Old 03-18-2009, 06:48   #1 (permalink)
FullFLASHgSMPH's Avatar
Member: 161739
Sonork: 100.1584054
Thanks Meter: 3,338
n79i phonelock DEAD
COM5 [VCP1] selected
module v2.78
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: "format ffs"
Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:6803:0005
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: 98004900000002:18E59F00000000
flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
Set baud ...
115200
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
device parameters autodetection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [standard] generation
New firmware detected (v.2.78, database date: 04.03.2009):
CELLTEL25_GEMINI_PCB01_GPRS_MT6225_S00.CBM16B_H_V3 23.BIN
This firmware is missing in support area. If this phone is good and working:
- make "Read full flash" operation
- send flash backup files to support: [email protected]
- include in your e-mail full text from phone back label (phone name etc.)
identification#1 detection finished
identification#1 protocol ver: 04
ver. sw 1: CELLTEL25_GEMINI_PCB01_GPRS_MT6225_S00.CBM16B_H_V3 23.BIN
ver. sw 2: CBM16B_H_V323, 00000000
ffs offset/size: 00E00000/00200000
detect device identification#2...
detect device identification#2 finished
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
checking area [00000000]: 00000000-00FFFFFF...
ffs/eeprom found near: 00430000
Detected ffs/eeprom address is non-standard: 00430000
Posible reasons:
1. ffs/eeprom is Ok but address is non-standard
2. ffs/eeprom is damaged and can't be detected
3. ffs/eeprom is Ok but detected incorrectly (f.e. unknown ffs/eeprom structure)
If you are not sure that detected address is correct:
1. press "NO" (and select standard address or terminate current operation)
2. make full flash backup for emergency case
3. repeat required operation
Are you sure that detected ffs/eeprom address is correct ?
autodetected ffs/eeprom address confirmed by user: 00430000
detecting ffs/eeprom size...
ffs/eeprom size: 00BD0000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00430000-00FFFFFF
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
Write Done
Finalization ...
formatting...
Finalization Done
Finished, time used: 157 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
Old 03-19-2009, 12:05   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
have you pressed power button long? up to 1 minute?
did you check if bettery fully charged?
need a flash file tv n79i urgently FullFlashPak Infinity-Box 5 11-21-2011 19:48
help!! se p910i phonelock, dead ru_dee HWK 7 04-02-2010 15:18
Genie dead no power on... [ANSWERED] lchico Genie Universal 1 03-29-2010 07:18
I cant play games in my n79i lil_pooch-357 Chinese Models & Cloned Phones 0 02-27-2009 06:44
N79i Pinout ?? ~mr_Ten$ion~ Infinity-Box 1 11-01-2007 00:30
Page generated in 0.14270 seconds with 10 queries
