03-02-2011, 14:42 | #1 (permalink) |
Registered User Join Date: Mar 2007 Location: Bandung, Indonesia
Member: 461468 Status: Offline Thanks Meter: 139 | K-Touch D780 GSM CDMA on Browser Problem Please help!!!! I get a chinese phones with label K-Touch D780 GSM CDMA on, with problem " internet browser " when try to press browser phone restarting. All other function normaly working. I have try to formated phone with CM v.3.27 phone become DEAD that i tried to reflash with backup flash files, not work due unknown firmware. I have send backup flash files from before formated to [email protected] directly. TBD170043_1250_PCB04_GPRS_MT6228_S02.170043_1250_V 9022__firmware_20110301-205640.B4M.rar - 4shared.com - online file sharing and storage - download Thanks for ur kind attention and reply. WBR, |
03-02-2011, 23:11 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hi, File downloaded. We need to make some changes in software to make it working with your phone/firmware. Did you flashed phone with your file already or you just tried to flash it and interrupted process when software say about "new firmware" ? |
03-03-2011, 03:16 | #3 (permalink) |
Member: 461468 Status: Offline Thanks Meter: 139 | Hi, Thanks for ur quick reply. Yes, I have try flash phone with backup files but not success still dead and try 2nd flash not working with DA error! Waiting ur info n updates. Thanks so much WBR, |
03-03-2011, 03:33 | #4 (permalink) | |
select model f.e. Fly-SX220 and flash your phone with your backup file. post here results | |
03-03-2011, 06:00 | #5 (permalink) |
Member: 461468 Status: Offline Thanks Meter: 139 | Hi, Thanks for ur quick reply. I was trying as per ur info but still not work, herewith log: COM10 [VCP0] selected module v3.78 Device: Fly-SX220 Checking data, wait... Action: write flash NAND write: Firmware TBD170043_1250_PCB04_GPRS_MT6228_S02.170043_1250_V 9022__firmware_20110301-205640.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nfi area detection... external bootloader is not present bootloader version: BOOTLOADER_170043_1250_V9022.bin nfi area detection (3 cores) finished: Ok interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6228:8A02:8A02 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0043]: 0098:00F000800095 [TOSHIBA] TC58NWM9S3B chip size: 64Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00020000 external RAM: S_DA_RAM_ERROR done Set baudrate (115200)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... detect sec ro... detect custom parameters... detect project-id... detect NAND info... number of areas/bytes to read: 1:00080000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... warning: header is empty: probably flash chip completely erased warning: can not detect header nfi area detection (0 cores) finished: failed warning: ffs can not be detected TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done code offset: 00000000 ===> done nfi area detection... external bootloader is not present bootloader version: BOOTLOADER_170043_1250_V9022.bin nfi area detection (3 cores) finished: Ok startup code area #1 check... startup code area #1 calculation... startup code area #1 fixed number of cores: 3 loading files... number of areas: 3 done write... write core... error: can not write flash: 0BEA:S_DA_NFB_BOOTLOADER_NOT_EXIST error: last error: 0BEA:S_DA_NFB_BOOTLOADER_NOT_EXIST Disconnect... done Finished, time used: 1 min 24 sec Remove/Install battery now ! Please info! how to solve this? Thanks so much for ut kind attenion. WBR, |
03-03-2011, 06:45 | #7 (permalink) |
Member: 461468 Status: Offline Thanks Meter: 139 | Hi, same problems, herewith log: COM10 [VCP0] selected module v3.27 Device: Autodetect 6228-6253 NAND Checking data, wait... Action: write flash NAND write: Firmware TBD170043_1250_PCB04_GPRS_MT6228_S02.170043_1250_V 9022__firmware_20110301-205640.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nfi area detection... external bootloader is not present bootloader version: BOOTLOADER_170043_1250_V9022.bin nfi area detection (3 cores) finished: Ok interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6228:8A02:8A02 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0043]: 0098:00F000800095 [TOSHIBA] TC58NWM9S3B chip size: 64Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00020000 external RAM: S_DA_RAM_ERROR done Set baudrate (115200)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... detect sec ro... detect custom parameters... detect project-id... detect NAND info... number of areas/bytes to read: 1:00080000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... warning: header is empty: probably flash chip completely erased warning: can not detect header nfi area detection (0 cores) finished: failed warning: ffs can not be detected TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done code offset: 00000000 ===> done nfi area detection... external bootloader is not present bootloader version: BOOTLOADER_170043_1250_V9022.bin nfi area detection (3 cores) finished: Ok startup code area #1 check... rpl file not found: C:\InfinityBox\ChineseMiracle\id.00006228.