Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Infinity-Box > Chinese Miracle & PinFinder
Old 02-09-2008, 00:07   #1 (permalink)
Member: 583680
Infinity Box Pin-finder adapter test report
Hello!
5 china phone models tested today with new Pin-finder adapter successfuly
Models:
Vertu_Narnia_i-70
searching adapter at COM4...
adapter found, version: 2000
Serial No: 00010E01******************************xx
pins: 8
power cycles: 1
activation cycles: 4
power control: via adapter
power-off delay: 20
start Rx/Tx: 1/1
Loading configuration...
Initializing...
Press and HOLD phone Power button now !
detecting pins...
CPU: MT6226
result: Rx:2 Tx:3
time required: 10 sec
Power On !
Nckia M5700+
Serial No: 0001***************************xx9
pins: 18
power cycles: 1
power-off delay: 20
start Rx/Tx: 1/1
Initializing...
detecting pins...
CPU: MT6226
result: Rx:12 Tx:10
time required: 97 sec
Power On !
Anycool F818
Serial No: 0001*********************xx9
pins: 18
power cycles: 1
power-off delay: 20
start Rx/Tx: 1/1
Initializing...
detecting pins...
try#2/3...
try#2/3...
try#2/3...
try#2/3...
try#2/3...
try#2/3...
try#2/3...
CPU: MT6225
result: Rx:7 Tx:9
time required: 52 sec
Power On !
Also successfuly found pinouts for Anycool F818,Anycool T808,XpresMusic 5610S.
After pinout found I opened Chinese Miracle 2.26 and do all the operations like read general info,repair imei,read full and write flash without disconnecting phone from Pin-finder adapter.
!!!!!!!!!!!Thanks to Infinity team!!!!!!!!!
Best wishes!!!
ezzis
The Following 14 Users Say Thank You to ezzis For This Useful Post:
Old 02-09-2008, 14:17   #2 (permalink)
bestncheap's Avatar
Member: 19785
test today 10pin N328
searching adapter at COM10...
Serial No:
pins: 10
power cycles: 1
activation cycles: 10
power-off delay: 20
start Rx/Tx: 1/1
Initializing...
detecting pins...
CPU: MT6226
result: Rx:10 Tx:8
time required: 72 sec
Power On !
BnC
The Following 6 Users Say Thank You to bestncheap For This Useful Post:
Old 02-09-2008, 17:44   #3 (permalink)
Member: 583680
Sooy Ersson K530i
Sooy Ersson K530i today
Serial No: 00010E0*********************************xx9
pins: 18
power cycles: 1
activation cycles: 5
power-off delay: 20
start Rx/Tx: 1/1
Initializing...
detecting pins...
CPU: MT6226
result: Rx:12 Tx:10
time required: 106 sec
Power On !
The Following 8 Users Say Thank You to ezzis For This Useful Post:
Old 02-09-2008, 18:09   #4 (permalink)
zinoubinabil's Avatar
Member: 84268
Sonork: 100.114149
Originally Posted by ahmertelecom View Post
where can i purchase this
dear friend,
it's very easy; check this link
http://www.infinity-box.biz/index.ph...infinder&lg=en
How to get it ?
Contact to:
support@infinity-box.biz
support@infinity-box.com
User manual with detailed description is here: http://www.infinity-box.biz/download..._PinFinder.pdf
br
Last edited by InfinitySupport; 02-10-2008 at 14:00. Reason: new e-mail and link added
The Following 4 Users Say Thank You to zinoubinabil For This Useful Post:
Old 02-09-2008, 20:53   #5 (permalink)
Member: 583680
Correct pinout found for totally dead ZT 8900
Model ZT 8900
phone condition:totally dead (MT6228)
pins: 12
power cycles: 1
activation cycles: 7
power-off delay: 20
start Rx/Tx: 1/1
Initializing...
detecting pins...
try#2/3...
try#2/3...
CPU: MT6228
result: Rx:3 Tx:10
time required: 26 sec
Power On !
