12-23-2010, 07:53 | #1 (permalink) |
Banned Join Date: Dec 2009 Location: india
Member: 1178099 Status: Offline Sonork: 143 Thanks Meter: 3 | i need china e71 flash file Code: COM6 [VCP1] selected module v3.22 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection disabled Action: read/check information ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:7DB7:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung D 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung D 16Mb otp offset: 00000000 detecting chip #02 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung D 16Mb otp offset: 00000000 detecting chip #03 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung D 16Mb otp offset: 00000000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung D 16Mb otp offset: 00000000 Warning: probably flash chip is empty, erased, incorrectly flashed or damaged ! What to do: 1. go to software "Settings" page 2. set "Advanced chip detection method" box CHECKED ! 3. make flash write operation If still no luck: send mail to support ([email protected]) with detailed description of problem, attach the next files in your e-mail: 1. C:\Program Files\InfinityBox\ChineseMiracle\operation.log 2. C:\Program Files\InfinityBox\ChineseMiracle\cfi_xxxx_xxxx.bin detecting chip #01 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung D 16Mb otp offset: 00000000 it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: - old firmware type w/o rom info information - empty (completely or partially erased) flash chip - damaged firmware - damaged hardware (bad soldered or damaged flash chip) > if phone works fine just ignore this warning < detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset assigned: 00E00000 flash: EC257E25082501:FFFFFF00000000 checking area [00000000]: 00080000-00FFFFFF... Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs/eeprom address selected by user detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF firmware area: 00000000-00DFFFFF detecting ffs/eeprom structure pass 1... ........................................................ ffs/eeprom: can't detect record name location error: ffs/eeprom detection failed: element #1 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished detecting firmware version... ................................................................ ................................................................ done warning: can not detect firmware version if software freez: make "Find firmware version (slow process)" unchecked and repeat operation. detecting firmware build... ................................................................ done detecting product-id... ................................................................ done detecting languages... ................................................................ error: can't detect language parameter #1 warning: can not detect language names if software freez: make "Find language names (slow process)" unchecked and repeat operation. Finished, time used: 1 min 28 sec Remove/Install battery now ! |
12-24-2010, 18:17 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! as you can see in log- software version can not be detected. you can search by model name, but this will return many different options. you must try each file one by one. Best way is to disassemble phone and search for short verision code printed on PCB. usually it is located near or under LCD. post it here, we will try to advise correct flash file |
01-22-2011, 06:48 | #3 (permalink) | |
Member: 1178099 Status: Offline Sonork: 143 Thanks Meter: 3 | help me Quote:
SN : SN100 2010060400122 SV : SN100_23D_VER_1.3_K2371_cak | |
need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 2 | 03-24-2017 16:24 |
needed pinout for carkit(N61xx) | mobileinfo | Nokia Hardware & Hardware Repair | 2 | 07-23-2013 02:41 |
need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-26-1999 11:35 |
