09-29-2010, 01:24 | #1 (permalink) |
Freak Poster Join Date: Apr 2008
Member: 744651 Status: Offline Thanks Meter: 20 | K688 cannot write IMEI I have here a K688 dual sim phone, a chinese copy of the HTC Snap. I have several of them that i needed to format complete to sort out some software issues. However, after format, i cannot write the imei to them, they are MT6235 and i use mode one and two, but nothing, even set rate to autodetect and have set to NAND. I have even tried to write imei to units some ofthem even before format, but still nothing. Here a log from one of my attempts: COM10 [VCP0] selected module v3.07 Action: "repair imei" imei write method: mode-2 imei write channel: imei #1 for dual sim/mono CPU new imei: 35768801000xxxx Model: Autodetect 6228-6239 NAND Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 high speed boot On chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235,E04 Date: 2000.00.00 Version: 1.0 Version: E702_BLJ1K2.01.0 Version: EVEN35_08B_HW detecting structure #2... 1 4 5 7 8 9 11warning: wrong packet cs 12 16 19 20 22 23 24 26 27error: detection failed (16 tries), read flash and send to support connection Ok detecting structure #2... 1warning: wrong packet cs 4 5 7 8 9 11 12 16 19 20 22 23 24 26 27error: detection failed (16 tries), read flash and send to support error: can't read required data error: operation failed ! Finished, time used: 15 sec Remove/Install battery now ! Your help as always will be welcome. |
09-29-2010, 17:21 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! i had similar phone yesterday, we had to modify software to make IMEI writing done. same story with your phone. please upload your phone flash file to rapidshare and post hre link |
09-30-2010, 03:13 | #3 (permalink) |
Member: 744651 Status: Offline Thanks Meter: 20 | Hi Masters, Thanks for your quick reply, i have read firmware on one of these units and uploaded files to rapidshare as you requested. This is the link: http://rapidshare.com/files/42223583...184533.B4M.bin I have two questions: 1) after you have this file, then what?....will you give me solution here?...please advise. 2) this is just a read of one unit, i have 9 units that need to flash, do i have to read all of them and send you individual files? You quickest response will be greatly appreciated. Thanks Masters! |
09-30-2010, 18:46 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! if all 9 phones is same version- then 1 backup is just enough. we will check this file and improve software. i will let you know what to do next |
09-30-2010, 19:54 | #5 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @DualSimCell File downloaded, I hope new software will be released in short time. |
10-07-2010, 00:45 | #7 (permalink) | |
Member: 744651 Status: Offline Thanks Meter: 20 | Quote:
Ok, so I installed latest version of Chinese Miracle, but still same, no problems to perform a format. When trying to write IMEI, it's just reaching to the point where it says "Connecting" and does not coonect. Your quickest response on a solution would be greatly appreciated. Thanks | |
10-08-2010, 01:00 | #9 (permalink) |
Member: 744651 Status: Offline Thanks Meter: 20 | Hi Master, Ok, here ya go, i'm using pinfinder V1.2 and Chinese Miracle V3.24 First Format, here is a read: COM10 [VCP0] selected module v3.24 Device: Autodetect 6228-6239 NAND Checking data, wait... Action: reset settings ("format ffs") NAND interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0058]: 002C:00A100800095 [MICRON] MT29F1G08ABB chip size: 128Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: S_DA_RAM_ERROR done Set baudrate (115200)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 03000000/05000000 firmware size: 48Mb ffs size: 80Mb detect sec ro... detect custom parameters... detect project-id... project-id: E702_BLJ1K2.01.0 detect NAND info... number of areas/bytes to read: 1:001A0000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... external bootloader is not present bootloader version: E702_BOOTLOADER_V005_MT6235B_01_1.bin nfi area detection (3 cores) finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 05 sw version: E702_BLJ1K2_PCB01_GPRS_MT6235B_S01.01_0.BIN project-id: E702_BLJ1K2.01.0, 00000000 code offset: 00000000 ffs offset/size [01]: 03000000/05000000 rom info structure: [standard] type (05) TCL-ID is absent ===> done Format (HW_STORAGE_NAND)... Disconnect... done Finished, time used: 3 min 13 sec Remove/Install battery now ! ********* WRITING IMEI#2 WITH MODE-2 ********** COM10 [VCP0] selected module v3.24 Action: "repair imei" imei write method: mode-2 imei write channel: imei #2 for dual sim/mono CPU new imei: 3570688000***** Model: Autodetect 6228-6239 NAND Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 high speed boot On chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... warning: wrong packet cs warning: wrong packet cs error: can not finalize test mode repeat operation and HOLD phone "Power" button more long time ! error: operation failed ! Finished, time used: 2 min 33 sec Remove/Install battery now ! ************WRITING IMEI#2 WITH MODE-1 Action: "repair imei" Model: Autodetect 6228-6239 NAND Checking data, wait... Phone should be Switched ON ! Connecting, wait... error: connection failed ! If you are sure that cable is good - select another baudrate (f.e. set baudrate to "autodetect") operation failed ! Finished, time used: 1 min 12 sec Remove/Install battery now ! I'm tried different setting and all the same, really confused here, because connection for format is great, but to write IMEI, as you can see...nothing. |
10-08-2010, 17:06 | #10 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! best way now is to try change IMEI over bluetooth. IMEI change without cable over Bluetooth link step-by-step tutorial - GSM-Forum try it and reply |
what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-31-2012 20:09 |
Nokia 51xx/61xx imei changer ver. 1.10?????? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 04-06-2012 16:22 |
6110 imei changer !!!!!! | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 11-21-2011 01:44 |
