01-05-2009, 08:59 | #1 (permalink) |
Insane Poster Join Date: Nov 2008
Member: 895274 Status: Offline Thanks Meter: 4 | i can't format N95-8g china by infinity i can not format nokia N95 8g by infinity ? which cable can i use ? i try many times but i can not .... thanks alot |
01-05-2009, 22:06 | #4 (permalink) | |
No Life Poster Join Date: Jun 2006
Member: 303402 Status: Offline Thanks Meter: 346 | Quote:
better show better answer, without picture, the answer is just a guess | |
01-05-2009, 22:09 | #5 (permalink) |
No Life Poster Join Date: Mar 2008 Location: infinity-box
Member: 720034 Status: Offline Thanks Meter: 213 | One more explanation: There are a lot of different "Chinese" phones with the same name but absolutely different hardware exist on market. Example: exist at least 30 "Chinese" phones with name "N95", at least 20 models "N73" etc. but all models has difference in hardware, different bottom connectors, different pinouts and and has different firmware, so it's impossible to give any advice about phone pinout only by phone name. So we recommend you to include the next information in your request regarding pinout: 1. detailed description of model: brand name, model name, complete text from phone back label, any other marks that you can find on phone cover 2. phone CPU chip name 3. phone PCB photo (Rx/Tx/Gnd test-points may exist on phone PCB) 4. attach phone photo 5. attach phone bottom connector photo 6. include information about Gnd and Charge pins on phone bottom connector After you have this information prepared, you can find pinout by yourself more easy than before, just check the next detailed description how to get pinout for your model: 1. use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297 2. if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle\ 3. if not helps, please read: http:///vbb/showpo...36&postcount=7 4. if not helps, please read: http:///vbb/showthread.php?t=433447 Universal solution for pinout detection: http://www.infinity-box.biz/index.ph...infinder&lg=en |
01-07-2009, 15:02 | #6 (permalink) |
Member: 895274 Status: Offline Thanks Meter: 4 | thanks alot mr sajidali can you explin detailly how i can use pinfinder to do that ? i have infinity box and pinfinder for three mounth but do not now how i can use pin finder i read alot decumentaion but i face problem to use pinfinder i used L5A pinfinder cable but i can't thanks for all |
01-07-2009, 19:26 | #7 (permalink) |
Member: 720034 Status: Offline Thanks Meter: 213 | @awod81 If your phone has 5 pins only there is a very big chance that Rx and Tx is inside phone, located at phone PCB. open phone and try to find test points with RX and TX marks. |
N95-8G china phone after format dead help! | alvinteh | SpiderMan | 5 | 01-29-2010 03:01 |
I can't Format n95 China Help | mickervin | SpiderMan | 4 | 06-28-2009 05:43 |
n95 8g china need your advice | rogue_16 | Chinese Models & Cloned Phones | 0 | 02-25-2009 11:14 |
I can't unlock N95 8G any problem on server | KHJAMAL | Universalbox | 12 | 12-17-2008 10:29 |
plz how format n95 8g with spiderman ?what cable to use | muhned | SpiderMan | 3 | 10-11-2008 22:29 |
