02-22-2009, 16:11 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,536 | hello! please post connector type. are you sure that this is mt62xx MCU based phone? tip: you can check this by typing *#0044# and pressing green (send) button. if you will see "language set: english"- you can be sure, that this phone is supported by Infintiy software |
02-24-2009, 17:56 | #6 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,536 | hello! 1. set multimeter to voltage measuring. 2. check bettery voltage, it should be more than 3,7volts 3. set one multimeter probe to some grounded phone part (if you cant find grounded part outside phone- you need to take out small thin wire from negative battery terminal) 4. with second probe touch one by one all phone pins (phone battery attached) (to get better result i would advice to set needle on the end of second probe) memorise pins with voltage between 2,7-2,9volts. those are tx/rx |
02-14-2010, 06:37 | #7 (permalink) |
Freak Poster Join Date: Jan 2005 Location: Tren Selular TegaL Age: 45
Member: 104571 Status: Offline Thanks Meter: 19 | got mixcon M88, find rx tx by using ur method. but phone cant boot. try to read also no respond. but can find rx tx using pinfinder. weird.... do you thing its flash chip fault? regards TS |
02-14-2010, 09:53 | #8 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,536 | Quote:
Sorry, i have to re-ask. you can find minout by pinifnder, but can not by voltage measuring method? | |
Need help I need pinout for this chinese phone | cayton_l | Infinity-Box | 9 | 12-03-2008 19:22 |
I need help. need pinout for 6060v RH-97 | IkaMazini | HWK | 1 | 07-26-2008 07:22 |
need pinout for flashing LG 200, 510,600... | doctorvatson | LG | 1 | 10-07-2006 08:54 |
need pinout for Nokia 3520 or 3560. very need | sp-lox | Nokia CDMA | 1 | 12-30-2003 20:59 |
