Unlock Server
Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Infinity-Box > Chinese Miracle & PinFinder
Old 08-05-2009, 19:08   #1 (permalink)
ZIYAAD STRYKER's Avatar
Member: 175945
Sonork: ziiyyaad
I need this firmware!!!
TAIBO25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_08_ _ffs_20090805-212747.B0E.bin
PLEASE HELP!!!
Old 08-05-2009, 19:11   #2 (permalink)
Member: 175945
Sonork: ziiyyaad
COM22 [VCP0] selected
module v2.84
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: write NOR flash
"smart write" active
write: Firmware
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
ffs/eeprom backup enabled, it may takes several minutes !
Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A03:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:B403:0008
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: EC257E25082501:18E59F00000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
Set baud ...
230400
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
device parameters autodetection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area (code #1) is Ok
security area (code #1) backup saved: G:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.2B9F4AB1.[TAIBO25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_08. BIN_2A7D43A7].rpl
New firmware detected (v.2.84, database date: unknown):
This firmware is missing in support area. If this phone is good and working:
- make "Read full flash" operation
- send "system_log_..." file to support: mt62xx@gmail.com
- send flash backup files to support: mt62xx@gmail.com
- include in your e-mail full text from phone back label (phone name etc.)
identification#1 detection finished
device-id: 2B9F4AB1
identification#1 protocol ver: 04
ver. sw 1: TAIBO25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_08. BIN
ver. sw 2: MAUI.06B.W07.08, 58BC82D5
ffs offset/size: 00E00000/00200000
detect device identification#2...
detect device identification#2 finished
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
checking area [00000000]: 00000000-00FFFFFF...
ffs/eeprom found near: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
reading: TAIBO25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_08_ _ffs...
file saved: G:\Program Files\InfinityBox\ChineseMiracle\TAIBO25_06B_PCB01 _GPRS_MT6225_S00.MAUI_06B_W07_08__ffs_20090805-212747.B0E.bin
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
detecting security area (code #2)...
security area (code #2) is absent
file saved: G:\Program Files\InfinityBox\ChineseMiracle\backup_security\T AIBO25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_08__ system_log_2B9F4AB1_2A7D43A7_20090805-212810.B0X.bin
Area: Firmware
Write: Firmware
jump to next chip: 01
Write: Firmware
Write Done
Finalization ...
Finalization Done
file saved: G:\Program Files\InfinityBox\ChineseMiracle\backup_security\T AIBO25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_08__ system_log_2B9F4AB1_2A7D43A7_20090805-215956.B0X.bin
Finished, time used: 2143 sec
Remove/Install battery now !
Old 08-05-2009, 19:24   #3 (permalink)
Member: 175945
Sonork: ziiyyaad
Is there any compatible flash i can put in the phone pleasae?
Old 08-05-2009, 19:55   #4 (permalink)
Member: 175945
Sonork: ziiyyaad
module v2.84
write: Firmware
skip: Customization
skip: Eeprom/ffs
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
status: FF
Boot Done
Initialize ...
flash: EC257E25082501:B6000000000000
Initialize Done
Set baud ...
230400
Set baud Done
it's time to stop: B6D90000000000000000000000B66D6F0000000000000000
detection phase #2...
warning: identification#1 information not found, possible reasons:
.old firmware type w/o identification#1 data
.damaged firmware
.damaged hardware
if phone works fine just ignore this warning
standard ffs/eeprom offset assigned: 00E00000
ffs/eeprom found near: 00C00000
Detected ffs/eeprom address is non-standard: 00C00000
Posible reasons:
1. ffs/eeprom is Ok but address is non-standard
2. ffs/eeprom is damaged and can't be detected
3. ffs/eeprom is Ok but detected incorrectly (f.e. unknown ffs/eeprom structure)
If you are not sure that detected address is correct:
1. press "NO" (and select standard address or terminate current operation)
2. make full flash backup for emergency case
3. repeat required operation
Are you sure that detected ffs/eeprom address is correct ?
autodetected ffs/eeprom address confirmed by user: 00C00000
ffs/eeprom size: 00400000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00C00000-00FFFFFF
reading: _ffs...
file saved: G:\Program Files\InfinityBox\ChineseMiracle\_ffs_20090805-222814.B0E.bin
Write ...
.damaged firmware
.damaged hardware
security area (code #1) calculation...
done
Area: Firmware
Write: Firmware
Write Done
Finalization ...
Finalization Done
Finished, time used: 1567 sec
Old 08-05-2009, 22:21   #5 (permalink)
Member: 148515
hello!
nothing even similar in our collection, sorry
Old 08-07-2009, 19:03   #6 (permalink)
Member: 175945
Sonork: ziiyyaad
Model is: Gaoxinqi t838 i badly need it!!!
Is it possible to remove bad software?
Old 08-07-2009, 19:34   #7 (permalink)
InfinitySupport's Avatar
Member: 130995
Hello,
Did you tried to make "repair bad software" operation ?
What is the results ?
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 08-08-2009, 17:22   #8 (permalink)
Member: 175945
Sonork: ziiyyaad
no not yet tried!!! i will try and post results!!!
need this firmware for z720 kwitek Samsung Flashers, Software, Firmware. 2 03-25-2008 01:01
i need this firmware on our support please tsarkh HWK 1 05-09-2007 21:07
i need this firmware on our support please tsarkh Universalbox 2 05-05-2007 12:33
need this firmware R4515_G_08BD.2AR for V3R vladic100 P2k Series 12 01-19-2007 22:07
i need this firmware asap D500JVED2 officer.doofy SWIFT Platform 0 02-20-2006 22:26
Page generated in 0.48427 seconds with 11 queries
