10-24-2010, 08:16 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: Pakistan Age: 41
Member: 278548 Status: Offline Sonork: 100.1583183 Thanks Meter: 948 | Infinity team please solve this problem module v3.25 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") Do you want to make ffs/eeprom backup before format ? ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:C403:000E status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC240200000000:2AEA0000000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 detecting chip #01 in region #00... flash: EC240200000000:2AEA0000000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 detecting chip #02 in region #00... flash: EC240200000000:2AEA0000000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 detecting chip #03 in region #00... flash: EC240200000000:2AEA0000000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: EC240200000000:2AEA0000000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 detecting chip #01 in region #00... flash: EC240200000000:2AEA0000000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (05) TCL-ID is absent ==================== New firmware found (v.3.25, database date: 20.10.2010): R269AL_LT_F15_PCB01_GPRS_MT6225_S00.R269AL_LT_X88_ F15_V04_091223.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info ver: 05 sw version: R269AL_LT_F15_PCB01_GPRS_MT6225_S00.R269AL_LT_X88_ F15_V04_091223.BIN project-id: R269AL_LT_X88_F15_V04_091223, 00000000 code offset: 00000000 ffs offset/size [01]: 00E40000/001C0000 rom info structure: [standard] type (05) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E40000 flash: EC240200000000:2AEA0000000000 checking area [00000000]: 00080000-00FFFFFF... Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 00E40000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs/eeprom address selected by user detecting ffs/eeprom size... ffs/eeprom size: 001C0000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E40000-00FFFFFF firmware area: 00000000-00E3FFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: EC240200000000:2AEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: EC240200000000:2AEA0000000000 Finalization Done Finished, time used: 2 min 30 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! COM8 [VCP0] selected module v3.25 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: "repair imei" imei write channel: imei #1 (default imei inside firmware) new imei: 354644000666443 ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:C403:000E status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC240200000000:2AEA0000000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 detecting chip #01 in region #00... flash: EC240200000000:2AEA0000000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 detecting chip #02 in region #00... flash: EC240200000000:2AEA0000000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 detecting chip #03 in region #00... flash: EC240200000000:2AEA0000000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: EC240200000000:2AEA0000000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 detecting chip #01 in region #00... flash: EC240200000000:2AEA0000000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (05) TCL-ID is absent ==================== New firmware found (v.3.25, database date: 20.10.2010): R269AL_LT_F15_PCB01_GPRS_MT6225_S00.R269AL_LT_X88_ F15_V04_091223.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info ver: 05 sw version: R269AL_LT_F15_PCB01_GPRS_MT6225_S00.R269AL_LT_X88_ F15_V04_091223.BIN project-id: R269AL_LT_X88_F15_V04_091223, 00000000 code offset: 00000000 ffs offset/size [01]: 00E40000/001C0000 rom info structure: [standard] type (05) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E40000 flash: EC240200000000:2AEA0000000000 checking area [00000000]: 00080000-00FFFFFF... Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 00E40000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs/eeprom address selected by user detecting ffs/eeprom size... ffs/eeprom size: 001C0000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E40000-00FFFFFF firmware area: 00000000-00E3FFFF detecting startup code area #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... startup code area #2 is absent sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: EC240200000000:2AEA0000000000 Backup required data Done ====> Patch required data ... detecting ffs/eeprom structure pass 2... ............................ ffs/eeprom: detect std location pass #1... .................................................. ....... ffs/eeprom: detect ext location pass #1... .................................................. ....... ffs/eeprom: detect ext2 location pass #1... .................................................. ....... warning: ffs/eeprom location can't be detected error: ffs/eeprom detection failed element #2 error: can not detect default imei value Patch required data Fail Finished, time used: 2 min 40 sec Remove/Install battery now ! |
10-24-2010, 09:44 | #4 (permalink) | |
No Life Poster Join Date: Sep 2006 Location: (¯Catch Me If U Can¯) Age: 50
Member: 360073 Status: Offline Thanks Meter: 2,181 | U PROB IS .... NO EEPROM(FFS) TETECTED TRY to WRITE GOOD EEPROM then format ffs & repair imie Quote:
10-25-2010, 23:42 | #9 (permalink) |
Major Poster Join Date: Nov 2009 Location: Hungary
Member: 1152295 Status: Offline Sonork: 19860704 Thanks Meter: 2 | Hello Can you please help i want to read firmware from this phone but cant. Phone working well dont have any problem. The boot is only go up to 45% than display this log Thank you COM2 [VCP0] selected module v3.25 Device: Autodetect 6228-6253 NAND Checking data, wait... Action: read flash NAND interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 0.0/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash id[0000]: 0000:000000000000 [AMD] AM29DL323D chip size: 0Mb otp status/size: S_DONE/00000000 NAND flash id[0000]: 0000:000000000000 [SAMSUNG] K9F5608Q0C chip size: 0Mb page/spare size: 0000/0000 pages per block: 0000 bits i/o: 00 address cycles: 00 internal RAM size: 00000000 external RAM [HW_RAM_UNKNOWN, CS0] size: 00000000 error: can not boot device: 07D4:S_BROM_DOWNLOAD_DA_FAIL error: last error: 07D4:S_BROM_DOWNLOAD_DA_FAIL Disconnect... done Finished, time used: 28 sec Remove/Install battery now ! |
10-26-2010, 20:00 | #10 (permalink) | |
Member: 1043909 Status: Offline Thanks Meter: 60,861 | Quote:
"Deskey Device driver not found" ?? Please help | DivAdonis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-08-2017 13:21 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
