Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Infinity-Box > Chinese Miracle & PinFinder
Old 01-06-2008, 19:35   #1 (permalink)
.:bono:.'s Avatar
Member: 96141
n95 new firmware, wanna flash lannguage
general information:
Action: read information
Model: Autodetect 6205-6227 NOR
Checking data, wait...
Phone should be Switched ON !
Connecting, wait...
Phone detected, wait...
Hardware version: MT6226, E02
Hardware version: HEXING26_06A_HW
Software version: MAUI.06A.W06.48.10"
Software date: 2005.04.12
Barcode: MT012345678901234567
imei: 356826010165189
Finished, time used: 5 sec
Power off phone now !
i have backup both eeprom and full flash:
backup_eeprom[LEDA26_06A_PCB01_GPRS_MT6226_S01.MAUI_06A_W06_48_1 0.BIN]_20080106-195555.B0E.bin (38ko)
backup_flash[LEDA26_06A_PCB01_GPRS_MT6226_S01.MAUI_06A_W06_48_1 0.BIN]_20080106-200817.B0M.bin (9.797mo)
COM1 [VCP3] selected
Device: Autodetect 6205-6227 NOR
advanced flash detection active
Action: read NOR flash
Boot...
baud autodetection active
19200
Connecting, wait...
Initializing[6226:8A02:8A01]...
chip: 0031:3352:2D8C
high speed disabled
boot step size: 0002
Release Power button now !
Boot Done
Initialize...
flash: 98004900000002:2BEA0000000000
flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
921600
Set baud Done
Identification...
device parameters autodetection in progress..
it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area#1 is Ok
security area#1 backup saved: F:\Dongels\InfinityBox\ChineseMiracle\backup_secur ity\id.BDCBEA58.[LEDA26_06A_PCB01_GPRS_MT6226_S01.MAUI_06A_W06_48_1 0.BIN_AE4D9433].rpl
New firmware detected:
- make "Repair security area" operation
- send "backup_system_log_..." file to support
- make "Read full flash" operation
- send flash backup file(s) to support
- include in your e-mail full text from phone back label (phone name etc.)
identification#1 detection finished
device-id: BDCBEA58
identification#1 protocol ver: 05
ver. sw1: LEDA26_06A_PCB01_GPRS_MT6226_S01.MAUI_06A_W06_48_1 0.BIN
ver. sw2: MAUI.06A.W06.48.10
ffs offset/size: 00E00000/00200000
detect device identification#2...
warning: optional information not found
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00E00000
checking area[00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00E00000
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
reading [flash[LEDA26_06A_PCB01_GPRS_MT6226_S01.MAUI_06A_W06_48_1 0.BIN]]...
warning: wrong data size at 0x00270400, retry...
read error recovered
warning: wrong data size at 0x0056A800, retry...
file saved: D:\Documents and Settings\Ahmed\Bureau\n95 2sim dlide moh backup\backup_flash[LEDA26_06A_PCB01_GPRS_MT6226_S01.MAUI_06A_W06_48_1 0.BIN]_20080106-200817.B0M.bin
file saved: F:\Dongels\InfinityBox\ChineseMiracle\backup_syste m_log_BDCBEA58_LEDA26_06A_PCB01_GPRS_MT6226_S01.MA UI_06A_W06_48_10.BIN_AE4D9433_20080106-200842.B0X.bin
Finished, time used: 666 sec
Remove/Install battery now !
phone name is n95 firmware LEDA26_06A_PCB01_GPRS_MT6226_S01.MAUI_06A_W06_48_1 0 (9.797Mo)
i want to flash french language and in support area i've found same firmware in french but for 6300 CM_Nokia-6300_LEDA26_06A_PCB01_GPRS_MT6226_S01.MAUI_06A_W06_48_1 0_16m_En_Ru_Fr_Th_Vn_Ar.B0M.bin (8.702Mo)
can i flash this flash file to my phone?
br
Old 01-06-2008, 19:56   #2 (permalink)
Member: 148515
hello!
are you using latest chinese miracle soft?
after you made backup you can to try to flash any file you want
Old 01-06-2008, 20:04   #3 (permalink)
.:bono:.'s Avatar
Member: 96141
hi support!
i use latest soft
u wanna say there is no risk to try the file i found for 6300 6300 CM_Nokia-6300_LEDA26_06A_PCB01_GPRS_MT6226_S01.MAUI_06A_W06 _48_1 0_16m_En_Ru_Fr_Th_Vn_Ar.B0M.bin
it looks like same version with my phone, but my phone name is n95?
Old 01-06-2008, 20:07   #4 (permalink)
Member: 148515
hello!
yes, it is safe to try. if it will not work- you will be able to restore your phone to original state.
Please send your backup to us for updating CM soft to recognise this firmware in future
infinityhelp@yahoo.com.hk
Old 01-06-2008, 20:27   #5 (permalink)
.:bono:.'s Avatar
Member: 96141
flashed, phone power on, but white screen
COM133 [VCP2] selected
Action: write NOR flash
"smart write" active
write: Firmware
skip: Customization
skip: Language Pack
skip: Eeprom/ffs
Boot...
19200
Connecting, wait...
high speed disabled
Boot Done
Initialize...
Initialize Done
Set baud...
921600
Set baud Done
Identification...
device-id: BDCBEA58
ffs chip: 00
reading [eeprom[LEDA26_06A_PCB01_GPRS_MT6226_S01.MAUI_06A_W06_48_1 0.BIN]]...
file saved: F:\Dongels\InfinityBox\ChineseMiracle\backup_eepro m[LEDA26_06A_PCB01_GPRS_MT6226_S01.MAUI_06A_W06_48_1 0.BIN]_20080106-210945.B0E.bin
Identification Done
Manipulation...
Manipulation Done
Finalization...
Finalization Done
Write...
security area#1 calculation...
done
file saved: F:\Dongels\InfinityBox\ChineseMiracle\backup_syste m_log_BDCBEA58_LEDA26_06A_PCB01_GPRS_MT6226_S01.MA UI_06A_W06_48_10.BIN_AE4D9433_20080106-210955.B0X.bin
Area: Firmware
Write: Firmware
Write Done
file saved: F:\Dongels\InfinityBox\ChineseMiracle\backup_syste m_log_BDCBEA58_LEDA26_06A_PCB01_GPRS_MT6226_S01.MA UI_06A_W06_48_10.BIN_AE4D9433_20080106-211548.B0X.bin
Finished, time used: 589 sec
is it clear that this firmware didn't much it or i have to do something else?
br
Old 01-06-2008, 21:04   #6 (permalink)
.:bono:.'s Avatar
Member: 96141
ok, i flashed it back with backup, it's fine, thanks
also i have sent u full backup and eeprom.
br
Old 01-06-2008, 21:35   #7 (permalink)
Member: 148515
hello!
yes, looks like that firmware do not suit to your phone.
even if would work, french language will be very funny in phone due a poor translation.
if you have some quantity of CM phones moving around maybe it worth to think about buying our language editor
*-* N95 New Firmware Virsion *-* mr.6630 Chinese Cocktail 6 02-11-2008 11:40
N81 & N95 New Firmware Details... Shayesta197 Nokia Base Band 5 ( BB-5 ) 2 11-20-2007 21:30
N95 NEW FIRMWARE (v12.0.013) Coming Soon! Shayesta197 Nokia Base Band 5 ( BB-5 ) 3 06-21-2007 18:23
N95 New Firmware 11.0.025 samipower Nokia Base Band 5 ( BB-5 ) 16 04-25-2007 23:45
Page generated in 0.32425 seconds with 12 queries
