Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Jul 2005 Location: Pak Age: 34
Member: 162328 Status: Offline Sonork: 100.1618216 Thanks: 7
| infinty Damege EEprom plz help i tried to change imei doul sim mobile ZT 6668 smile with method 3 but its damage my mobile eeprom. i download files from infinity support and flsh with two files flash file and eeprom file after flash still dead. here is first log which mobile dead. i also flash backup rpl and eeprom with its read only small size 6 kb. COM3 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: read/check detailed information Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:6386:1681 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... slowest Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: H:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.3B89E71D.[E553_X9PAPAARTF_E553_GPRS_MT6226_S01.01_1.BIN_1355 4C00].rpl ==================== New firmware detected: E553_X9PAPAARTF_E553_GPRS_MT6226_S01.01_1.BIN - make "Read full flash" operation - send "backup_system_log_..." file to support: mt62xx@gmail.com - send flash backup file(s) to support: mt62xx@gmail.com - include in your e-mail full text from phone back label (phone name etc.) ==================== identification#1 detection finished device-id: 3B89E71D identification#1 protocol ver: 04 ver. sw1: E553_X9PAPAARTF_E553_GPRS_MT6226_S01.01_1.BIN ver. sw2: E553_X9PAPAARTF.01.1, FFB3AAEC ffs offset/size: 00800000/001FF000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00800000 flash: EC257E25082501:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 Detected eeprom/ffs address is non-standard: 00E00000 Posible reasons: 1. eeprom is Ok but address is non-standard 2. eeprom damaged and can't be detected 3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make flash backup for emergency case 3. repeat required operation Are you sure that detected eeprom address is correct ? Do you want to use standard eeprom address: 00800000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation operation terminated by user error: critical error#1 during ffs size detection error: can't detect eeprom/ffs address/size error: chip layout not detected error: chip layout not detected Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... file saved: H:\Program Files\InfinityBox\ChineseMiracle\system_log_3B89E7 1D_E553_X9PAPAARTF_E553_GPRS_MT6226_S01.01_1.BIN_1 3554C00_20080705-181653.B0X.bin Finished, time used: 161 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? COM3 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: reset Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:6386:1681 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... slowest Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: H:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.3B89E71D.[E553_X9PAPAARTF_E553_GPRS_MT6226_S01.01_1.BIN_1355 4C00].rpl ==================== New firmware detected: E553_X9PAPAARTF_E553_GPRS_MT6226_S01.01_1.BIN - make "Read full flash" operation - send "backup_system_log_..." file to support: mt62xx@gmail.com - send flash backup file(s) to support: mt62xx@gmail.com - include in your e-mail full text from phone back label (phone name etc.) ==================== identification#1 detection finished device-id: 3B89E71D identification#1 protocol ver: 04 ver. sw1: E553_X9PAPAARTF_E553_GPRS_MT6226_S01.01_1.BIN ver. sw2: E553_X9PAPAARTF.01.1, FFB3AAEC ffs offset/size: 00800000/001FF000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00800000 flash: EC257E25082501:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 Detected eeprom/ffs address is non-standard: 00E00000 Posible reasons: 1. eeprom is Ok but address is non-standard 2. eeprom damaged and can't be detected 3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make flash backup for emergency case 3. repeat required operation Are you sure that detected eeprom address is correct ? Do you want to use standard eeprom address: 00800000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation operation terminated by user error: critical error#1 during ffs size detection error: can't detect eeprom/ffs address/size Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... flash: EC257E25082501:29EA0000000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Write Done Finalization... formatting... flash: EC257E25082501:29EA0000000000 Finalization Done file saved: H:\Program Files\InfinityBox\ChineseMiracle\system_log_3B89E7 1D_E553_X9PAPAARTF_E553_GPRS_MT6226_S01.01_1.BIN_1 3554C00_20080705-182016.B0X.bin Finished, time used: 177 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! COM3 [VCP0] selected Action: imei imei write method: mode-2 new imei: 350697305764986 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:6386:1681 Connecting, wait... error: can't finalize test mode repeat operation and HOLD phone "Power" button long time ! error: operation failed ! Finished, time used: 96 sec Remove/Install battery now ! Imei 35069730576498 already was repaired: 7/5/2008-6:23:15 PM Continue with this imei ? COM3 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: imei imei write method: mode-3 new imei: 350697305764986 Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:6386:1681 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... slowest Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb Warning: probably flash chip empty, erased, incorrectly flashed or damaged. What to do: 1. go to software "Settings" page 2. set "Advanced chip detection method" box UN-CHECKED ! 