Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Infinity-Box > Chinese Miracle & PinFinder
Old 01-12-2008, 15:19   #1 (permalink)
rajumobile's Avatar
Member: 54993
N73-1 Pinout please
N73-1 Pinout please, connector is DKU-2 type.
Attached Found two pinouts in the forum but not working, gnd is same as in picture.
please help.
Thanks.
The Following User Says Thank You to rajumobile For This Useful Post:
Old 01-12-2008, 21:43   #2 (permalink)
allal123's Avatar
Member: 192681
Sonork: 100.106870
OPEN UR PHONE AND U FIND RX/TX/GND NEAR THE CONNECTOR SIM
i think it's work for u
The Following User Says Thank You to allal123 For This Useful Post:
Old 01-12-2008, 23:31   #3 (permalink)
rajumobile's Avatar
Member: 54993
Thanks for yr help.
I'll check and post result soon.
Regards.
Old 01-16-2008, 20:35   #4 (permalink)
rajumobile's Avatar
Member: 54993
Its not working bro.
anybody have working pinouts please.
thanks.
Old 01-16-2008, 21:01   #5 (permalink)
BouRRi_GSM's Avatar
Member: 111457
u have 100% problem with connection
pinout on board must work and tested by all pêoples on this forum
what's not working exactly!!!!!!!!!!!!!!!!!!
br
Old 01-17-2008, 15:48   #6 (permalink)
rajumobile's Avatar
Member: 54993
Yes bro you r right, pin out on PCB works all the time, but my N73-1 have no rx, tx marked on PCB as sown in picture. Even no points without marking itself.
regards
Old 01-17-2008, 16:26   #7 (permalink)
Member: 148515
hello!
so what was a reason to post "not working" ? you had to write "not exist"
i would advice you to use "pin voltage measuring method"
by checking voltage on each phone pin you can find needed pins
Old 01-19-2008, 13:07   #8 (permalink)
BouRRi_GSM's Avatar
Member: 111457
@rajumobile
remove phone info/imei sticker, and check under
Old 01-22-2008, 22:31   #9 (permalink)
electrosoft's Avatar
Member: 93850
regards
Tray this pinouts
br!
Old 01-23-2008, 01:53   #10 (permalink)
Member: 185776
Thanks electrosoft.I will post result very soon.Thanks advance.
N73-1 pinout GEORGIA Chinese Miracle & PinFinder 11 02-19-2009 21:43
Need N73 dual sim pinout please....... ASHRIFF Chinese Models & Cloned Phones 3 11-12-2008 05:47
N73s spreadtrum pinout overdose Chinese Miracle & PinFinder 1 06-03-2008 07:50
n73 2sim pinout MaHmUt1982 Chinese Miracle & PinFinder 1 05-30-2008 07:10
NEX MINI and N73 CABLE PINOUT Nasmi Chinese Miracle & PinFinder 2 12-17-2007 22:20
Page generated in 0.35885 seconds with 12 queries
