Old 06-26-2010, 13:05   #1 (permalink)
umarmsn's Avatar
Member: 616909
Sonork: 1672125
Thanks Meter: 648
model :i9++i after flash not power on
COM4 [VCP0] selected
module v3.15
Device: Autodetect 6205-6239 NOR
Checking data, wait...
Action: "repair imei"
imei write channel: imei #1 (default imei inside firmware)
new imei: 363297009060388
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:1703:000D
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: EC240200000000:18E59F00000000
flash: Samsung K5L2833ATA T 16Mb
otp offset: 00FF0000
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====> Set baud ...
230400
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: 2nd [standard] generation
TCL-ID is absent
rom info detection finished
New firmware detected (v.3.15, database date: 14.06.2010):
M5120_HRD_UI2_EN+FR+SP+PR+GE+GR+TU_128+32FLASH_A03 .BIN
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or 4shared.com - free file sharing and storage
- include in your e-mail full text from phone back label (phone name etc.)
rom info ver: 04
sw version: M5120_HRD_UI2_EN+FR+SP+PR+GE+GR+TU_128+32FLASH_A03 .BIN
project-id: M5120_HRD_UI2_EN+FR+SP+PR+GE+GR+TU_128+32FLASH_A03 , 00000000
code offset: 00000000
ffs offset/size [01]: 00E00000/00200000
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
checking area [00000000]: 00080000-00FFFFFF...
Can't detect ffs/eeprom area
Do you want to use standard ffs/eeprom address: 00E00000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
2. make flash backup for emergency case
3. repeat required operation
standard ffs/eeprom address selected by user
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
detecting startup code area #2...
startup code area #2 is absent
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
Backup required data Done
====> Patch required data ...
detecting ffs/eeprom structure pass 2...
ffs/eeprom: can't detect record name location
error: ffs/eeprom detection failed element #2
error: can not detect default imei value
Patch required data Fail
Finished, time used: 2 min 15 sec
Remove/Install battery now !
pls help me
Old 06-27-2010, 21:04   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
flash with this flash file:
flashfiles/ChineseMiracle/_MT6205-MT6227/M5120_HRD_APPLE_UI1_KEY4_EN+FR+SP+P0+IT+GR+TU_V25_ _i9+++_16m_En_Fr_Es_It_De_Tr_Pt.B0M.bin
Old 06-28-2010, 04:10   #3 (permalink)
baldev's Avatar
Member: 153805
Thanks Meter: 325
hello!
hello infinityhelp I have same model its flash is erased i.e. no flash file details.customer took out battery while set was making a call.I flashed it with few i9+++ flash file but still set not on.
can anyone have working i9++i and read full flash and send to Infinity support.
Old 06-28-2010, 05:58   #4 (permalink)
Member: 64823
Thanks Meter: 439
DId you try after flash a COMPLETE FFS???? Make it and post results !!
Old 06-28-2010, 07:54   #5 (permalink)
umarmsn's Avatar
Member: 616909
Sonork: 1672125
Thanks Meter: 648
hello!
module v3.15
Action: write flash
"smart write" active
write: Firmware
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
ffs/eeprom backup enabled, it may takes several minutes !
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
status: FF
Boot Done
Initialize Done
====> Set baud ...
230400
Set baud Done
TCL-ID is absent
rom info ver: 04
TCL-ID is absent
ffs/eeprom found near: 00480000
Detected ffs/eeprom address is non-standard: 00480000
Posible reasons:
1. ffs/eeprom is Ok but address is non-standard
2. ffs/eeprom is damaged and can't be detected
3. ffs/eeprom is Ok but detected incorrectly (f.e. unknown ffs/eeprom structure)
If you are not sure that detected address is correct:
1. press "NO" (and select standard address or terminate current operation)
2. make full flash backup for emergency case
Are you sure that detected ffs/eeprom address is correct ?
autodetected ffs/eeprom address confirmed by user: 00480000
ffs/eeprom size: 00B80000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00480000-00FFFFFF
reading: M5120_HRD_UI2_EN+FR+SP+PR+GE+GR+TU_128+32FLASH_A03 __ffs...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\M5120_HRD_UI2_EN+ FR+SP+PR+GE+GR+TU_128+32FLASH_A03__ffs_20100628-120437.B0E.bin
Patch required data Done
====> Special operation ...
Code CRC check error fix...
firmware do not have "Code CRC check error" area
Special operation Done
====> Write ...
sec info (fast) detection...
usb bootloader (file) is absent
startup code area #1 check...
startup code area #1 fixed
Area: Firmware
Write: Firmware
Write Done
====> Finalization ...
Finalization Done
Finished, time used: 28 min 15 sec
yes it is working so i like infinity i have no words to express my thanks to infinity once again thanks a lot
Old 06-28-2010, 14:49   #6 (permalink)
baldev's Avatar
Member: 153805
Thanks Meter: 325
yes i tried it.
COM6 [VCP0] selected
module  v3.15
advanced flash detection disabled
Action: read/check information
====>  Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
chip: 0001:B703:0003
status: FF
Boot Done
flash: EC240200000000:FFFFFF00000000
Initialize Done
====>  Set baud ...
921600
Set baud Done
Warning: probably flash chip is empty, erased, incorrectly flashed or damaged !
Old 06-28-2010, 21:56   #7 (permalink)
Member: 148515
yes i tried it.
[/CODE]
hello!
In current situation best move is following:
disassemble phone and crefully check PCB.
there MUST be short software code printed on board.
post it here, i will advice flash file.
here is example how this method works for people:
help me please mobile chine - GSM-Forum
"Deskey Device driver not found" ?? Please help DivAdonis Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-08-2017 13:21
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-30-2014 08:14
what prog changes imei on 6110 and how do i do it? Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 07-31-2012 20:09
Page generated in 0.25464 seconds with 10 queries