The Following 3 Users Say Thank You to ezzis For This Useful Post:
Old 02-10-2008, 13:10   #6 (permalink)
bestncheap's Avatar
Member: 19785
Test Again N95 8GB CHINA
Serial No: *********************************x
pins: 10
power cycles: 1
power-off delay: 20
start Rx/Tx: 1/1
Initializing...
detecting pins...
CPU: MT6226
result: Rx:3 Tx:8
time required: 25 sec
Power On !
BnC
Old 02-10-2008, 13:49   #7 (permalink)
Member: 20069
Originally Posted by zinoubinabil View Post
dear friend,
How to get it ?
Contact to support@infinity-box.com
br
thanks for the link Bro now i'm sure this wonderfull thing will make jobs more easier for Infinity users.
The Following 4 Users Say Thank You to the_frightener For This Useful Post:
Old 02-10-2008, 14:14   #8 (permalink)
ABOUSHADY's Avatar
Member: 200717
Sonork: 100.1580056
good work by infinity
The Following User Says Thank You to ABOUSHADY For This Useful Post:
Old 02-10-2008, 14:21   #9 (permalink)
mvr
Member: 10541
to infinityhelp:
i am using the old usb direct infinity dongle, do i still need to use a unibox just to connect the pin finder adapter? or there is another way that i can use my dongle without a unibox? please enlighten us. thanks and more power!
wbr,
mvr
The Following User Says Thank You to mvr For This Useful Post:
Old 02-10-2008, 14:39   #10 (permalink)
harim_1981's Avatar
Member: 243961
Sonork: 100.1591654
good work...
but when it will reach india...
waiting,...any resellers...make it fast..
The Following User Says Thank You to harim_1981 For This Useful Post:
Old 02-10-2008, 14:48   #11 (permalink)
sayedhas's Avatar
Member: 420598
good work infinity good box
The Following User Says Thank You to sayedhas For This Useful Post:
Old 02-10-2008, 22:40   #12 (permalink)
InfinitySupport's Avatar
Member: 130995
Originally Posted by mvr View Post
to infinityhelp:
wbr,
mvr
Hello,
Currently it's need to use Unibox to connect adapter to it's RJ45.
But if you don't have Unibox you can use any other COM port cable, but you need to have Rx, Tx. Gnd and one additional wire connected to Adapter.
Please, check Appendix in our PinFinder UserManual to see "input RJ45" connector layout: http://www.infinity-box.biz/download..._PinFinder.pdf
The Following 4 Users Say Thank You to InfinitySupport For This Useful Post:
Old 02-10-2008, 23:39   #13 (permalink)
gsm5378's Avatar
Member: 650213
Sonork: 100.1581739:333
this done inifinityteam good but late then great person always come late
The Following User Says Thank You to gsm5378 For This Useful Post:
Old 02-11-2008, 06:14   #14 (permalink)
hanif007's Avatar
Member: 665441
Sonork: 100.1601130
good work infinity team carry on to do the best work
The Following 3 Users Say Thank You to hanif007 For This Useful Post:
Old 02-11-2008, 06:49   #15 (permalink)
alfox's Avatar
Member: 91411
Sonork: 100.1584444
wow im excited to have my own pin finder.let me check with my reseller and get my order.thanks infinity team.....
The Following User Says Thank You to alfox For This Useful Post:
Cable Compatible For IP-L18C For / Infinity Box Pin Finder Adapter / Pad Finder Box / IPMART ipmart WebShop 0 11-26-2009 09:30
Infinity-Power Cable Compatible For MC Tool / Infinity Box Pin Finder Adapter / Pad F IPMART ipmart WebShop 0 11-26-2009 09:30
Cable Compatible For IP-L20B For / Infinity Box Pin Finder Adapter / Pad Finder Box / IPMART ipmart WebShop 0 11-26-2009 09:30
Infinity Box PIN FINDER Adapter Not working OK hc_nuck23 Infinity-Box 2 04-14-2008 20:32
Infinity Box Pin-finder adapter : update box error nekbil Chinese Miracle & PinFinder 9 02-28-2008 17:02
Page generated in 0.78684 seconds with 12 queries
