02-22-2008, 06:47 | #63 (permalink) |
No Life Poster Join Date: May 2007 Location: uk
Member: 508072 Status: Offline Thanks Meter: 1,621 | software version: 1.05 searching adapter at COM3... adapter found, version: 2000 pins: 10 power cycles: 1 activation cycles: 7 power control: via adapter power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... CPU: MT6226 result: Rx:3 Tx:9 time required: 21 sec Power On ! |
02-22-2008, 06:48 | #64 (permalink) |
Member: 508072 Status: Offline Thanks Meter: 1,621 | cect k300 1x12 pins software version: 1.05 searching adapter at COM3... adapter found, version: 2000 pins: 12 power cycles: 2 activation cycles: 7 power control: via adapter power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... CPU: MT6225 result: Rx:7 Tx:6 time required: 76 sec Power On ! |
02-27-2008, 16:59 | #69 (permalink) | |
Freak Poster Join Date: Mar 2005
Member: 122712 Status: Offline Thanks Meter: 121 | help.... anyone has tested this phone before? nckia E90 has 2 lcd screen and using 20pin i can't a-n-a-l-yze it using pinfinder infinity and also rx tx finder paklink. please anyone have a pinout of this phone? Quote:
02-27-2008, 18:31 | #70 (permalink) | |
No Life Poster Join Date: Feb 2005 Location: AD
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | Quote:
what CPU type ?? my experience that phone have infineon may that cpu is not supported yet txs | |
02-27-2008, 19:06 | #71 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! yes, mr. andra widianto is right. First make sure what MCU is used. second thing: Phone may have Test points on PCB, which is not present in system connector |
02-27-2008, 19:50 | #72 (permalink) |
Freak Poster Join Date: Apr 2007 Location: bangladesh
Member: 487537 Status: Offline Thanks Meter: 61 | what MCU is used how can i sure & i tri to foemat (ffs:safe) foemat was dan but problem is now Phone i tri to flash but Phone dasnot on what hapen in Phone teel me (infinityhelp |
02-27-2008, 22:42 | #73 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! first of all open phone and make sure it is MT62xx MCU based phone. then read autopinout finder user manual and find pinout after pinout found- make format FFS at what point you facing problems mr. gobindopura ? |
02-28-2008, 06:18 | #74 (permalink) | |
Member: 122712 Status: Offline Thanks Meter: 121 | Quote:
so is there any posibility to make this phone support without TP method? hope infinity team will do great job. like mr andra widianto said CPU infineon doesn't support yet. | |
Cable Compatible For IP-L18C For / Infinity Box Pin Finder Adapter / Pad Finder Box / | IPMART | ipmart WebShop | 0 | 11-26-2009 10:30 |
Infinity-Power Cable Compatible For MC Tool / Infinity Box Pin Finder Adapter / Pad F | IPMART | ipmart WebShop | 0 | 11-26-2009 10:30 |
Cable Compatible For IP-L20B For / Infinity Box Pin Finder Adapter / Pad Finder Box / | IPMART | ipmart WebShop | 0 | 11-26-2009 10:30 |
Infinity Box PIN FINDER Adapter Not working OK | hc_nuck23 | Infinity-Box | 2 | 04-14-2008 20:32 |
Infinity Box Pin-finder adapter : update box error | nekbil | Infinity-Box | 9 | 02-28-2008 18:02 |
