11-01-2012, 14:08 | #1 (permalink) |
No Life Poster Join Date: Nov 2005 Location: UNLOCKING IN GENERAL:) Age: 51
Member: 196126 Status: Offline Thanks Meter: 80 | Huawei G7300 bricked After Im flashing modified firmware and its porering on but cant use it what to do customer is leaving in the morning ??Pls advice PS During flash get error incorrect bootloader version ill post a log later Last edited by radez; 11-01-2012 at 14:16. |
11-01-2012, 15:15 | #2 (permalink) |
Member: 196126 Status: Offline Thanks Meter: 80 | this is a log editor corrected file now phone is powered on COM6 [VCP2] selected module v4.27 Device: _Autodetect MT6228-6276 NAND Checking data, wait... Action: write flash NAND write: Firmware editor_corrected_BYD36_10A_PCB01_GPRS_MT6236_S00.U 5_6PY01V01_09__firmware_20121031-174332.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nfi area detection... nfi scat area detected (3 areas) nfi area detection (3 cores) finished: Ok interface: BROM_DLL_v3.1108.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6236:8A02:8A00 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0055]: 0098:00B100900055 [TOSHIBA] TC58NYG0S8C chip size: 128Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 10 address cycles: 04 internal RAM size: 00018000 external RAM: absent done Set baudrate (921600)... done interesting cpu type found: 6236:8A02:8A00 ram test (40000000)... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 04000000/04000000 firmware size: 64Mb ffs size: 64Mb detect sec ro... error:0BF9:S_DA_HANDSET_SEC_INFO_NOT_FOUND detect custom parameters... error:0401:S_CUST_PARA_NOT_SUPPORTED detect project-id... project-id: U5.6PY01V01.05 detect NAND info... number of areas/bytes to read: 1:00080000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... warning: core offset is not detected nfi area detection (0 cores) finished: failed warning: ffs can not be detected TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: BYD36_10A_PCB01_GPRS_MT6236_S00.U5_6PY01V01_05.BIN project-id: U5.6PY01V01.05, 00000000 code offset: 00000000 rom info structure: [standard] type (07) TCL-ID is absent ===> done nfi area detection... nfi scat area detected (3 areas) nfi area detection (3 cores) finished: Ok startup code area #1 check... done number of cores: 3 loading files... number of areas: 3 done write... write bootloader... . . . . write core... write core... Disconnect... done Finished, time used: 12 min 11 sec Remove/Install battery now ! |
11-01-2012, 15:34 | #3 (permalink) |
Member: 196126 Status: Offline Thanks Meter: 80 | After firmware from support phone is dead what to do now? COM6 [VCP2] selected module v4.27 Device: _Autodetect MT6228-6276 NAND Checking data, wait... Action: write flash NAND write: Firmware Huawei-G7300_BYD36_10A_PCB01_GPRS_MT6236_S00.U5_6PY01V01_ 05_2011-09-15_En_Pt.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nfi area detection... incorrect ext bootloader signature: 10B501F0 bootloader version: BYD36_10A_BOOTLOADER_V005_MT6236_U5_6PY01V01_05.bi n nfi area detection (3 cores) finished: Ok interface: BROM_DLL_v3.1108.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6236:8A02:8A00 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0055]: 0098:00B100900055 [TOSHIBA] TC58NYG0S8C chip size: 128Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 10 address cycles: 04 internal RAM size: 00018000 external RAM: absent done Set baudrate (921600)... done interesting cpu type found: 6236:8A02:8A00 ram test (40000000)... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 04000000/04000000 firmware size: 64Mb ffs size: 64Mb detect sec ro... error:0BF9:S_DA_HANDSET_SEC_INFO_NOT_FOUND detect custom parameters... error:0401:S_CUST_PARA_NOT_SUPPORTED detect project-id... project-id: U5.6PY01V01.09 detect NAND info... number of areas/bytes to read: 1:00080000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... warning: core offset is not detected nfi area detection (0 cores) finished: failed warning: ffs can not be detected TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: BYD36_10A_PCB01_GPRS_MT6236_S00.U5_6PY01V01_09.BIN project-id: U5.6PY01V01.09, 00000000 code offset: 00000000 rom info structure: [standard] type (07) TCL-ID is absent ===> done ==================== New firmware found (v.4.27, database date: 08.05.2012): BYD36_10A_PCB01_GPRS_MT6236_S00.U5_6PY01V01_09.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare ? Secure Data Logistics or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== nfi area detection... incorrect ext bootloader signature: 10B501F0 bootloader version: BYD36_10A_BOOTLOADER_V005_MT6236_U5_6PY01V01_05.bi n nfi area detection (3 cores) finished: Ok startup code area #1 check... done number of cores: 3 loading files... number of areas: 3 done write... write bootloader... . . . write core... write core... Disconnect... done Finished, time used: 12 min 27 sec Remove/Install battery now ! |
11-02-2012, 11:39 | #4 (permalink) |
Member: 196126 Status: Offline Thanks Meter: 80 | Thread closed Ive edited file from fullflash without changing anything with LPE and flash it back finally no russian lp in this phone after changing dictionary to russian some icons disapeared from menu the conclusion is LPE bug but the second thing is the firmware from support is not working |
