_GPRS_MT6226M_S01.GD1_M735301SB_MP.BIN ver. sw2: GD1.M735301SB.MP, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: 01227E22202200:2AEA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... flash: 01227E22202200:2AEA0000000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Write Done Finalization... formatting... flash: 01227E22202200:2AEA0000000000 Finalization Done Finished, time used: 120 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
| | #4 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Sep 2005 Age: 48
Member: 185776 Status: Offline Thanks: 20
| If u want to know second cpu pinout,in pin out finder use near left side button of SET button,and try FIND IT,Sure u will get second cpu pin out. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| how to use mx key on amd cpu? | neo_7 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 19 | 12-22-2010 09:23 |
| how to use pin finder check it | goherabbas | Chinese Models & Cloned Phones | 4 | 11-17-2009 08:01 |
| how to use pin finder as cable adapter? | vazgsm | Infinity-Box | 4 | 10-26-2008 13:57 |
| spiderman box also pinout finder for gsm-cdma phones not only chinese | AYMAN SHAMAYLH | SpiderMan | 21 | 10-19-2008 02:24 |
| How To Use Video Function For Apple I-phones | Nasmi | iPhone ,iPod & iPad (Apple Inc. Products) | 4 | 04-04-2008 00:36 |
