Old 05-27-2016, 12:53   #1 (permalink)
diesel6's Avatar
Member: 315867
Sonork: 100.1654770
Thanks Meter: 708
intex aqua strong flash done but bseband become unkown
i have readed flash file with cm2 when i flash it to other phone
its shows baseband unkwon
here is the logs
======= Flash
Files set for flashing :
[ MCU ] : SC77xx Infinity Package
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
3. Insert cable
==== Wait for phone...
Phone found! [ 23 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : SC7715 Loader NAND v1.1 Infinity
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
PMTManager : Load 0x16 records
PMTManager : PMT Update Ok!
Flashing now
Update BootCode : u-boot-spl-16k.bin
Write Data ...
Write Data Ok!
Update BootCode : u-boot.bin
Write Data ...
Write Data Ok!
Write FSImage : prodnv_b128k.img
Write Data ...
Write Data Ok!
Erase Block : RuntimeData
Erase block ...
Block erase Ok!
Erase block ...
Block erase Ok!
Write CodeData : sc7715_modem.bin
Write Data ...
Write Data Ok!
Write CodeData : DSP_DM_Gx.bin
Write Data ...
Write Data Ok!
Write CodeData : CP2._CP2_WCN_14C_W15.18_Release.bin
Write Data ...
Write Data Ok!
Write CodeData : logo_480x854.bin
Write Data ...
Write Data Ok!
Write CodeData : boot.img
Write Data ...
Write Data Ok!
Write FSImage : system_b128k.img
Write Data ...
Write Data Ok!
Write FSImage : cache_b128k.img
Write Data ...
Write Data Ok!
Write CodeData : recovery.img
Write Data ...
Write Data Ok!
Write FSImage : userdata_b128k.img
Write Data ...
Write Data Ok!
Elapsed: 00:02:06
Reconnect Power/Cable!
Old 05-27-2016, 15:09   #2 (permalink)
Member: 1778833
Thanks Meter: 10
here is the logs
======= Flash
3. Insert cable
Phone found! [ 23 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Flashing now
Write Data ...
Write Data Ok!
Write Data ...
Write Data Ok!
Write Data ...
Write Data Ok!
Erase block ...
Block erase Ok!
Erase block ...
Block erase Ok!
Write Data ...
Write Data Ok!
Write Data ...
Write Data Ok!
Write Data ...
Write Data Ok!
Write Data ...
Write Data Ok!
Write Data ...
Write Data Ok!
Write Data ...
Write Data Ok!
Write Data ...
Write Data Ok!
Write Data ...
Write Data Ok!
Write Data ...
Write Data Ok!
Elapsed: 00:02:06
reflash with this firmware
http://https://docs.google.com/uc?id...Wt6TjRrc3Jnbkk
Old 05-27-2016, 15:16   #3 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Hello,
Check Update NVM option and flash again.
If still remains same flash with same version as written on phone back sticker.
Br.
Infinity Box Support Team.
Old 05-28-2016, 06:00   #4 (permalink)
diesel6's Avatar
Member: 315867
Sonork: 100.1654770
Thanks Meter: 708
Originally Posted by PASSIONATE_BOYS View Post
Hello,
Br.
already flash with update nvm and also y with tick both options erase and update nv but smae problem
already flash with back sticker verison but problem remains still same
Old 05-28-2016, 06:02   #5 (permalink)
diesel6's Avatar
Member: 315867
Sonork: 100.1654770
Thanks Meter: 708
Originally Posted by jason_s View Post
link is not vailed pls update the link
Old 05-29-2016, 08:14   #6 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
After flash erase on nand phone, in some cases, required make flashing again without "erase" enabled, if device stuck or semi-working.
Page generated in 0.17186 seconds with 8 queries
