04-21-2009, 21:21 | #1 (permalink) |
Insane Poster Join Date: Apr 2009
Member: 1012502 Status: Offline Thanks Meter: 2 | Mobile phone vs Infinity box Should I connect it via USB port (I mean left port on infinty box), or connect via com1 port (right port on infinity box). Is there any different? Next questions are: Which LED should shine? I saw only TX LED blinking, and sometimes RED LED shine, but I dont understand when und why which LED should shine, I cant read f.e. full flash, please help more detailed. Thanks |
04-21-2009, 21:24 | #2 (permalink) |
Member: 1012502 Status: Offline Thanks Meter: 2 | COM1 vs USB In real I dont thnik USB and COM1 port but it is RJ45 port with names: 1. on left RJ45 is name USB 2. on right RJ45 is name COM1 SO, I mean these two "ports" on BACK of infinity box, do you understand me? |
04-21-2009, 22:53 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, 1. read this: http://forum.gsmhosting.com/vbb/showthread.php?t=342807 2. How to write flash (upgrade/downgrade firmware, change language): 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Flash" page and load required files 8. press "Write" button and follow instruction given by software How to read flash: 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. press "Read flash" (or "Read full flash") button and follow instruction given by software How to unlock (remove sp-lock, provider lock etc.): 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. press "SP-Unlock" button and follow instruction given by software How to reset/format ffs (reset setting to default values, repair freez/restart etc.): - at first try to make "safe format" (if this option exist) - if "safe" option is not works try to make "complete" format (if this option exist) 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. select format mode "safe" or "complete" (if mode is available) 9. press "Reset" or "Format" button and follow instruction given by software |
i-Pmart BX Series RJ45 Cable Compatible For I-Mobile 600 For Infinity Box | IPMART | ipmart WebShop | 0 | 03-14-2009 03:50 |
i-Pmart BX Series RJ45 Cable Compatible For I-Mobile 510 For Infinity Box | IPMART | ipmart WebShop | 0 | 03-14-2009 03:50 |
spreadtrum chips vs infinity box | jhongtech | Infinity-Box | 8 | 02-07-2008 11:05 |
multi-box vs infinity box!!! | .::koolfriend4u::. | The Market Feed Back | 10 | 09-10-2006 10:35 |
