Old 12-22-2008, 18:12   #1 (permalink)
redouane2007's Avatar
Member: 523957
Thanks Meter: 118
by infinyti hlp mi in phone chinse v180
COM3 [VCP0] selected
module v2.71
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: "format ffs"
eeprom backup enabled, it may takes several minutes !
Boot ...
19200 fixed
Connecting, wait...
Initializing [6226:8A02:8A01]...
CPU: MT6226
high speed boot Off
chip: 0031:BEEE:0102
high speed boot Off
boot packet size: 0002
Release Power button now !
Boot Done
Initialize ...
flash: EC257E25082501:FFFFFF00000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud ...
115200
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
device parameters autodetection in progress...
Warning: probably flash chip empty, erased, incorrectly flashed or damaged.
What to do:
1. go to software "Settings" page
2. set "Advanced chip detection method" box UN-CHECKED !
3. make flash write operation
If still no luck: send mail to support ([email protected]) with detailed description of problem,
attach the next files in your e-mail:
1. C:\Program Files\InfinityBox\ChineseMiracle\operation.log
2. C:\Program Files\InfinityBox\ChineseMiracle\cfi_xxxx_xxxx.bin
it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detection phase #2...
warning: identification#1 information not found, possible reasons:
.old firmware type w/o identification#1 data
.damaged firmware
.damaged hardware
if phone works fine just ignore this warning
detect device identification#1 finished
detect device identification#2...
warning: optional information is not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset assigned: 00E00000
checking area [00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00E00000
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
reading: eeprom...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom_20081222-170633.B0E.bin
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
Write Done
Finalization ...
formatting...
Finalization Done
Finished, time used: 613 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
file: eeprom[N818_PCB01_GPRS_MT6227_S01.BIN]_20081222-161121.B0E.bin
file structure: Infinity-Box
Loading file v.02...
eeprom[N818_PCB01_GPRS_MT6227_S01.BIN]_20081222-161121.B0E.bin loaded
file size: 0x00200000, 2Mb
file type: eeprom/ffs or unknown firmware part
file: eeprom[N618_PCB01_GPRS_MT6227_S01.BIN]_20081220-122832.B0E.bin
eeprom[N618_PCB01_GPRS_MT6227_S01.BIN]_20081220-122832.B0E.bin loaded
error: wrong file size[0x00000200]: C:\Program Files\InfinityBox\ChineseMiracle\cfi_00EC_257E_250 8_2501.bin
file: eeprom[N618_PCB01_GPRS_MT6227_S01.BIN]_20081204-140914.B0E.bin
eeprom[N618_PCB01_GPRS_MT6227_S01.BIN]_20081204-140914.B0E.bin loaded
What is the solution
Old 12-22-2008, 19:06   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
Please explain what is the problem exactly so we will be able to understand the problem well.
Old 12-22-2008, 19:26   #3 (permalink)
deepakgarg's Avatar
Member: 220603
Thanks Meter: 1,164
first ur phone has damaged firmware.second u have selected wrong files as ur phone has mt6226 cpu n u r using mt6227 cpu files.if u cant find v180 firmware on support area then read full flash from a working v180 and flash ur phone with it
The Following User Says Thank You to deepakgarg For This Useful Post:
Old 12-23-2008, 08:21   #4 (permalink)
Member: 523957
Thanks Meter: 118
by infinity
the phone not power is demaged
the solution ????
plz
the phone is chinoise nokia v180
Old 12-23-2008, 17:20   #5 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
we cant advice correct flash file, because it is unreadable.
now only way to repair it- is search flash file by model name and try them all in your phone.
here is example of searching in support area:
http://forum.gsmhosting.com/vbb/showthread.php?t=499453
your search keyword is "v180"
Old 12-23-2008, 17:20   #6 (permalink)
Member: 148515
worth to make format FFS complete after each tryed flash file
Permanent Memory Tool v0.4 not work.hlp mi?? hazar Genie Universal 2 01-12-2010 10:22
genie universal pls hlp mi? hazar Genie Universal 2 01-10-2010 11:53
bu infinity hlp mi in this pb new cpu redouane2007 Infinity-Box 3 04-12-2009 18:02
Page generated in 0.17642 seconds with 9 queries
