09-18-2010, 12:05 | #1 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Latvia-Riga Age: 44
Member: 88823 Status: Offline Thanks Meter: 26 | i9+++ dead COM1 [Serial2] selected module v3.22 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: repair security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:9E03:0008 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E223D2200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x008000 01FEx020000 0004x008000] 64Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 01227E223D2200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x008000 01FEx020000 0004x008000] 64Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 total flash region size: 04000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (05) TCL-ID is absent rom info detection finished rom info ver: 05 sw version: NEOTEL25_08B_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_08B _W08_52_MP_V22_F2.BIN project-id: MAUI.08B.W08.52.MP.V22.F2, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [standard] type (05) TCL-ID is absent detecting startup code area #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... startup code area #2 is absent sec info (fast) detection... searching sec info#1... . search sec info#1 finished error: incorrect ffs address range Finished, time used: 1 min 14 sec Remove/Install battery now ! |
09-19-2010, 02:37 | #2 (permalink) |
Freak Poster Join Date: Jan 2009
Member: 950629 Status: Offline Thanks Meter: 105 | rom info structure: [standard] type (05) I think You don't need to repair the security. Please do this.. Do you have a backup .. then Full erase the phone and write the backup. and if not solved try with smiler firmware versions. if not solved check Hardware. (Specially LCD part) and also check this Why I don't need to fix security |
09-19-2010, 11:43 | #3 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! lets try to find required Original software version. open operatio.log file and find first operation with this phone. there must be available phone's original version. post this log here, we will advice correct flash file |
09-19-2010, 11:48 | #4 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: pakistan
Member: 334999 Status: Offline Thanks Meter: 225 | here is my correct version plz give me flash file Quote:
KINGSTAR25_GEMINI_08B_PCB01_GPRS_MT6225_S00.MAUI_0 8B_W08_52_MP_V7_F7__ffs_20100720-130326.B0E thanks | |
09-19-2010, 18:41 | #5 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! seems that you used wrong file. use one of these: flashfiles/ChineseMiracle/_MT6225/32m/KINGSTAR25_GEMINI_08B_PCB01_GPRS_MT6225_S00.MAUI_0 8B_W08_52_MP_V7_F7_32m_En_Ru_Gr_Nl_Fr_Es_It_Sv_No_ Pl_De_Ml_Id_Th_Vn_Cn_Tr_Farsi_Pt_Cz_Cn_He_Ar.B0M.b in flashfiles/ChineseMiracle/_MT6225/32m/KINGSTAR25_GEMINI_08B_PCB01_GPRS_MT6225_S00.MAUI_0 8B_W08_52_MP_V7_F7_32m_w_eeprom.B0M.bin flashfiles/ChineseMiracle/_MT6225/32m/KINGSTAR25_GEMINI_08B_PCB01_GPRS_MT6225_S00.MAUI_0 8B_W08_52_MP_V7_F7__iphone--i9+++_32m_En_Ru_Gr_Nl_Fr_Es_It_Sv_No_Pl_De_Ml_Id_T h_Vn_Cn_Tr_Farsi_Pt_Cz_Cn_He_Ar.B0M.bin flashfiles/ChineseMiracle/_MT6225/32m/KINGSTAR25_GEMINI_08B_PCB01_GPRS_MT6225_S00.MAUI_0 8B_W08_52_MP_V7_F7__SciPhone-i9+++_32m_En_Ru_Gr_Nl_Fr_Es_It_Sv_Pl_De_Ml_Id_Th_V n_Cn_Tr_Farsi_Pt_Cn_He_Ar.B0M.bin |
Repaired dead phone without backup | Prodigal | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-29-2011 11:26 |
HELP Dead 5130 v5.00 | N.Schmetz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 03-08-2011 04:51 |
help! Dead 5110 v5.30 | aklishin | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 04-04-2001 11:56 |
nokia 5110 dead | alpha | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 02-28-2001 11:59 |
6150 V5.20 WANTED --- DEAD OR ALIVE --- IT'S BETTER ALIVE ! ;))) | tcamilo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 12-19-1999 22:30 |
