05-28-2011, 17:09 | #1 (permalink) |
Freak Poster Join Date: Aug 2009 Location: nobody is perfect and i'm 1
Member: 1105427 Status: Offline Sonork: I don't use sonork Thanks Meter: 57 | Infinty team please help COM16 [VCP0] selected module v3.30 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6227:8A02:8A01]... CPU: MT6227 high speed boot On chip: 0031:E441710 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 89880F00010001:89880F00000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: 89880F00010001:89880F00000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb otp offset: 00000000 detecting chip #02 in region #00... flash: 89880F00010001:89880F00000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb otp offset: 00000000 detecting chip #03 in region #00... flash: 89880F00010001:89880F00000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 89880F00010001:89880F00000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: 89880F00010001:89880F00000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb otp offset: 00000000 it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (04) TCL-ID is absent rom info detection finished rom info ver: 04 sw version: D122_A212_PCB01_GPRS_MT6227_S01.D122_A212_1_01_0.B IN project-id: D122_A212_1.01.0, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [standard] type (04) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: 89880F00010001:89880F00000000 checking area [00000000]: 00080000-00FFFFFF... Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs/eeprom address selected by user detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF firmware area: 00000000-00DFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: D122_A212_PCB01_GPRS_MT6227_S01.D122_A212_1_01_0__ ffs... file saved: C:\InfinityBox\ChineseMiracle\D122_A212_PCB01_GPRS _MT6227_S01.D122_A212_1_01_0__ffs_20110528-083801.B0E.bin flash: 89880F00010001:89880F00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 89880F00010001:89880F00000000 Finalization Done Finished, time used: 9 min 26 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
05-29-2011, 21:44 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! download and flash your phone by following file: flashfiles/1MTK/_MT6227/D122_A212_PCB01_GPRS_MT6227_S01.D122_A212_1_01_0__ SONG-W668_16m_En_Cn__w_eeprom.B0M.bin |
Winlock 1.10 - Help | rdmfs | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 06-25-1999 08:21 |
