03-07-2017, 07:14 | #1 (permalink) |
Freak Poster Join Date: Apr 2006 Location: MVR
Member: 266180 Status: Offline Thanks Meter: 25 | Huawei y336-u02 unlock help 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 26 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! Boot failed! Reconnect Power/Cable! Any help i would real apriciate |
03-09-2017, 10:20 | #4 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Uganda Age: 45
Member: 96478 Status: Online Sonork: 100.1674604 Thanks Meter: 1,420 | No solution for SP-unlocking check here http://forum.gsmhosting.com/vbb/f296...lp-me-2157961/ |
03-09-2017, 19:14 | #5 (permalink) | |
Member: 266180 Status: Offline Thanks Meter: 25 | Quote:
03-27-2017, 11:42 | #6 (permalink) |
Member: 266180 Status: Offline Thanks Meter: 25 | Any one has got solution with this huawei? i have flahs it no luck now i try to sp unlock still no luck here is the log of sp unlock ==== Wait for phone... Phone found! [ 383 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! Detected eMMC Flash , Structure detect Ok! Checking Structure ... SimLock state : Not Locked! Nothing to do! Elapsed: 00:00:27 Reconnect Power/Cable! |
07-14-2017, 13:42 | #7 (permalink) |
No Life Poster Join Date: Dec 2003 Location: Karachi Pakistan Age: 38
Member: 47321 Status: Offline Sonork: 100.54032 Thanks Meter: 497 | Phone found! [ 159 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! Detected eMMC Flash , Structure detect Ok! Checking Structure ... SimLock state : Not Locked! Nothing to do! Elapsed: 00:00:34 Reconnect Power/Cable! |
