01-15-2009, 06:23 | #1 (permalink) |
Major Poster Join Date: Mar 2007
Member: 471808 Status: Offline Thanks Meter: 5 | Infi team help me COM17 [VCP0] selected module v2.74 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:A503:000C boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98004900000002:FFFFFF00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:FFFFFF00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud ... 230400 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 98004900000002:FFFFFF00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb Warning: probably flash chip empty, erased, incorrectly flashed or damaged. What to do: 1. go to software "Settings" page 2. set "Advanced chip detection method" box UN-CHECKED ! 3. make flash write operation If still no luck: send mail to support ([email protected]) with detailed description of problem, attach the next files in your e-mail: 1. C:\Program Files\InfinityBox\ChineseMiracle\operation.log 2. C:\Program Files\InfinityBox\ChineseMiracle\cfi_xxxx_xxxx.bin detecting chip #01 in region #00... flash: 98004900000002:FFFFFF00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. ............................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset assigned: 00E00000 flash: 98004900000002:FFFFFF00000000 checking area [00000000]: 00000000-00FFFFFF... Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs/eeprom address selected by user detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: eeprom... file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom_20090114-182437.B0E.bin flash: 98004900000002:FFFFFF00000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... formatting... flash: 98004900000002:FFFFFF00000000 Finalization Done Finished, time used: 252 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! error: wrong file size[0x00000200]: C:\Program Files\InfinityBox\ChineseMiracle\cfi_0098_0049_000 0_0002.bin |
01-15-2009, 09:24 | #2 (permalink) | |
Freak Poster Join Date: Sep 2006 Location: Indonesia
Member: 355635 Status: Offline Thanks Meter: 53 | Quote:
u have warning before do something just follow instruction to revive u phone just flash again with backup file, iff u read flash first before do format operation regards notgood | |
The Following User Says Thank You to notgood For This Useful Post: |
FOURIOUS TEAM HELP ME...furiousgold dongel gavin error ..plz help me | musa_bahi | FuriousGold | 1 | 03-29-2009 14:53 |
UFS TEAM help me | sos-gsm | UFS2 + UFS3-Tornadoflasher | 0 | 08-14-2005 20:13 |
fighter team help me | saeed-gsm | Cruiser Suite | 6 | 06-01-2005 12:51 |
