11-15-2008, 01:37 | #1 (permalink) |
No Life Poster Join Date: May 2005 Age: 40
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | N95 (T6226_05C_PCB01_GPRS_MT6226_S01.B10_EFAIS_V1017A) is Dead.. after firmware refresh phone is dead now..pls check the log... Code: COM17 [VCP2] selected module v2.69 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: read/check detailed information Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:2866:E067 high speed disabled boot packet size: 0002 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:76737200000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:76737200000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: EC257E25082501:76737200000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:76737200000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 76657273696F6E3A30320000000000000000000000000000 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... . detection phase #2... ................................................................................................................................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1.... warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset assigned: 00E00000 flash: EC257E25082501:76737200000000 checking area [00000000]: 00000000-00FFFFFF... Can't detect eeprom/ffs area Do you want to use standard ffs address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs address selected by user detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF detecting ffs structure pass 1... ........................................................ can't detect fat record name location error: ffs element #1 detection failed detecting ffs structure pass 2... ........................................................ can't detect fat record name location error: ffs element #2 detection failed Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... Finished, time used: 173 sec Remove/Install battery now ! |
11-15-2008, 02:00 | #2 (permalink) | |
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | Quote:
i have the org. backup but after flashing again phone is still dead.. eeprom log.. Code: COM17 [VCP2] selected module v2.69 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: write NOR flash "smart write" active skip: Firmware skip: Customization/Language Pack skip: Customization write: Eeprom/ffs Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:2866:E067 high speed disabled boot packet size: 0002 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:76737200000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:76737200000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: EC257E25082501:76737200000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:76737200000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 76657273696F6E3A30320000000000000000000000000000 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... . detection phase #2... ................................................................................................................................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset assigned: 00E00000 flash: EC257E25082501:76737200000000 checking area [00000000]: 00000000-00FFFFFF... Can't detect eeprom/ffs area Do you want to use standard ffs address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs address selected by user detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: eeprom... file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom_20081115-025718.B0E.bin flash: EC257E25082501:76737200000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Area: Eeprom/ffs flash: EC257E25082501:76737200000000 Write: Eeprom/ffs detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished Write Done Finalization ... Finalization Done Finished, time used: 315 sec Remove/Install battery now ! | |
11-15-2008, 02:07 | #3 (permalink) |
No Life Poster Join Date: Nov 2008 Location: Riyadh, KSA Age: 43
Member: 894719 Status: Offline Sonork: 100.1580092 Thanks Meter: 905 | try this one its back up flash file and the epprom of a chinese nokia N95 T6226_05C_PCB01_GPRS_MT6226_S01.MAUI_05C_W06_16_MP _V3_F3_1.BIN click here let me if it works good luck shehab |
The Following User Says Thank You to gsm2start For This Useful Post: |
11-15-2008, 02:27 | #4 (permalink) | ||
phone is oki now.. with orj eeprom and flash file.. eeprom[T6226_05C_PCB01_GPRS_MT6226_S01.B10_EFAIS_V1017A.B IN]_20081113-015948.B0E flash[T6226_05C_PCB01_GPRS_MT6226_S01.B10_EFAIS_V1017A.B IN]_20081113-001035.B0M | ||
11-15-2008, 02:31 | #6 (permalink) | |
i will add to rapidshare to this new flash file.. cause of not exist on support.. supporter would add to support page.. thanx for ur sensetive again... | |
11-15-2008, 02:39 | #7 (permalink) |
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | eeprom[T6226_05C_PCB01_GPRS_MT6226_S01.B10_EFAIS_V1017A.B IN]_20081113-015948.B0E flash[T6226_05C_PCB01_GPRS_MT6226_S01.B10_EFAIS_V1017A.B IN]_20081113-001035.B0M http://rapidshare.com/files/16387626....BIN_.rar.html b.r. |
The Following User Says Thank You to LoveLess For This Useful Post: |
ub team n95 8g after unlock contact service my phone is dead helllllllllllllllllllllp | khalid0909 | Universalbox | 3 | 03-28-2009 11:17 |
Nokia N95 - Is Dead After Unlock | PHU KADAR | Nokia Base Band 5 ( BB-5 ) | 7 | 11-11-2008 03:59 |
n95 rm-160 to n95 rm-159 is it possible? | $ide$tep | Nokia Base Band 5 ( BB-5 ) | 2 | 03-12-2008 23:46 |
Has anyone supplied bb5team with n95-8gig locked ? Is n95-8g coming soon? | Rezn | BB5BOX | 13 | 02-25-2008 21:07 |
