07-12-2008, 15:36 | #1 (permalink) |
No Life Poster Join Date: Dec 2006 Location: egypt Age: 37
Member: 419703 Status: Offline Thanks Meter: 123 | model new by gsm_bb5 TOUCHPANEL_E8 model : TOUCHPANEL nokia:E8 CPU: MT6226 New firmware detected: E553_X9PAPAARTF_E553_GPRS_MT6226_S01.01_1.BIN COM4 selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: reset Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:197A:1A64 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 921600 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.EC4A483A.[E553_X9PAPAARTF_E553_GPRS_MT6226_S01.01_1.BIN_1355 4C00].rpl ==================== New firmware detected: E553_X9PAPAARTF_E553_GPRS_MT6226_S01.01_1.BIN - make "Read full flash" operation - send "backup_system_log_..." file to support: [email protected] - send flash backup file(s) to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== identification#1 detection finished device-id: EC4A483A identification#1 protocol ver: 04 ver. sw1: E553_X9PAPAARTF_E553_GPRS_MT6226_S01.01_1.BIN ver. sw2: E553_X9PAPAARTF.01.1, FFB3AAEC ffs offset/size: 00800000/001FF000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00800000 flash: EC257E25082501:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 Detected eeprom/ffs address is non-standard: 00E00000 Posible reasons: 1. eeprom is Ok but address is non-standard 2. eeprom damaged and can't be detected 3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make flash backup for emergency case 3. repeat required operation Are you sure that detected eeprom address is correct ? autodetected eeprom/ffs address[00E00000] confirmed by user detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading [eeprom[E553_X9PAPAARTF_E553_GPRS_MT6226_S01.01_1.BIN]]... file saved: C:\Documents and Settings\GSM_BB5\Desktop\T\New Folder\eeprom[E553_X9PAPAARTF_E553_GPRS_MT6226_S01.01_1.BIN]_20080711-223008.B0E.bin flash: EC257E25082501:29EA0000000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Write Done Finalization... formatting... flash: EC257E25082501:29EA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\system_log_EC4A48 3A_E553_X9PAPAARTF_E553_GPRS_MT6226_S01.01_1.BIN_1 3554C00_20080711-223056.B0X.bin Finished, time used: 257 sec Remove/Install battery now ! COM4 selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: read NOR flash Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:197A:1A64 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 921600 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.EC4A483A.[E553_X9PAPAARTF_E553_GPRS_MT6226_S01.01_1.BIN_1355 4C00].rpl ==================== New firmware detected: E553_X9PAPAARTF_E553_GPRS_MT6226_S01.01_1.BIN - make "Read full flash" operation - send "backup_system_log_..." file to support: [email protected] - send flash backup file(s) to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== identification#1 detection finished device-id: EC4A483A identification#1 protocol ver: 04 ver. sw1: E553_X9PAPAARTF_E553_GPRS_MT6226_S01.01_1.BIN ver. sw2: E553_X9PAPAARTF.01.1, FFB3AAEC ffs offset/size: 00800000/001FF000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00800000 flash: EC257E25082501:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 Detected eeprom/ffs address is non-standard: 00E00000 Posible reasons: 1. eeprom is Ok but address is non-standard 2. eeprom damaged and can't be detected 3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make flash backup for emergency case 3. repeat required operation Are you sure that detected eeprom address is correct ? autodetected eeprom/ffs address[00E00000] confirmed by user detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading [flash[E553_X9PAPAARTF_E553_GPRS_MT6226_S01.01_1.BIN]]... file saved: C:\Documents and Settings\GSM_BB5\Desktop\TO\backup_flash[E553_X9PAPAARTF_E553_GPRS_MT6226_S01.01_1.BIN]_20080711-222424.B0M.bin file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_system_log _EC4A483A_E553_X9PAPAARTF_E553_GPRS_MT6226_S01.01_ 1.BIN_13554C00_20080711-222444.B0X.bin Finished, time used: 661 sec Remove/Install battery now ! MR / ABOELWAFA |
07-12-2008, 21:22 | #2 (permalink) | |
No Life Poster Join Date: May 2008 Location: COME & MADE GREEN WORLD
Member: 771937 Status: Offline Sonork: 100.1605717 Thanks Meter: 1,052 | Quote:
brother read this carefully,i hope you will gat ans. E553_X9PAPAARTF_E553_GPRS_MT6226_S01.01_1.BIN - make "Read full flash" operation - send "backup_system_log_..." file to support: [email protected] - send flash backup file(s) to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) | |
The Following User Says Thank You to debmobile For This Useful Post: |
07-13-2008, 20:10 | #3 (permalink) |
Member: 419703 Status: Offline Thanks Meter: 123 | ok im send flash backup file(s) to support: [email protected] |
The Following User Says Thank You to GSM_BB5 For This Useful Post: |
anycool d66+ new by gsm_bb5 | GSM_BB5 | Infinity-Box | 4 | 09-29-2009 10:00 |
open locked Vodafone-330FM BY GSM_BB5 | GSM_BB5 | Infinity-Box | 1 | 08-03-2009 17:54 |
No New Bb5 Models Supported By Mt-lite.....911gt No Christmis Gift By Gt Team? | sairat | MT-BOX | 0 | 12-20-2007 21:48 |
Solutions for New models dead by flashing | PARMATMA | UFS2 + UFS3-Tornadoflasher | 3 | 12-22-2005 20:25 |
where to buy rj45 cable for new model supported by redbox | ashvin | Redbox | 2 | 11-22-2005 08:07 |
