09-19-2011, 10:22 | #1 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Algérie Age: 43
Member: 570252 Status: Offline Thanks Meter: 207 | looking for JOYTECH23C_09A_GEMINI_PCB01_GPRS_MT6223P_S00.GEWOO _A1823_6223D_09A_V45_0. Code: COM2 [VCP0] selected module v4.01 Device: _Autodetect MT6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") Do you want to make ffs/eeprom backup before format ? ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot Off chip: 0011:56C0:000C status: FF high speed boot Off boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22102201:2CEA0000000000 flash: Amd AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb otp offset: 007F0000 detecting chip #01 in region #00... flash: 01227E22102201:2CEA0000000000 flash: Amd AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb otp offset: 007F0000 detecting chip #02 in region #00... flash: 01227E22102201:2CEA0000000000 flash: Amd AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb otp offset: 007F0000 detecting chip #03 in region #00... flash: 01227E22102201:2CEA0000000000 flash: Amd AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb otp offset: 007F0000 detecting chip #04 in region #00... flash: 01227E22102201:2CEA0000000000 flash: Amd AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb otp offset: 007F0000 detecting chip #05 in region #00... flash: 01227E22102201:2CEA0000000000 flash: Amd AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb otp offset: 007F0000 detecting chip #06 in region #00... flash: 01227E22102201:2CEA0000000000 flash: Amd AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb otp offset: 007F0000 detecting chip #07 in region #00... flash: 01227E22102201:2CEA0000000000 flash: Amd AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb otp offset: 007F0000 number of flash chip/regions detected: 08/01 Initialize Done ====> Set baud ... 460800 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 01227E22102201:2CEA0000000000 flash: Amd AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb otp offset: 007F0000 detecting chip #01 in region #00... flash: 01227E22102201:2CEA0000000000 flash: Amd AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb otp offset: 007F0000 it's time to stop: 2C0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 00800000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (07) TCL-ID is absent ==================== New firmware found (v.4.01, database date: 19.08.2011): JOYTECH23C_09A_GEMINI_PCB01_GPRS_MT6223P_S00.GEWOO_A1823_6223D_09A_V45_0.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare – Secure Data Logistics or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info ver: 07 sw version: JOYTECH23C_09A_GEMINI_PCB01_GPRS_MT6223P_S00.GEWOO_A1823_6223D_09A_V45_0.BIN project-id: GEWOO_A1823_6223D_09A_V45.0, 00000000 code offset: 00000000 ffs offset/size [02]: 00730000/000D0000 rom info structure: [standard] type (07) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00730000 flash: 01227E22102201:2CEA0000000000 checking area [00000000]: 00080000-007FFFFF... ffs/eeprom found near: 00620000 Detected ffs/eeprom address is non-standard: 00620000 Posible reasons: 1. ffs/eeprom is Ok but address is non-standard 2. ffs/eeprom is damaged and can't be detected 3. ffs/eeprom is Ok but detected incorrectly (f.e. unknown ffs/eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make full flash backup for emergency case 3. repeat required operation Are you sure that detected ffs/eeprom address is correct ? Do you want to use standard ffs/eeprom address: 00730000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make full flash backup for emergency case 3. repeat required operation aborted by user operation aborted Finished, time used: 46 sec Remove/Install battery now ! Last edited by temp_temp; 09-19-2011 at 10:23. Reason: added code |
09-20-2011, 15:57 | #2 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, This exact version is not present on support area. But you can try with this closest file present on support- flashfiles/1MTK/_MT6223/8m/JOYTECH23C_09A_GEMINI_PCB01_GPRS_MT6223P_S00.GEWOO _A1823_6223D_09A_V30_0_2011-01-05_8m_En_Fr_Hi_Farsi_Ar.B0M.bin BTW what's the problem with your phone? Did you tried to format the phone? Wr. |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
09-26-2011, 18:27 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! try this file: flashfiles/1MTK/_MT6223/8m/JOYTECH23C_09A_GEMINI_PCB01_GPRS_MT6223P_S00.GEWOO _A1823_6223D_09A_V30_0_2011-01-05_8m_En_Fr_Hi_Farsi_Ar.B0M.bin |
needed pinout for carkit(N61xx) | mobileinfo | Nokia Hardware & Hardware Repair | 2 | 07-23-2013 02:41 |
Operator-Logo for 5110 | MiMiR the WiseMan | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 06-25-1999 15:50 |
