11-29-2008, 14:11 | #1 (permalink) |
Freak Poster Join Date: Jun 2007 Location: S A H I W A L Age: 38
Member: 526737 Status: Offline Thanks Meter: 9 | Infinity team plz help me and give me flash file when i recive set it is dead then i write ffs complete formate after then set is gone "bad softwere" i read eeprom and write set is dead and no on plz asist me what should i have to do. . . after writing the eeprom showing this error Detected eeprom/ffs address is non-standard: 00F40000 Posible reasons: 1. eeprom is Ok but address is non-standard 2. eeprom damaged and can't be detected 3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make flash backup for emergency case 3. repeat required operation Are you sure that detected eeprom address is correct ? Do you want to use standard eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation This is full flash backup file flash_20081128-235302.B0M This is eeprom file eeprom_20081128-232011.B0E Regard's aamirgsm |
11-29-2008, 15:47 | #2 (permalink) |
No Life Poster Join Date: Nov 2008 Location: Riyadh, KSA Age: 43
Member: 894719 Status: Offline Sonork: 100.1580092 Thanks Meter: 905 | try to use someother flash files from the support area and choose same as the set you have try all the flash files of 5310 hopfly one of them will be the right one regards |
11-29-2008, 16:42 | #3 (permalink) | |
No Life Poster Join Date: Nov 2005 Location: .:GSM WORLD:.
Member: 203158 Status: Offline Sonork: 100.1592032 Thanks Meter: 358 | Quote:
if u have the first EEprom backup .. then write the phone will revive..... | |
11-30-2008, 07:46 | #5 (permalink) | |
Member: 526737 Status: Offline Thanks Meter: 9 | Quote:
Dear sir when i recive this set . set is dead i write the ffs complete formate.set is gone "bad softwere" then i write the first eeprom backup after writing the eeprom set is gone dead . . . plz asist me what should i have to do. . . Regard's aamirgsm | |
11-30-2008, 08:00 | #6 (permalink) | |
sir i will download all 5310 files at the support then i have try all the flash file and post here Regard's aamirgsm | |
11-30-2008, 08:36 | #8 (permalink) |
No Life Poster Join Date: Oct 2005 Location: Islamabad--Pakistan
Member: 194128 Status: Offline Thanks Meter: 303 | Here is your desired flashfile. http://www.4shared.com/file/73762776...V1_6_1BIN.html After flashing if phone shows "Bad Software", simply click on "Repair Bad Software" button. BEST OF LUCK! yawarniazi |
11-30-2008, 11:58 | #9 (permalink) | |
i write these flash file set is gone bad softwere i write ffs complete formate set is dead what should i have to do plz help me . . . Regard's aamirgsm | |
11-30-2008, 12:26 | #10 (permalink) |
Member: 194128 Status: Offline Thanks Meter: 303 | Why are you hasitating on clicking "Repair Bad Software" button in ChineseMiracle after flash????????????????????????????????????????????? ??????????????????????? |
11-30-2008, 14:38 | #11 (permalink) |
Member: 526737 Status: Offline Thanks Meter: 9 | dear when i flash phone ur files set is gone "bad softwere" u will advice me after flashing if phone shows "Bad Software", simply click on "Repair Bad Software" button but i will clicking ffs complete formate and set is gone dead mode plz help me what should i have todo Regard's aamirgsm |
12-01-2008, 08:41 | #15 (permalink) |
Member: 526737 Status: Offline Thanks Meter: 9 | thanks a lot sir my problm is solve set is alive but when i power on after few sec set is hang and set is power off plz asist me what should i have to do infinity is good box 4 chines mobile & infinity team is great work Regard's aamirgsm |
infinity team plz help me | qadriatta | Infinity-Box | 2 | 03-08-2009 21:46 |
6300 RH-37 after factory setting set is gone dead mode infinity team plz help me | aamirgsm | Infinity-Box | 4 | 12-08-2008 09:39 |
infinity team plz help me | Raja_Vickey | Infinity-Box | 1 | 09-18-2008 21:50 |
c140 cant unlock in infinity team plz help me | ramesh_931 | Infinity-Box | 7 | 07-20-2007 17:47 |
Infinity team plz help me to flash for nokia E60 | .::Munazzam::. | Infinity-Box | 7 | 06-27-2007 19:53 |
