04-14-2011, 14:58 | #1 (permalink) |
Freak Poster Join Date: Jan 2009 Location: IN U R MIND
Member: 947992 Status: Offline Thanks Meter: 37 | MT6225 format ffs warning: wrong cs at 0x01F93800, retry. ffs warning: wrong cs at 0x01F93800, retry. COM35 [Serial2] selected module v3.28 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:8203:0000 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E223C2200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb otp offset: 00000000 detecting chip #01 in region #00... flash: 01227E223C2200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb otp offset: 00000000 number of flash chip/regions detected: 02/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 01227E223C2200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb otp offset: 00000000 detecting chip #01 in region #00... flash: 01227E223C2200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb otp offset: 00000000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 02000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (07) TCL-ID is absent rom info detection finished rom info ver: 07 sw version: SUPERCON25_09A_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_0 9A_W09_32_MP_V1.BIN project-id: MAUI.09A.W09.32.MP.V1, 00000000 code offset: 00000000 ffs offset/size [01]: 01D00000/00300000 rom info structure: [standard] type (07) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 01D00000 standard ffs/eeprom offset confirmed: 01D00000 detecting ffs/eeprom size... ffs/eeprom size: 00300000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:01D00000-01FFFFFF firmware area: 00000000-01CFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: SUPERCON25_09A_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_0 9A_W09_32_MP_V1__ffs... warning: wrong cs at 0x01EA3000, retry... read error recovered warning: wrong cs at 0x01F93800, retry... warning: wrong cs at 0x01F93800, retry... warning: wrong cs at 0x01F93800, retry... warning: wrong cs at 0x01F93800, retry... warning: wrong cs at 0x01F93800, retry... warning: wrong cs at 0x01F93800, retry... warning: wrong cs at 0x01F93800, retry... warning: wrong cs at 0x01F93800, retry... warning: wrong cs at 0x01F93800, retry... error: too many retries during read operation Probably errors exist during flash read operation. Do you want to repeat read operation ? aborted by user file saved: C:\InfinityBox\ChineseMiracle\SUPERCON25_09A_GEMIN I_PCB01_GPRS_MT6225_S00.MAUI_09A_W09_32_MP_V1__ffs _20110414-075502.B0E.bin error: incorrect ffs buffer size Finished, time used: 5 min 28 sec Remove/Install battery now ! |
04-14-2011, 15:10 | #3 (permalink) |
No Life Poster Join Date: Mar 2009 Location: earth
Member: 992568 Status: Offline Sonork: kulit Thanks Meter: 231 | sir did you use 1.41 ver with 3.29chinemiracle update the last time i used that version that was happened in my infinity when im flashing and formatting maybe its not compatible to dual core or i don't know but when i turn it back to 2.19b and Chinese miracle ver3.26 my job will come smooth and function perfectly may be that new update of infinity is not applicable somewhere or conflict with the other driver of our box i don't exactly but try to turn it back to previous ver. you use before and if the problem persist reheat flash or mtk chip mild only good luck |
04-14-2011, 15:20 | #4 (permalink) | |
Product Supporter Join Date: Nov 2010 Location: Every where
Member: 1549240 Status: Offline Thanks Meter: 1,130 | Quote:
CS problems with dejan flasher | Dark Lemming | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 02-02-2001 12:27 |
Someting wrong | zizo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 10 | 01-11-2001 08:13 |
Nokia2000 return a [b]Wrong[/b] security code | baypierre | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-19-2000 23:03 |
How can I use AT command control Nokia6110?Help me! | arnom | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 07-15-2000 07:35 |
What's wrong with my 6150? | tojij | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 05-16-2000 06:55 |
