02-18-2008, 09:13 | #48 (permalink) |
Product Supporter Join Date: Sep 2004 Location: *In the right way*
Member: 84268 Status: Offline Sonork: 100.114149 Thanks Meter: 2,569 | N82 with 18 pins with seccess software version: 1.05 searching adapter at COM3... adapter found, version: 2000 pins: 18 power cycles: 1 activation cycles: 7 power control: via adapter power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... CPU: MT6226 result: Rx:xx Tx:xx time required: 94 sec Power On ! |
02-19-2008, 06:44 | #50 (permalink) |
No Life Poster Join Date: Mar 2006 Location: tamilnadu, india.
Member: 243961 Status: Offline Sonork: 100.1591654 Thanks Meter: 104 | just now tested one piece .. software version: 1.05 searching adapter at COM4... adapter found, version: 2000 pins: 18 power cycles: 1 activation cycles: 7 power control: via adapter power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... CPU: MT6226 result: Rx:12 Tx:10 time required: 92 sec Power On ! Power Off ! good working ..thanks. |
02-19-2008, 13:54 | #52 (permalink) |
No Life Poster Join Date: Jan 2004 Location: india
Member: 50772 Status: Offline Sonork: 100.1590990 Thanks Meter: 318 | pins: 18 power cycles: 1 activation cycles: 7 power control: via adapter power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... CPU: MT6225 result: Rx:15 Tx:16 time required: 180 sec Power On ! |
02-19-2008, 22:11 | #53 (permalink) | |
Freak Poster Join Date: Sep 2007
Member: 583680 Status: Offline Thanks Meter: 47 | model tested:Sands A603 connector L20A Quote:
02-19-2008, 23:38 | #54 (permalink) | |
Member: 583680 Status: Offline Thanks Meter: 47 | tested phone:Cect T999-TV dual sim Quote:
02-21-2008, 09:28 | #56 (permalink) |
Member: 84268 Status: Offline Sonork: 100.114149 Thanks Meter: 2,569 | another n95 software version: 1.05 searching adapter at COM2... adapter found, version: 2000 pins: 12 power cycles: 1 activation cycles: 7 power control: via adapter power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... CPU: MT6226 result: Rx:7 Tx:6 time required: 44 sec Power On ! |
02-21-2008, 12:25 | #58 (permalink) |
Freak Poster Join Date: Oct 2005 Location: surat gujrat Age: 36
Member: 188609 Status: Offline Thanks Meter: 43 | software version: 1.05 searching adapter at COM5... adapter found, version: 2000 pins: 12 power cycles: 1 activation cycles: 4 power control: via adapter power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... failed to detect pins time required: 55 sec Power Off ! what is a problem plz ans [email protected] |
02-21-2008, 15:27 | #60 (permalink) |
No Life Poster Join Date: Jan 2004 Location: India Age: 43
Member: 50805 Status: Offline Thanks Meter: 101 | ZTC_ZT868 2GSM software version: 1.05 searching adapter at COM10... adapter found, version: 2000 pins: 18 power cycles: 1 activation cycles: 7 power control: via adapter power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... CPU: MT6226 result: Rx:12 Tx:10 time required: 98 sec Power On ! work fine |
Cable Compatible For IP-L18C For / Infinity Box Pin Finder Adapter / Pad Finder Box / | IPMART | ipmart WebShop | 0 | 11-26-2009 10:30 |
Infinity-Power Cable Compatible For MC Tool / Infinity Box Pin Finder Adapter / Pad F | IPMART | ipmart WebShop | 0 | 11-26-2009 10:30 |
Cable Compatible For IP-L20B For / Infinity Box Pin Finder Adapter / Pad Finder Box / | IPMART | ipmart WebShop | 0 | 11-26-2009 10:30 |
Infinity Box PIN FINDER Adapter Not working OK | hc_nuck23 | Infinity-Box | 2 | 04-14-2008 20:32 |
Infinity Box Pin-finder adapter : update box error | nekbil | Infinity-Box | 9 | 02-28-2008 18:02 |
