03-07-2009, 22:09 | #1 (permalink) |
No Life Poster Join Date: Apr 2003
Member: 26692 Status: Offline Thanks Meter: 51 | i9 iphone cant writhe imei pin 1 have 4.27 vots and infinity box too.i dont find any diode in my infinity for cut.(that manual is for very old boards only.my infinity is from unlockcellular and is rectangular short black box). y try with fully chargued battery too and cant make job becouse never conect. i had worked many others iphones like iphoe,p168 etc and all is ok.only in these model is the problem. |
03-08-2009, 01:06 | #2 (permalink) |
Member: 26692 Status: Offline Thanks Meter: 51 | i begin tryng to writhe imei but now i use the test point cable of rocker box(zulea not legija tp cable) for pwer the phone and sw tray to conect but was unsusefull. butttttttttttttttttttt...... i use the same boxes:infinity in com 8 .next pinfinder and tp cable like power and using cracked other chinese box imei was writed in pone in a second. so infinity you have problem for conect these models of iphones in pwer on mode.i have pics and logs |
03-08-2009, 22:59 | #3 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! 4,27 is volatge which was cut by diode. you just must find it where it is located. after you remove it- pinfinder work will increase dramaticaly |
03-09-2009, 19:33 | #4 (permalink) | |
Member: 26692 Status: Offline Thanks Meter: 51 | Quote:
sorry i cant find any diode.you produce it not me ,then please post were is located. if there are many versions of boxes you must have diagrams or pic each one i suposse. | |
M7600 - Cant repair IMEI - Cant read Security data | marquesphelder | Z3X-Team Products | 9 | 08-06-2010 07:14 |
2 pcs iPhone 2G No IMEI, No ICCID, Cant Make & Receice Calls | dannyogolo | iPhone 2 / iPhone 3G / iPhone 3GS | 8 | 08-01-2009 20:05 |
iphone cant recive call on standby | kasra | iPhone 2 / iPhone 3G / iPhone 3GS | 8 | 05-31-2008 19:30 |
iphone cant make call from keypad | quantumgsm | iPhone 2 / iPhone 3G / iPhone 3GS | 0 | 11-29-2007 21:14 |
v70 cant unlock cant change imei | click190 | Motorola P2k | 0 | 06-24-2003 09:50 |
