11-23-2008, 05:26
#1 (permalink)
Member: 486305
Thanks Meter: 465 | Iphone Q380A+ dead Done by Infinity[Pinout's Inside] Iphone Q380A+ dead Done by Infinity[Pinout's Inside]
Problem;
Dead
Procedure;
-Open Infinity Shell/select Brand [Chinese-Miracle]/ Model [Other-China-clone-model]/ Click run
-Select com/Select Complete/click format ffs/power on the phone
Pinout's;
Formating; Quote:
COM6 [VCP0] selected
module v2.68
Device: Autodetect 6205-6227 NOR
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: "format ffs"
Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A03:8A00]...
CPU: MT6225
high speed boot enabled
chip: 0001:7F03:0003
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: EC257E25082501:18E59F00000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud ...
115200
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
device parameters autodetection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [standard] generation
identification#1 protocol ver: 04
ver. sw 1: M6225_DUAL_PCB01_GPRS_MT6225_S00.Z618_SW_FMBT_MLAN G01_01B03.BIN
ver. sw 2: Z618_SW_FMBT_MLang01.01b03, 00000000
ffs offset/size: 00E00000/00200000
detect device identification#2...
warning: optional information is not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00E00000
checking area [00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00E00000
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
reading: eeprom[M6225_DUAL_PCB01_GPRS_MT6225_S00.Z618_SW_FMBT_MLAN G01_01B03.BIN]...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[M6225_DUAL_PCB01_GPRS_MT6225_S00.Z618_SW_FMBT_MLAN G01_01B03.BIN]_20081123-112515.B0E.bin
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
write ...
write Done
Finalization ...
formatting...
Finalization Done
Finished, time used: 541 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
| Write Imei; Quote:
module v2.68
Action: imei
imei write method: mode-2
imei write channel: imei #2 for dual sim/mono CPU
new imei: 368801008865153
Model: Autodetect 6205-6227 NOR
19200 autodetect
CPU: MT6225
Connecting, wait...
Phone detected, wait...
Hardware: MT6225,E03
Date: 2006.06.14
Version: 1.0
Version: Z618_SW_FMBT_MLang01.01b03
Version: M6225_DUAL
detecting structure #2...
5 11Done
67 byte(s) read
imei: 36880100886593
connection Ok
5 11Done
67 byte(s) read
verification...
verification done: 36880100886515
Finished, time used: 20 sec
| Viola; |
