Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Insane Poster ![]() ![]() ![]() Join Date: Feb 2010
Member: 1231161 Status: Offline Thanks: 44
| Infinity does not read or write flash in the N97 and N97 Chinese Please infinity team how to solve this?? COM15 [VCP0] selected Módulo v3.25 Dispositivo: Autodetect 6205-6239 NOR Verificando Dados. Aguarde... Detecção Avançada da Flash Habilitada Action: read flash ====> Boot ... Pressione e SEGURE o Botão de Ligar! 19200 fixed Conectando. Aguarde... Inicializando [6235:8A04:8A01]... CPU: MT6235 Boot Em Alta Velocidade On chip: 0000:0000:0003 status: FF Tamanho do Pacote de Inicialização: 0400 Solte o Botão de Ligar! Em Caso de Problemas Com a Conexão Inicial: Ligue/Desligue "Seleção Autom. da Vel. de Inicialização" Boot Fail Finalizado. Tempo Gasto: 12 sec Remova/Recoloque a Bateria! |
| The Following User Says Thank You to marcel09 For This Useful Post: |
| | #4 (permalink) |
| after flash the phone so do not start flashing COM15 [VCP0] selected Módulo v3.25 Dispositivo: Autodetect 6228-6253 NAND Verificando Dados. Aguarde... Action: write flash NAND Escrever Firmware E708_PXHT1_PCB01_GPRS_MT6235B_S01.01_0__N97_128Mb_ En_Fr_Es_Pt_It_De_Ml_Id_Cz_Slovak_Nl_Tr_Vn_Ru_Bg_P ersian_Cn.B4M.bin Pular: Customization/Language Pack Pular: Customization Pular: Eeprom/ffs nfi area detection... external bootloader is not present bootloader version: E708_BOOTLOADER_V005_MT6235B_01_1.bin nfi area detection (3 cores) finished: Ok "Formatar FFS" Ativado interface: BROM_DLL_v3.1016.00 Connectar... O Telefone Deverá Estar DESLIGADO! Pressione e SEGURE o Botão de Ligar! Connecting... Booting... Solte o Botão de Ligar! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0058]: 002C:00A100800015 [MICRON] MT29F1G08ABB chip size: 128Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: S_DA_RAM_ERROR Feito Set baudrate (460800)... Feito ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... Tamanho/Offset do FFS: 03000000/05000000 firmware size: 48Mb ffs size: 80Mb detect sec ro... detect custom parameters... detect project-id... project-id: E708_JJF1NCOMP.01.0 detect NAND info... number of areas/bytes to read: 1:001A0000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... external bootloader is not present bootloader version: E708_BOOTLOADER_V005_MT6235B_01_1.bin nfi area detection (3 cores) finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 05 sw version: E708_JJF1NCOMP_PCB01_GPRS_MT6235B_S01.01_0.BIN project-id: E708_JJF1NCOMP.01.0, 00000000 code offset: 00000000 ffs offset/size [01]: 03000000/05000000 rom info structure: [standard] type (05) TCL-ID is absent ===> Feito ==================== New firmware found (v.3.25, database date: 23.11.2010): E708_JJF1NCOMP_PCB01_GPRS_MT6235B_S01.01_0.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Ler FullFlash" operation - send flash backup files to support: mt62xx@gmail.com or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== nfi area detection... external bootloader is not present bootloader version: E708_BOOTLOADER_V005_MT6235B_01_1.bin nfi area detection (3 cores) finished: Ok startup code area #1 check... Feito number of cores: 3 loading files... number of areas: 3 Feito write... write bootloader... . . . . . write core... Aviso: can not format: HW_STORAGE_NOR is not present Format (HW_STORAGE_NOR)... Disconnect... Feito Finalizado. Tempo Gasto: 26 min 34 sec Remova/Recoloque a Bateria! |
| | #5 (permalink) |
| Product Supporter ![]() ![]() ![]() Join Date: May 2005 Age: 36
Member: 148515 Status: Offline Thanks: 2,319
| hello! your phone's original software version is E708_JJF1NCOMP_PCB01_GPRS_MT6235B_S01.01_0 why did you flash it with different file? did you make full backup before this operation? |
| | #9 (permalink) | |
| Quote:
MEGAUPLOAD - The leading online storage and file delivery service thanksss | |
| | #10 (permalink) |
| Junior Member ![]() Join Date: Mar 2010
Member: 1251379 Status: Offline Thanks: 8
| Same problem here, I can´t find another Chiang Jiang N97 to make full backup and restore one phone I have. I use the STAR N97 image (E708_PXHT1_PCB01_GPRS_MT6235B_S01.01_0_B4M.bin). Everything works BUT touchscreen. Have acces to full functions by qwerty keyboard. The file you link is for Flash Tools and I never be able to restore the phone with that file (no boot). |
| | #11 (permalink) |
| Update Now I remember, I try the same image from suport (E708_PXHT1_PCB01_GPRS_MT6235B_S01) and have same fail result. Try this file Is a STAR N97 Infinity Box image I have and works with CJ N97. Remember, touch screen not work, everything else OK. |
| The Following User Says Thank You to mx-t2 For This Useful Post: |
| | #12 (permalink) | |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Sep 2005 Age: 30
Member: 179402 Status: Offline Thanks: 174
| Quote:
| | #14 (permalink) |
| | #15 (permalink) |
| Insane Poster ![]() ![]() ![]() Join Date: Aug 2011 Location: el carmen M.
Member: 1630737 Status: Offline Thanks: 36
| I have this problem friends COM3 [VCP0] selected module v3.26 Action: reset settings ("format ffs") Model: Autodetect 6228-6253 NAND Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:5603:0009 status: FF Connecting at 19200, wait... error: can not finalize test mode repeat operation and HOLD phone "Power" button more long time ! error: operation failed ! Finished, time used: 1 min 25 sec Remove/Install battery now ! help |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| 6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 5 | 04-10-2013 02:07 |
| How to add a language in 51xx/61xx | tati | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 7 | 12-10-2012 04:46 |
| Seeking for flash nokia 5110 old version (3 version) can exchange for new | Tomas | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 7 | 11-17-2011 17:08 |
| IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 3 | 11-15-2011 12:08 |
| wt603 and .pkd | ARt | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 0 | 06-13-1999 19:18 |
