12-28-2010, 11:04 | #1 (permalink) |
No Life Poster Join Date: May 2005 Age: 40
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | IPhone with Internal Memory "No Memory Card".. phone is not detecting internal memory..gives error after opening the camera "No Memory Card"... i tried complete phone format but nothing changed.. is this can be h\w pb.? Detailed information.. Code: COM5 [VCP0] selected module v3.25 Device: Autodetect 6228-6253 NAND Checking data, wait... Action: read/check information interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6225:8A05:8A00 status: FF bbchip bl ver: FE NOR flash id[007C]: 00EC:257E25082501 [SAMSUNG] K5L2931CAM chip size: 16Mb otp status/size: S_DA_NOR_OTP_NOT_SUPPORT/00000000 NAND flash chip: not installed internal RAM size: 0000C000 external RAM: S_DA_RAM_ERROR done Set baudrate (921600)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 00000000/00000000 detect sec ro... detect custom parameters... detect project-id... project-id: ONECOM_V188 detect NOR info... number of areas/bytes to read: 1:00040000 reading (HW_STORAGE_NOR)... TCL-ID detection... TCL-ID detection done startup code area #1 detection... number of areas/bytes to read: 1:00004000 reading (HW_STORAGE_NOR)... number of areas/bytes to read: 1:00004000 reading (HW_STORAGE_NOR)... error: unexpected answer: startup code area #1 is valid startup code area #1 detection done rom info ver: 05 sw version: HR25_08A_GEMINI_PCB01_GPRS_MT6225_S00.ONECOM_V188.BIN project-id: ONECOM_V188, 36E34B38 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [protected] type (05), 1 record(s) TCL-ID is absent ===> done Disconnect... done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\HR25_08A_GEMINI_PCB01_GPRS_MT6225_S00.ONECOM_V188__system_log_20101228-120303.B4X.bin Finished, time used: 39 sec Remove/Install battery now ! |
12-28-2010, 14:28 | #2 (permalink) | |
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | Quote:
anyone has any idea..? | |
12-30-2010, 09:42 | #5 (permalink) | |
Freak Poster Join Date: Dec 2006 Location: Khartoum-Sudan
Member: 420318 Status: Offline Sonork: 100.1661057 Thanks Meter: 65 | Quote:
just open the back cover ( you will find sd card inside ) just change it wiz good one | |
The Following User Says Thank You to sudsud For This Useful Post: |
NHE_8 wont work with NHEK5689.dll v3 | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 07-23-1999 15:48 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-09-1999 17:04 |
