04-13-2009, 01:11 | #1 (permalink) |
Freak Poster Join Date: Mar 2006 Location: Pakistan Age: 44
Member: 240756 Status: Offline Thanks Meter: 90 | To Infinity Team,Facing New Problem Now a days im facing new problem that i can not make any operation with MT6228 Cpu base fone.always one Error shows(error Unexpected answer) Mobiles are on working condition,just Restart Problem.not a single mobile more then 5 MT6228 cpu not format nor read detail information. Here is a 1 example Logs. COM4 [VCP0] selected module v2.81 Device: Autodetect 6228-6230 NAND Checking data, wait... Action: read/check detailed information Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6228:8A02:8A02]... CPU: MT6228 high speed boot Off chip: 0031:0000:0101 status: FF high speed boot Off boot packet size: 0400 Release Power button now ! Boot Done Initialize ... version: 3.0207 loader: 3.748.0 NAND: Hynix HY27XS08121M 512+16 32 pages, 66Mb NAND id: AD76AD76 page size: 200+10 pages/block: 20 bits i/o: 08 address cycles: 04 blocks: 1000 finalize connection... done emi configuration... emi configuration done check bootloader validity... error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: done NOR: 0000:000000000000 [00000000] NAND: 00AD:007600AD0076 [04200000] NOR chip is not installed Initialize Done Set baud ... slowest Set baud Done Identification ... error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: reading bootloader structure area (00010000 bytes)... error: unexpected answer: warning: nfi read command is not accepted error: bootloader structure area read failed, read again... error: unexpected answer: warning: nfi read command is not accepted error: can't read area required for bootloader structure detection: 00000000 instead of 00010000 Finished, time used: 140 sec Remove/Install battery now !. ------------------------------- Tried evrything what i can do. slowest speed,highiest Baudrate.at everybaudrate i try but same result. i can not understand that My infinity is damaged or what? MT6226 and others are having no problems.good flash good format. I request to infinit team,plz kindly help me and solve this nonsense problem. i will be very thankfull to Infinity team. im using infinity for 3year. Thanx in Adv............ |
04-13-2009, 08:39 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, There is no any problems with your box. Try to press and HOLD phone "Power" button more long time, probably it may helps to solve problem. |
04-13-2009, 20:00 | #3 (permalink) |
Member: 240756 Status: Offline Thanks Meter: 90 | @Infinitysupport Thanx to infinity team not help,Same problem.. COM4 [VCP2] selected module v2.81 Device: Autodetect 6228-6230 NAND Checking data, wait... Action: read/check detailed information Boot ... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... Initializing [6228:8A02:8A02]... CPU: MT6228 high speed boot Off chip: 0031:0000:0101 status: FF high speed boot Off boot packet size: 0400 Release Power button now ! Boot Done Initialize ... version: 3.0207 loader: 3.748.0 NAND: Hynix HY27XS08121M 512+16 32 pages, 66Mb NAND id: AD76AD76 page size: 200+10 pages/block: 20 bits i/o: 08 address cycles: 04 blocks: 1000 finalize connection... done emi configuration... emi configuration done check bootloader validity... error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: done NOR: 0000:000000000000 [00000000] NAND: 00AD:007600AD0076 [04200000] NOR chip is not installed Initialize Done Set baud ... 115200 error: unexpected answer: error: can't work at this speed, use lower speed Set baud Fail Finished, time used: 101 sec Remove/Install battery now ! |
04-13-2009, 22:32 | #5 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @Aazib jhon I don't think that it's a problem with latest software, but to be sure, please, make this test: download and install previous ChineseMiracle version (f.e. 2.79) and test your phone with previous version. What is the results ? |
04-15-2009, 00:15 | #6 (permalink) |
Member: 240756 Status: Offline Thanks Meter: 90 | @Infinitysupport Same Result.problem is stil yet. COM14 [VCP0] selected Device: Autodetect 6228, 6230 NAND Checking data, wait... Action: read/check detailed information Boot... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... Initializing[6228:8A02:8A02]... CPU: MT6228 high speed boot disabled chip: 0031:0000:0101 high speed disabled boot step size: 0400 Release Power button now ! Boot Done Initialize... version: 3.0207 loader: 3.748.0 NAND: Hynix HY27XS08121M 512+16 32 pages, 66Mb NAND id: AD76AD76 page size: 200+10 pages/block: 20 bits i/o: 08 address cycles: 04 blocks: 1000 error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: error: unexpected answer: NOR: 0000:000000000000 [00000000] NAND: 00AD:007600AD0076 [04200000] NOR chip is not installed Initialize Done Set baud... 115200 error: unexpected answer: error: can't work at this speed, use lower speed Set baud Fail Finished, time used: 106 sec Remove/Install battery now ! ===================== im in deep trouble now.i don't know what should i do more? now im going to change my pc.then i will post result. (this logs is from another infinity box)i also changed pinfinder cable. anyway thanx infinity team.! (version chinese miracle 2.61 and 2.78 tried) |
04-18-2009, 21:57 | #7 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, I don't think that it's a problem with software due to it was done no big changes with initial communication in latest ChineseMiracle versions. Try to adjust port settings: Let's see results. |
to infinity team fix problem R306 | ayhen42 | Infinity-Box | 1 | 01-17-2010 09:17 |
to infinity team please respond(((solution new alcatelīs avaible.. | residentdenuevo | Infinity-Box | 8 | 08-20-2009 19:28 |
to infinity team plss add new firm ware s22ou | ayhen42 | Infinity-Box | 0 | 06-07-2009 09:34 |
i am facing new problem like this | kasim | iPhone 2 / iPhone 3G / iPhone 3GS | 0 | 08-04-2008 08:52 |