[TBD170043_1250_PCB04_GPRS_MT6228_S02.170043_1250_V 9022.BIN_E0CCAC5D].rpl rpl file not found: C:\InfinityBox\ChineseMiracle\id.00006228._TBD1700 43_1250_PCB04_GPRS_MT6228_S02.170043_1250_V9022.BI N_E0CCAC5D_.rpl rpl file not found: C:\InfinityBox\ChineseMiracle\backup_security\id.0 0006228.[TBD170043_1250_PCB04_GPRS_MT6228_S02.170043_1250_V 9022.BIN_E0CCAC5D].rpl rpl file not found: C:\InfinityBox\ChineseMiracle\backup_security\id.0 0006228._TBD170043_1250_PCB04_GPRS_MT6228_S02.1700 43_1250_V9022.BIN_E0CCAC5D_.rpl ==================== warning: unknown firmware: TBD170043_1250_PCB04_GPRS_MT6228_S02.170043_1250_V 9022.BIN_E0CCAC5D Unknown firmware found (v.3.27, database date: 03.03.2011), user action required: 1. download latest software from support area and try again 2. if no still luck follow the next procedure: - find good working phone with the same firmware: TBD170043_1250_PCB04_GPRS_MT6228_S02.170043_1250_V 9022.BIN - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) - be little bit patient and wait update ==================== error: startup code area #1 can't be fixed You can flash phone now but can not finalize it, in most cases phone CAN NOT power-on. Do you want to continue anyway ? number of cores: 3 loading files... number of areas: 3 done write... error: can not write flash: 0BBF:S_DA_RAM_ERROR error: last error: 0BBF:S_DA_RAM_ERROR Disconnect... done Finished, time used: 1 min 45 sec Remove/Install battery now ! please info! WBR, |
03-03-2011, 06:50 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hi, it's looks like your phone flash chip completely erased, at least software can not read any correct data from phone. Did you flashed or erased flash before ? Also, it may be a result of (partially) damaged or bad soldered flash chip or other hardware problem. Are you sure that phone has no hardware damage ? |
03-03-2011, 07:42 | #9 (permalink) |
Member: 461468 Status: Offline Thanks Meter: 139 | Hi, Yes, phone have erased after flashing with backup files due phone still dead. And then I tried to flash phone and formated again but not works. Phone is working well before formated FFS, just BROWSER problem and I am sure flash chip is okay. Please help! how to solve this problem? Thanks for ur attention and kind help. WBR, |
03-04-2011, 12:54 | #11 (permalink) |
Member: 461468 Status: Offline Thanks Meter: 139 | Hi, InfinitySupport I tried to flash phone used Flash Tool v. 3.1044 with original files but different version V2744 and project id from backup phone V9022. Phone live in K-Touch logo only. And try formated with MModule SX220, CM still same problem and then I tried to flash with backup file used MModule Phone back to dead. See this log: COM10 [VCP0] selected module v3.78 Device: Fly-SX220 Checking data, wait... Action: write flash NAND write: Firmware TBD170043_1250_PCB04_GPRS_MT6228_S02.170043_1250_V 9022__firmware_20110301-205640.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs firmware patch (sp-lock #1)... not required firmware patch (sp-lock #2)... not required nfi area detection... external bootloader is not present bootloader version: BOOTLOADER_170043_1250_V9022.bin nfi area detection (3 cores) finished: Ok "format ffs" active interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6228:8A02:8A02 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0043]: 0098:00F000800095 [TOSHIBA] TC58NWM9S3B chip size: 64Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00020000 external RAM: S_DA_RAM_ERROR done Set baudrate (115200)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/02000000 firmware size: 32Mb ffs size: 32Mb detect sec ro... detect custom parameters... detect project-id... project-id: 170027_1246_V2744 detect NAND info... number of areas/bytes to read: 1:00080000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... external bootloader is not present bootloader version: BOOTLOADER_170027_1246_V2744.bin nfi area detection (3 cores) finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... number of areas/bytes to read: 1:00020000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... number of areas/bytes to read: 1:00020000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... error: unexpected answer: startup code area #1 is valid startup code area #1 detection done rom info ver: 04 sw version: TBD170027_1246_PCB04_GPRS_MT6228_S02.170027_1246_V 2744.BIN project-id: 170027_1246_V2744, 5F3E8D86 code offset: 00000000 ffs offset/size [01]: 02000000/02000000 rom info structure: [protected] type (04), 1 record(s) TCL-ID is absent ===> done ==================== New firmware found (v.3.78, database date: 03.03.2011): TBD170027_1246_PCB04_GPRS_MT6228_S02.170027_1246_V 2744.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== nfi area detection... external bootloader is not present bootloader version: BOOTLOADER_170043_1250_V9022.bin nfi area detection (3 cores) finished: Ok startup code area #1 check... startup code area #1 calculation... startup code area #1 fixed number of cores: 3 loading files... number of areas: 3 done write... write core... Please help! and did you have bootloader version V9022. Thanks for attention n reply WBR, |
