12-03-2008, 16:56 | #1 (permalink) |
No Life Poster Join Date: Jan 2007 Location: mumbai india
Member: 432679 Status: Offline Thanks Meter: 118 | M-Star GSM CDMA .. kindly assit! very soon i WILL MAIL THE BACKUP FILE . kindly assit what to do here is the log file COM8 [VCP0] selected module v2.70 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:E803:0005 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 01227E22202200:18A59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:18A59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 01227E22202200:18A59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:18A59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb it's time to stop: 18B09FA518B09FA518B09FA518B09FA518B09FA518B09FA5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. ............................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset assigned: 00E00000 flash: 01227E22202200:18A59F00000000 checking area [00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E40000 Detected eeprom/ffs address is non-standard: 00E40000 Posible reasons: 1. eeprom is Ok but address is non-standard 2. eeprom damaged and can't be detected 3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make flash backup for emergency case 3. repeat required operation Are you sure that detected eeprom address is correct ? autodetected eeprom/ffs address confirmed by user: 00E40000 detecting eeprom/ffs size... eeprom/ffs size: 001C0000 ffs chip: 00 eeprom/ffs area: 00000000:00E40000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... flash: 01227E22202200:18A59F00000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... formatting... flash: 01227E22202200:18A59F00000000 Finalization Done Finished, time used: 63 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! regards! |
12-03-2008, 19:32 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, NEVER SEND TO US FILES FROM DAMAGED PHONES !!! Try to flash phone several times with "smart write" option enabled. Try to flash phone with "advanced chip detection" off. If still no luck I suggest you to check phone hardware, g.,e. reball flash/cpu chip and check PCB carefully. |
12-03-2008, 20:33 | #3 (permalink) | |
No Life Poster Join Date: Dec 2004 Age: 50
Member: 98139 Status: Offline Thanks Meter: 126 | Quote:
kindly assit, MX KEY WILL DAMAGE MY P- KEY | syed.n | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 11-10-2009 09:36 |
New GSM CDMA forum...New GSM CDMA forum... | samirov-gsm | GSM Mobile Links | 0 | 04-24-2009 08:08 |
kindly assit to installl infinity | syed.n | Infinity-Box | 5 | 12-21-2007 11:01 |
For All Kinds Of Gsm,cdma Solution | Javajohn | GSM Mobile Links | 1 | 05-11-2006 10:40 |
XAK: GSM/CDMA/TDMA/WCDMA/AMPS Product Support Tools | Xak | Main Sales Section | 1 | 08-01-2002 21:40 |
