02-17-2009, 23:20 | #1 (permalink) |
No Life Poster Join Date: Feb 2003 Location: africa Age: 54
Member: 22284 Status: Offline Thanks Meter: 81 | May someone Help Original data below. ction: read information Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6225, E03 Hardware version: MT6225_GEMINI_HW Software version: M6225_00J6_XRX3_00_v Software date: 2006.06.14 Barcode: MT012345678901234567 imei: 354101000882868 imei: 135790246811220 Finished, time used: 5 sec Power off phone now ! COM25 [VCP1] selected module v2.73 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read/check detailed information Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:0A03:0003 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw 1: MT6225_GEMINI_PCB01_GPRS_MT6225_S00.M6225_00J6_XRX 3_00_V05.BINver. sw 2: M6225_00J6_XRX3_00_v05, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: EC257E25082501:18E59F00000000 checking area [00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF detecting ffs structure pass 1... ....................... detect standard fat location pass #1... .................................................. . detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs detected ok: element #1 detecting ffs structure pass 2... ....................... detect standard fat location pass #1... .................................................. . detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs detected ok element #2 Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... Finished, time used: 64 sec Remove/Install battery now ! [COLOR="red"]AFTER FLASH WITH THIS FILE FONE WORKS BUT WHITE DISPLAY. FLASHED FILE MT6225_GEMINI_PCB01_GPRS_MT6225_S00.M6225_00J6_XRX 2_00_V05_16m_En_Ru_Fr_It_De_Th_Vn_Pt.B0M.binHELP , May someone help to identify the flash which might work and brings my display on ,and works better. |
02-18-2009, 19:05 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, You do not need to flash phone to remove code !!! Solution is here: C:\Program Files\InfinityBox\Documentation\ChineseMiracle\Repair_White-screen_Black-screen.txt |
02-18-2009, 23:23 | #3 (permalink) |
Member: 22284 Status: Offline Thanks Meter: 81 | Yes as i have read the documentation and i rule out display problem cause before i flashed the display was working alright.I kow its something to do with the flash file. Original file was MT6225_GEMINI_PCB01_GPRS_MT6225_S00.M6225_00J6_XRX3_00_V05.BI and that off from support centre is MT6225_GEMINI_PCB01_GPRS_MT6225_S00.M6225_00J6_XRX2_00_V05.BI all am asking is you to help me if there is a file i may download from the support centre which could bring my display on again. They nare just too many so i woouldnt know which one to download. Help |
02-19-2009, 22:50 | #6 (permalink) |
No Life Poster Join Date: Mar 2008 Location: infinity-box
Member: 720034 Status: Offline Thanks Meter: 213 | Hello, If required file can not be found in support area (please use "search" function in support area first) it will be good if somebody can read full flash from the same good working phone and send full flash backup to [email protected] so we will be able to prepare and upload good working files in support area for all users. Please, DO NOT send to us backup files from damaged phones. We CAN NOT repair damaged files ! |
Please May Someone Help me!!! | jordizzee | Phone Unlocking Codes & Maps | 1 | 10-06-2009 02:09 |
Can someone help help me please?! Nokia 6111 | joel2esq | Nokia Base Band 5 ( BB-5 ) | 4 | 09-19-2009 20:34 |
Plz plz plz can someone help me 8700g blackberry i know someone is out there | sgreensky | BlackBerry (RIM) | 0 | 06-20-2009 05:36 |
hello may someone help me please?? | starteceg | Nokia Base Band 5 ( BB-5 ) | 1 | 10-02-2006 10:28 |
May someone help please K750i Ufx cable | chitawira | HWK | 2 | 09-24-2006 08:52 |