3. make flash write operation If still no luck: send mail to support (mt62xx@gmail.com) with detailed description of problem, attach the next files in your e-mail: 1. H:\Program Files\InfinityBox\ChineseMiracle\operation.log 2. H:\Program Files\InfinityBox\ChineseMiracle\cfi_***x_***x.bin detecting chip #01 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. ............................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset assigned: 00E00000 flash: EC257E25082501:FFFFFF00000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading [eeprom]... file saved: H:\Program Files\InfinityBox\ChineseMiracle\eeprom_20080705-18doublepppp25.B0E.bin flash: EC257E25082501:FFFFFF00000000 Backup required data Done Patch required data... imei is not detected ! What to do: 1. Power-On phone 2. wait 20-30 sec 3. Power-Off by "Power" button, don't remove battery ! 4. Repeat "imei repair" procedure again If imei can't be detected: 1. make "complete" ffs format 2. Power-On phone 3. wait 20-30 sec 4. Power-Off by "Power" button, don't remove battery ! 5. Repeat "imei repair" procedure again If imei can't be detected: read flash and send to support: mt62xx@gmail.com Patch required data Fail Finished, time used: 1324 sec Remove/Install battery now ! |
| | #3 (permalink) |
| i flash with two files here is log phone still dead plz help ZTC-ZT6668E553_X9PAPAARTF_E553_GPRS_MT6226_S01.01_1__1 6m_Ru_Fr_En_Th_Vn_Cn_Hi_Cn_Ar.B0M.bin ZTC-ZT6668-Smile_E553_X9PAPAARTF_E553_GPRS_MT6226_S01.01_1_16 m_Ru_Fr_En_Th_Ar_w_eeprom.B0M(3).bin COM3 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection disabled eeprom backup enabled, it may takes several minutes ! Action: write NOR flash "smart write" active write: Firmware skip: Customization/Language Pack skip: Customization write: Eeprom/ffs enhanced security fix enabled Boot... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:6386:1681 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:76737200000000 flash: Samsung D 16Mb detecting chip #01 in region #00... flash: EC257E25082501:76737200000000 flash: Samsung D 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 460800 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:76737200000000 flash: Samsung D 16Mb detecting chip #01 in region #00... flash: EC257E25082501:76737200000000 flash: Samsung D 16Mb it's time to stop: 76657273696F6E3A30320000000000000000000000000000 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. ............................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset assigned: 00E00000 flash: EC257E25082501:76737200000000 checking area[00000000]: 00000000-00FFFFFF... Can't detect eeprom/ffs area Do you want to use standard ffs address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs address selected by user detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading [eeprom]... file saved: H:\Program Files\InfinityBox\ChineseMiracle\eeprom_20080712-124628.B0E.bin flash: EC257E25082501:76737200000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. ............................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished security area#1 calculation... done Area: Firmware flash: EC257E25082501:76737200000000 Write: Firmware Area: Eeprom/ffs flash: EC257E25082501:29EA0000000000 Write: Eeprom/ffs detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished Write Done Finalization... Finalization Done Finished, time used: 1402 sec Remove/Install battery now ! |
| | #4 (permalink) |
| chines miracle detect first that is New firmware detected: E553_X9PAPAARTF_E553_GPRS_MT6226_S01.01_1.BIN - make "Read full flash" operation - send "backup_system_log_..." file to support: mt62xx@gmail.com - send flash backup file(s) to support: mt62xx@gmail.com - include in your e-mail full text from phone back label (phone name etc.) ==================== identification#1 detection finished device-id: 3B89E71D identification#1 protocol ver: 04 ver. sw1: E553_X9PAPAARTF_E553_GPRS_MT6226_S01.01_1.BIN ver. sw2: E553_X9PAPAARTF.01.1, FFB3AAEC |
| | #5 (permalink) |
| orignal is ver. sw1: E553_X9PAPAARTF_E553_GPRS_MT6226_S01.01_1.BIN ver. sw2: E553_X9PAPAARTF.01.1, FFB3AAEC ![]() i flash it ZTC-ZT6668E553_X9PAPAARTF_E553_GPRS_MT6226_S01.01_1__1 6m_Ru_Fr_En_Th_Vn_Cn_Hi_Cn_Ar.B0M.bin loaded identification#1 protocol ver: 04 ver. sw1: E553_X9PAPAARTF_E553_GPRS_MT6226_S01.01_1.BIN ver. sw2: E553_X9PAPAARTF.01.1, 9D6E0918 ![]() small differnt in ver sw2 if some one have same ver plz give me |
| | #6 (permalink) |
| Product Supporter ![]() ![]() ![]() Join Date: May 2005 Age: 36
Member: 148515 Status: Offline Thanks: 2,319
| hello! sad that you did not follow program advice and not backuped original firmware. some chinese firmwares are different even if name is same. this is your case. Now in order to reapir your phone you must find exactly same model on your local market and read out backup |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| 6120c mic point dameg plz help | ..:::Gsm india:::.. | Nokia Hardware & Hardware-Repair Area | 5 | 10-16-2012 05:02 |
| 1202 auto on battery in automatic on water dameg set plz helpe me | faheemkhan | Nokia Hardware & Hardware-Repair Area | 2 | 07-30-2010 09:30 |
| lg kg270 sim point dameg plz help me | ..:::Gsm india:::.. | LG | 1 | 09-29-2008 08:20 |
| n3310water dameged plz help | mahmoud | Nokia Hardware & Hardware-Repair Area | 5 | 11-03-2002 00:14 |
| how to unlock Alcatel HE1 v300 via Eeprom ??? plz HELP | Svetli | Alcatel & TCL Old Models | 10 | 06-05-2000 18:34 |
