01-12-2011, 03:33 | #1 (permalink) |
Insane Poster Join Date: Oct 2007
Member: 599499 Status: Offline Thanks Meter: 1 | Infinity team please help me, how to unlock china nckia n98i COM6 [VCP0] selected module v3.25 Action: read unlock codes unlock method: read codes Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:7003:000B status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: HDZ1701.8.12.1.0T07M0225_M551A Version: HDZM551A detecting structure #2... 5 11 done 67 byte(s) read imei: 35603200374060 connection Ok detecting structure #1... 0 1 5 8 9 10 12 13 14 done 178 byte(s) read 166 byte(s) read Phone lock: Off Network lock: Off Network subset lock: Off Service provider lock: Off Corporate lock: Off IMSI lock: Off Auto lock: Off Phone code: 1122 Finished, time used: 14 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! |
01-12-2011, 03:34 | #2 (permalink) |
Member: 599499 Status: Offline Thanks Meter: 1 | ==== [2011-1-4 11:08:40] ==== COM6 [VCP0] selected module v3.25 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:7003:000B status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 detecting chip #02 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 detecting chip #03 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 460800 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (04) TCL-ID is absent rom info detection finished rom info ver: 04 sw version: TECHAIN25_GEMINI_PCB01_GPRS_MT6225_S00.HDZ1701_8_1 2_1_0T07M0225_M551A.BIN project-id: HDZ1701.8.12.1.0T07M0225_M551A, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [standard] type (04) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF firmware area: 00000000-00DFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: TECHAIN25_GEMINI_PCB01_GPRS_MT6225_S00.HDZ1701_8_1 2_1_0T07M0225_M551A__ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\TECHAIN25_GEMINI_ PCB01_GPRS_MT6225_S00.HDZ1701_8_12_1_0T07M0225_M55 1A__ffs_20110104-111039.B0E.bin flash: 01227E22202200:18E59F00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 01227E22202200:18E59F00000000 Finalization Done Finished, time used: 2 min 19 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
01-12-2011, 03:35 | #3 (permalink) |
Member: 599499 Status: Offline Thanks Meter: 1 | ==== [2011-1-4 11:13:19] ==== COM6 [VCP0] selected module v3.25 Action: "sp-unlock" unlock method: smart fast Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:7003:000B status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: HDZ1701.8.12.1.0T07M0225_M551A Version: HDZM551A detecting structure #2... 5 11 done 67 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #1... 0warning: wrong packet cs 1 5 8 9 10 12 13 14 done 178 byte(s) read reading data... building new data... writing data... detecting structure #3... error: can't read additional data reading data... 34 byte(s) read building new data... warning: unknown lock mode: 2E312E30 error: data is invalid Finished, time used: 22 sec Remove/Install battery now ! |
01-12-2011, 03:41 | #4 (permalink) |
Member: 599499 Status: Offline Thanks Meter: 1 | ==== [2011-1-4 11:19:49] ==== COM6 [VCP0] selected module v3.25 Action: "sp-unlock" unlock method: smart fast Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:7003:000B status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: HDZ1701.8.12.1.0T07M0225_M551A Version: HDZM551A detecting structure #2... 5 11 done 67 byte(s) read imei: 35700000387309 connection Ok detecting structure #1... 0 1 5 8 9 10 12 13 14 done 178 byte(s) read reading data... building new data... writing data... detecting structure #3... error: can't read additional data reading data... 34 byte(s) read building new data... warning: unknown lock mode: 2E312E30 error: data is invalid Finished, time used: 13 sec Remove/Install battery now ! |
01-12-2011, 03:43 | #5 (permalink) |
01-13-2011, 22:31 | #8 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! please make full backup and try one of there firmwares: flashfiles/ChineseMiracle/_MT6225/TECHAIN25_GEMINI_PCB01_GPRS_MT6225_S00.HDZ1701_8_1 2_1_0T07M0225_M551A_16m_En_Fr_Es_Id_Th_Vn_Tr_Farsi _Pt_Ar.B0M.bin flashfiles/ChineseMiracle/_MT6225/TECHAIN25_GEMINI_PCB01_GPRS_MT6225_S00.HDZ1704_8_1 2_1_0T03M0226_M551A_2010-02-26_16m_En_Ru_Fr_De_Id_Th_Vn.B0M.bin i have strong feeling that SPlock is located in firmware |
01-20-2011, 02:53 | #9 (permalink) | |
Member: 599499 Status: Offline Thanks Meter: 1 | Quote:
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
