Old 05-31-2012, 10:37   #1 (permalink)
Member: 1698387
Thanks Meter: 43
Mt6252 imei repair
Hello
Please help to repair imei.
Cpu mt6252
repair imei 1-2 is ok but 3-4 is not working.
This is imei 3 repair!
COM4 [VCP0] selected
module v4.27
Device: _Autodetect MT6252-6253 NOR
Checking data, wait...
advanced flash detection disabled
Action: "repair imei"
imei write method: mode-3
imei write channel: imei #3 for triple sim CPU
new imei: 355711223755037
ffs/eeprom backup enabled, it may takes several minutes !
====> Boot ...
This is imei 4 repair! It show that imei repair is ok but imei has not change.
Model: _Autodetect MT6252-6253 NOR
Phone should be Switched ON !
Connecting, wait...
Phone detected, wait...
imei-4: 355711223755045
imei write method: mode-1
imei write channel: imei #4
new imei-4: 355711223755045
verification Ok
Finished, time used: 5 sec
Remove/Install battery now !
Flash chip is also unsupported. Please support Thnak you
module v4.27
Action: read flash NAND
interface: BROM_DLL_v3.1108.00
Connect...
Connecting...
Booting...
Release Power button now !
bootcode current/expected: 3.2/3.2
CPU: 6250:CA02:0100
status: FF
bbchip bl ver: FE
NOR flash id[0000]: 0000:000000000000 [AMD] AM29DL323D
chip size: 0Mb
otp status/size: S_DONE/00000000
NAND flash id[0000]: 0000:000000000000 [SAMSUNG] K9F5608Q0C
chip size: 0Mb
page/spare size: 0000/0000
pages per block: 0000
bits i/o: 00
address cycles: 00
internal RAM size: 00000000
external RAM [HW_RAM_UNKNOWN, CS0] size: 00000000
error: can not boot device: 0C0B:S_DA_UNSUPPORTED_BBCHIP
error: last error: 0C0B:S_DA_UNSUPPORTED_BBCHIP
Disconnect...
done
Finished, time used: 19 sec
Old 06-01-2012, 07:46   #2 (permalink)
Member: 1043909
Thanks Meter: 60,926
Hello,
Try to use this software: http://forum.gsmhosting.com/vbb/f296...dated-1483908/
And for flash reading: press and HOLD phone "power" button until you will see "Set baudrate..." message.
Waiting for results.
The Following User Says Thank You to YellowBoss For This Useful Post:
Old 06-02-2012, 02:16   #3 (permalink)
Member: 1698387
Thanks Meter: 43
Hello
Now imei repairing is working good! The flas reading is still not working.
The result is same as before.
Thank you
Old 07-20-2012, 14:35   #4 (permalink)
Member: 878992
Thanks Meter: 34
have anyone successful yet repair imei on mt 6236?
would you please share how?
i have tried all mode.
still not succeed..
the phone is Nexian NX-G965.
thanks in advance
Old 07-20-2012, 14:41   #5 (permalink)
uttam4u2002's Avatar
Member: 523972
Sonork: 100.1596548
Thanks Meter: 1,259
still not succeed..
thanks in advance
Yes i am. Use New IMEI Writing Tool MTK. Download From HERE
B.R.,
B.Uttam
The Following User Says Thank You to uttam4u2002 For This Useful Post:
Old 07-21-2012, 11:55   #6 (permalink)
Member: 1406553
Thanks Meter: 2
did you test it brother??????????????????
Old 07-21-2012, 14:22   #7 (permalink)
Member: 878992
Thanks Meter: 34
I have try it. Successful.
Download the driver here:
MT6235 driver.zip - 4shared.com - online file sharing and storage - download
Good luck all.
and thanks for brother uttam4u2002.
Thank you very much
Working IMEI changed phone? Barjo Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 03-01-2015 11:49
what prog changes imei on 6110 and how do i do it? Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 07-31-2012 20:09
Nokia 51xx/61xx imei changer ver. 1.10?????? Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 04-06-2012 16:22
6110 imei changer !!!!!! Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 11-21-2011 01:44
Page generated in 0.21235 seconds with 10 queries