03-04-2011, 12:59 | #12 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
Wr. | |
03-04-2011, 13:17 | #13 (permalink) |
Member: 461468 Status: Offline Thanks Meter: 139 | Hi, Flash with Fly SX220 log: COM10 [VCP0] selected module v3.78 Device: Fly-SX220 Checking data, wait... Action: write flash NAND write: Firmware TBD170043_1250_PCB04_GPRS_MT6228_S02.170043_1250_V 9022__firmware_20110301-205640.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs firmware patch (sp-lock #1)... not required firmware patch (sp-lock #2)... not required nfi area detection... external bootloader is not present bootloader version: BOOTLOADER_170043_1250_V9022.bin nfi area detection (3 cores) finished: Ok "format ffs" active interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6228:8A02:8A02 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0043]: 0098:00F000800095 [TOSHIBA] TC58NWM9S3B chip size: 64Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00020000 external RAM: S_DA_RAM_ERROR done Set baudrate (115200)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/02000000 firmware size: 32Mb ffs size: 32Mb detect sec ro... detect custom parameters... detect project-id... project-id: 170027_1246_V2744 detect NAND info... number of areas/bytes to read: 1:00080000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... external bootloader is not present bootloader version: BOOTLOADER_170027_1246_V2744.bin nfi area detection (3 cores) finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... number of areas/bytes to read: 1:00020000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... number of areas/bytes to read: 1:00020000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... error: unexpected answer: startup code area #1 is valid startup code area #1 detection done rom info ver: 04 sw version: TBD170027_1246_PCB04_GPRS_MT6228_S02.170027_1246_V 2744.BIN project-id: 170027_1246_V2744, 5F3E8D86 code offset: 00000000 ffs offset/size [01]: 02000000/02000000 rom info structure: [protected] type (04), 1 record(s) TCL-ID is absent ===> done ==================== New firmware found (v.3.78, database date: 03.03.2011): TBD170027_1246_PCB04_GPRS_MT6228_S02.170027_1246_V 2744.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== nfi area detection... external bootloader is not present bootloader version: BOOTLOADER_170043_1250_V9022.bin nfi area detection (3 cores) finished: Ok startup code area #1 check... startup code area #1 calculation... startup code area #1 fixed number of cores: 3 loading files... number of areas: 3 done write... write core... error: can not write flash: 0FA9:S_FT_DOWNLOAD_CHKSUM_MISMATCH error: last error: 0FA9:S_FT_DOWNLOAD_CHKSUM_MISMATCH Disconnect... done file saved: C:\InfinityBox\MModule\backup_security\Fly-SX220_TBD170043_1250_PCB04_GPRS_MT6228_S02.170043_ 1250_V9022__system_log_20110304-191443.B4X.bin Finished, time used: 33 min 45 sec Remove/Install battery now ! |
03-04-2011, 13:18 | #14 (permalink) |
Member: 461468 Status: Offline Thanks Meter: 139 | Hi, Format with Complete mode: COM10 [VCP0] selected module v3.78 Device: Fly-SX220 Checking data, wait... Action: reset settings ("format ffs") NAND interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6228:8A02:8A02 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0043]: 0098:00F000800095 [TOSHIBA] TC58NWM9S3B chip size: 64Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00020000 external RAM: S_DA_RAM_ERROR done Set baudrate (115200)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... detect sec ro... detect custom parameters... detect project-id... detect NAND info... number of areas/bytes to read: 1:00080000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... warning: core offset is not detected nfi area detection (0 cores) finished: failed warning: ffs can not be detected TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done code offset: 00000000 ===> done warning: can not format: HW_STORAGE_NOR is not present Format... error: can not format: 0BFA:S_DA_HANDSET_FAT_INFO_NOT_FOUND Format... error: can not format: 0BFA:S_DA_HANDSET_FAT_INFO_NOT_FOUND error: last error: 0BFA:S_DA_HANDSET_FAT_INFO_NOT_FOUND Disconnect... done Finished, time used: 1 min 22 sec Remove/Install battery now ! |
03-04-2011, 23:07 | #15 (permalink) | |
According to this information I think that phone may have hardware problems (f.e. partially damaged or bad soldered flash chip). Yes, I understand that before phone had problem with wap only, but that fault may be a result of hw damage too. | |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
