02-11-2009, 08:54 | #1 (permalink) |
Freak Poster Join Date: Dec 2004 Age: 38
Member: 101615 Status: Offline Thanks Meter: 7 | N73-1 pinout module v2.73 Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:BD41:41E4 Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: V2.0628.0.0.1 Version: NokiaN73(11) detecting structure #2... done 60 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok building list... done items to clear: 216 items cleared: 197 of 216 building list... done items remains: 1 Finished, time used: 151 sec Remove/Install battery now ! |
The Following User Says Thank You to GEORGIA For This Useful Post: |
02-14-2009, 15:22 | #5 (permalink) |
Freak Poster Join Date: Jan 2005 Age: 45
Member: 110518 Status: Offline Thanks Meter: 17 | However, when used polar quenched lamp with red-polar I put in the right place. Positive in the positive and negative in the negative. But to no avail. pinfinder it can't read the rx and tx. if i chose from list from (InfinityBox PinFinder) program and run (ChineseMiracle) no response. plz help me how i can connect it. |
02-16-2009, 19:12 | #8 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,531 | hello! you can do this without disassembling phone by typing *#0044# and pressing green (send) button. if you will see "language set: english"- you can be sure, that this phone is supported by Infintiy software (mt62xx based) |
02-17-2009, 13:31 | #9 (permalink) |
Member: 110518 Status: Offline Thanks Meter: 17 | [QUOTE=InfinityHelp;4162621]hello! you can do this without disassembling phone by typing *#0044# and pressing green (send) button. if you will see "language set: english"- you can be sure, that this phone is supported by Infintiy software (mt62xx based)[/QUOTE Thank you very much, Mr. I noted at the poles connect any type of phone on the pinfinder extinguished, the lamp Even when connected with pinfinder on output2, the Nokia 3110 i noted the red lamp turn off. Is the problem of Pinfinder? |
N73s spreadtrum pinout | overdose | Infinity-Box | 1 | 06-03-2008 07:50 |
N73s spreadtrum pinout ?? | overdose | SpiderMan | 0 | 06-02-2008 21:17 |
n73 2sim pinout | MaHmUt1982 | Infinity-Box | 1 | 05-30-2008 07:10 |
N73-1 Pinout please | rajumobile | Infinity-Box | 9 | 01-23-2008 02:53 |
NEX MINI and N73 CABLE PINOUT | Nasmi | Infinity-Box | 2 | 12-17-2007 23:20 |
